Student of the obvious
Porsche 911SC office chair
I've had no luck selling a pair of slightly worn SC seats. Then a bracket broke on my office chair. Hmmmm.... an hour later:
Lee Last edited by LeeH; 04-15-2006 at 08:54 PM.. |
Will program for food
Sweet. That chair must be FAST!
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
I like it.
'94 VW Jetta '85 VW Scirocco '81 911 SC coupe Euro '67 VW Bug |
That you might actually be able to sell
Honest honey it's not a porn site...close but not quite. 2007 BMW 335 coupe 2005 Ducati Multistrada 2001 BMW 1100SA Light |
GFCC
That looks good Lee. I may have to make my Carrera seats into something like that.
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
Add a seat belt! looks good.
John Adams 1980 ROW 911SC |
Porsche-pa
Lee,
Very cool dood! I hope you have a high speed connection to compliment the whole picture. A seat belt is probably a good idea too. That seat will have you thinking about you car even more now. The belt may help you keep your butt on the job! LOL... I like it!
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious), Also rans... '02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7, Donny |
Just be careful with the oversteer.
"It looks like a Pleco.." |
I did that with a Mercedes seat and my kid used it throughout college. His buddies loved it. I saw an ad in the back of Car & Driver....Recaro office chairs go for a grand!!!!!
'82 911 SC |
Make Bruins Great Again
I must see the underside to see how you mounted it! (please)
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Tilt? Spring? Looks cool. and the price was right, LOL
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
The Porsche seat is thicker (ie taller) than most office chairs. If you mount the base to the bottom of the seat then it sits too high - even in the lowest position. I used two pieces of steel going across and mounted them directly to the factory holes. The base plate that would mount to the bottom of the office chair is mounted on top of the bars, up inside the seat base. Spacers result on a lower position. There's no tilt for the base, so I used different sized spacers to get the angle I wanted.
Lee Last edited by LeeH; 04-16-2006 at 10:43 PM.. |
GFCC
"Spacers result on a lower position."
So is this considered euro height specs?
Excellent idea! I'll keep that in mind when my seats are kaput!
1981 911SC Euro Trial & error, mostly error, I'll figure it out. |
Lee |
Is there a bump steer kit available?
GFCC
"Is there a bump steer kit available?"
I've heard rumors that this will be Tyson first and most pressing project once he is settled in a Wevo.
I have been planning to do that to a spare seat I have. How stable is it when you recline the seat back? Does the chair fall backwards?
Charles 88 Cab |
It goes pretty far back while still feeling stable. I can recline it to the seat's limit and not fall back, but at that point it's tipsy.
You can adjust the CG with the mounting point. The base on mine is just aft of center. I used some holes that were already in the steel. I'm sure if I moved the base a few inches aft it would be stable in full recline.
Lee |
