Toothzilla's Avatar
WEVO vs. Stomski shift couplers?
Which one did you guys choose, and why?
TIA
Chris
'02 996 TT
'84 Turbo Look
'72 911 Vintage Racer
06 Tacoma (Tow)
Old 04-03-2006, 01:12 PM
Administrator
Jack Olsen's Avatar
In my opinion, Wevo is one of those (very rare) aftermarket companies that you can place blind faith in, and just jump. Everything I've seen from their product line has been best-in-class, built to standards on par with those of Porsche's engineering department at the top of its game. I hate to gush about any company (they can only disappoint me, now ), but Wevo earns it.
Very smart company. Very smart products.
I've got their shifter, coupler and gateshift. I hope to eventually have their motor mounts and swaybar mount replacements.
That's not to knock the Stromski product. I've seen it, but haven't used it.
But I put the Wevo in my own car. (And when I ran the Open Track Challenge, I asked Wevo if I could put their decal on my car, not the other way around.)
Old 04-03-2006, 01:39 PM
PRO Motorsports
Tyson Schmidt's Avatar
Maybe we should put them head to head in a cage match to the death to decide the winner.
A shift-off, no holds barred!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 04-03-2006, 02:22 PM
Maybe simply use the tighter-tolerance 914 inserts into a stock coupler
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-04-2006, 12:19 PM
Bill Verburg's Avatar
Maybe simply use the tighter-toleeance 914 inserts into a stock coupler
That's what I ended up w/. I swapped back and forth between a Stomki and a stock coupler w/ custom brass inserts(essentially the brass 914 ones at a higher cost). I think that I mightl ike to try Sherwood's shift mod as icing.
The brass inserts, zero clearance bushes and some other minor tweeks make it shift like a dream, even better than my 993 w/ RS shift linkage
Bill Verburg
Old 04-04-2006, 12:44 PM
randywebb's Avatar
I agree with Jack in general re Wevo (also SRP).
But as Tyson says, nothing beats an experiment...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Jubbie's Avatar
I have got the Stomski coupler and it looks pretty good and just like the pictures of the Wevo product. I think the universial joint is a standard aircraft part that both companies modify to do the Porsche job. Some one should buy both and run a test.
John F. Lewis
74' 911S Targa + 930/02
76' 914 - Eternal Type IV project FOR SALE
Old 04-04-2006, 02:15 PM
Jubbie:
Look what I say here...same thought ...
--> http://forums.pelicanparts.com/showthread.php?threadid=110665&highlight=Ferch+universal+coupler+Aircraft
Wil
Wil Ferch
Old 04-05-2006, 08:45 AM
I have a question for those of you that have tried one of the Stomski or Wevo couplers, or have used the 914-style bushings in a stock coupler. Do you notice any vibration (and noise) from the shifter at any point in the rev range, or any fore/aft movement of the shift lever when getting on and off of the throttle?
I am thinking of street car application here, not a race car. Other cars I own are sensitive to reducing the slop in the linkage and I don't want to create a problem (buzzing lever) by using one of these.
Thanks,
JR
We need not be gracious when our enemy dies. Civility is only afforded those who don't go to their grave trying to destroy us and ours. E. M. Burlingame
Old 04-05-2006, 10:07 AM
JR, I have the wevo shift coupler and shifter in my 930. It shifts very well and is a great improvement over stock in terms of shifting ease and precision. That said, with the Wevo parts, transmission sounds are transmitted through the coupler resulting in a slight buzzing sound. It is only noticeable when "lugging" the car, being in a higher gear at low rpm. In terms of audibility, I can't hear it with the radio on or window open.
Tim
'06 Cayman S
'96 993tt
'87 930 (gone, but not forgotten)
Old 04-05-2006, 10:31 AM
tobluforu's Avatar
Stomski and no complaints
Old 04-05-2006, 11:39 AM
stv951's Avatar
Bill, where can I get the brass inserts and zero clearance bushes ? What are the tighter-tolerance 914 inserts ? Are they stock parts ?
Old 04-05-2006, 01:10 PM
klaucke's Avatar
The tighter tolerance 914 bushings are just shift coupler bushings for a 914, which have circular holes and not elongate holes, which reduces the fore/aft play in the shifter significantly. In theory, they would not (significantly) improve side radial slop over good condition stock 911 bushings. I'm not sure you can even buy the 911 bushings anymore, but Pelican most definately carries the 914 pieces.
Old 04-05-2006, 01:26 PM
Neil Peart Fan
Pele911's Avatar
I have the Stromski and it takes out a lot of slop. I have driven a 911 witht he Wevo coupler but it also had the Wevo shifter housing so it wouldnt be a fair comparison. Both couplers are very similar in design so I dont think you can lose. Add the Robotek spring shifter and you got yourself a smooth( for a 915) shifter.
Old 04-05-2006, 02:43 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
I ended up getting the stomski because I was ordering some other bits from them at the same time. Dont really think there can be a huge difference betwixt the two. FWIW the stomski piece is plated the factory yellow cadmium color, the rubber boot seal is red and is a very smooth piece. Doubt there is any other difference between them and I believe they both cost the same.
Trident racing in the UK sells a gaggle of linkage pieces and I am sure if you are into the make your own part category you could get what you need there.
74 911s neverending story. two feet and a jetta for now.
Old 04-05-2006, 02:47 PM
Send a message via Yahoo to Lukesportsman
They are very similar in appearance to what Summit sells for drag cars' steering u-joints. They were listed as a "helicopter joint" on the parts sheet included. I paid $68 for the bare part and then you'd have to go from there but its even the same color arrangement as stated above.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 04-05-2006, 03:04 PM
Toothzilla's Avatar
Thanks everyone for your input, I'm going to put in an order for the WEVO one.
Chris
'02 996 TT
'84 Turbo Look
06 Tacoma (Tow)
Old 04-05-2006, 08:21 PM
gumba's Avatar
I think the Wevo coupler is beefier than the Stromski. The old SRP coupler and Stromski were the same size. I switched from the SRP to the Wevo a few years back when it came out. I noticed a slight improvement, as it felt tighter than the SRP.
Harold
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 04-05-2006, 08:34 PM
3 restos WIP = psycho
kenikh's Avatar
BINGO: Summit Racing link...
or Stomski: Stomski Racing link...
Family resemblance indeed! Looks like Stomski makes a coupler for these and that's that.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 04-05-2006, 08:38 PM
Kenikh, that summit link is dead and I don't find it using keyword search. Can you see if your Google-fu is stronger than mine and you can find the u-joint again? I've got a welder and a plan...
Ken
1986 930 2016 R1200RS
Old 03-29-2016, 08:08 AM
