Zombie
RSR steering wheel
Is this a RSR steering wheel? I read that their suppose to be 380mm or 15 inches?
Looks like a regular SC wheel to me. They are all 380mm.
Zombie
Your probably right but i thought the regular sc wheel was 16 inches.
Senior Registered User
I "thought" RSR steering wheels were Momo Prototipo.
Some else chime in here, I know you will if I am wrong ![]() Randy Jones 1971 911 "Iris" |
I think that picture is an SC wheel...I agree the RSR used either a Prototipo...or...I have also seen pics of the older 4 spoke wheels....but that may have been in an RS....
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
There is no specific 3.0 RSR wheel.
Every RSR had the wheel that was on the shelf at the time put on it. Some had a Prototipo, some had a fat rimmed rim, some (like my mechanic's) had a thin rimmed steering wheel. Of the Porsche wheels, the correct wheels all had a thick flat steel center like the one on your pictures, not the later model that had a thin stamped sheet as a center. The collapsible hub also had losange openings, not the late VW stamped hubs with round openings. The RSR wheel legend comes from some unscrupulous sellers (thieves?)who charged obscene amounts for 911S wheels that happened to be fat rimmed, by pretending they were genuine RSR wheels off a car.... |
Zombie
They made a 380mm and a 400mm ?
As far as I know there has never been a 400mm version of the 3-spoke type steering wheel.
Zombie
The nearest i can tell the 74/79 911s baring a 3.0 carrera and a turbo had 400mm. The 80/83 sc had a 380mm but it was a cheaper wheel. I found some pics of a rsr that had a wheel similar to mine.
80/83 SC wheel ![]() RSR Wheel ![]() |
nice doggie
Well you could make a reasonable facsimile by taking off the back and adding a metal platye to the front. Who would know? Probably what the factory did.
Jerry 78 SC hotrod 02 Mini Cooper S |
Hey I think I made an RSR wheel. Only I used Alu.
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
