Blk95993's Avatar
Question Sunroof wont slide back-what to do??
Sun roof will not slide back more than a 1/4 of the way. My guess is that it is off track? Any words of advice, thoughts on what to do??
Porsche-Less at the moment....
Old 03-30-2006, 05:40 PM
bagpiper46's Avatar
Had that happen last fall. Seems to be off the track on one side and I was able to push/giggle it back using one hand and the switch. Might not be your case though. I haven't had a need for sunroof this winter here in Colorado but I am planning on opening it up in a few weeks to see if it just got off track or if I need parts from our host. Hope it works out for you.
Old 03-30-2006, 05:50 PM
they really don't get off track. the cables break on one side and it binds from getting pulled on only one side. sometimes the cable pulls out of it's slider block where it bolts to the sunroof panel. they can often be twisted back in and recrimped to save money.
206 637 4071
Old 03-30-2006, 06:09 PM
This exact thing happened to me last year. What has likely happened is that one of the cables has pulled away from the sliding mechanism in the guide rail. There's a tech article on this site that takes you through the steps to repair it. You can replace the cables, but I believe you have to adapt newer style cables since the old ones (yours) are no longer made. Or, you can do what I did and use JB Weld - remove the cable and the sliding mechanism, slap some JB Weld on it, reinstall and you are good to go. No problems since then. Not sure how long it will last, but it was the cheapest solution.
Todd
99 BMW 528
68 Land Rover Series IIa - 0-60 all in the same week
86 Carrera Coupe, sold, missed
"If a woman has to choose between catching a fly ball and saving an infant's life, she will choose to save the infant's life without even considering if there is a man on base." - Dave Barry
Old 03-31-2006, 06:25 AM
I had a problem with my sunroof as well. I found that a little lubrication in the channels solved it.
The older I get, the more I realize that patience is a virtue and, I only wish that I had some.
Old 03-31-2006, 04:37 PM
ruf-porsche's Avatar
Sunroof won't slide back-what to do??
Trade it in for a Targa.
Old 04-01-2006, 04:00 AM
Driving member
jester911's Avatar
Re: Sunroof wont slide back-what to do??
Yeah, then it doesn't ever stick. It just leaks air, water, flies off while driving, what else am I forgetting.
Just ribbin ya a little ruf-porsche
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 04-01-2006, 05:51 AM
