Ball joint installation
Will be installing new ball joints this weekend- do you tighten the ball joint nut to the ball joint using any anti-seize on the threads? Also, Some say ant-seize on the wedge pin, what about grease on the wedge pin, any thoughts? Thanks, Jerry
Old 03-17-2006, 06:33 PM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
I'm not sure about your particular inquiry, but it's always helpful if you tell us what car you're working on (what year).
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 03-17-2006, 06:36 PM
Yes It is 1977 911. Installing new ball joints and turbo tie rods, Just inquiring on what everyone is using on the the ball joint and tie rod joints and threaded parts if anything at all, anti-seize, grease, lock-tite?, before I do this tomorrow. thanks Jerry
Old 03-17-2006, 07:02 PM
Jeff Alton's Avatar
Use the anti seize on the pin. You can use it on the threads if you would like as well.
Cheers
www.turn3autosport.com
Old 03-17-2006, 07:15 PM
Senior member
steve lewis's Avatar
Jerry, I have just completed the same job on my car 77 carrera 3 and according to the factory porsche spec book I have it says to apply grease to the threads on the nut ( ball joint to control arm that is and torque to 250Nm)this is the only nut to grease according to this book. I also applied grease to all surfaces on the wedge pin except for its thread
1976 - Porsche 911 Carrera 3
1972 - VW Microbus 9 seater (low light)
1962 - VW split screen single cab
Old 03-17-2006, 07:49 PM
Steve, thanks for the info. I would think that if you greased this nut it would probably be only a light coat. Does grease affect the torque setting and would it tend to loosen the nut eventually? Not sure, Thanks jerry
Old 03-19-2006, 06:55 AM
Nine9six's Avatar
I completed this job awhile back...a light coat of antisieze on the pin, and ball joint thds, and torque to spec.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 03-19-2006, 07:36 AM
Senior member
G`day Jerry, I only lightly greased the large nut you shouldn`t have any worries with it coming loose if you torque it up correctly (torqued up fine with the grease) and refit the wave washer and cotter pin.
hope all goes well. Steve
Old 03-21-2006, 01:52 AM
Thanks all for responding. Had to put my ball joint intall on hold for a week or so, while i source new torsion bars. Had a small problem with rubbing torsion bars wearing a ridge in them, Jerry
Old 03-21-2006, 07:31 PM
Air Medal or two
afterburn 549's Avatar
what did you use to seperate the strut from the lower control arm...Pickle fork ??........having seperation problems here
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 03-24-2006, 12:16 PM
What is the torque on the tie rod side connecting to the strut?
Thanks,
Old 03-24-2006, 01:35 PM
The pickle fork did not work for me- after friving the pin out, after much wasted time with a pickle fork, & small 2 ' pry bar I finally got it separated by pushing in on the strut and using a large 5 foot steel bar wedged under the belly of the car and over the a-arm then pushed down on the large pry bar, popped right out. The key I think is pushing in on the rotor/strut creating a better angle for the pin to come out and the use of alot of leverage. Argeo- I don't have my manual with me now but if memory serves me correctly I think it was 33 or 36 lb- the nut attaching the tie rod to the spindle arm. The large ball joint nut is 184 lb. Jerry
Old 03-24-2006, 07:38 PM
Air Medal or two
thats what works well,-lean it way away from the car and wack it
Old 03-24-2006, 08:33 PM
Yes, and push in on the rotor while doing it
Old 03-24-2006, 08:45 PM
