#29 SCWDP (muhaahhh!!)
Gene Wilkes's Avatar
Porsche Crest Repair? or Replace?
I'm starting to see some oil weeping from my oil tank. Would you repair it or replace it?
IslandmanFL
SOLD...78 911SC (ROW) cabriolet/widebody
hear BEBE purr!!
92 325is
Now living in Sunny West Palm Beach FL!
Old 08-30-2006, 02:35 PM
charleskieffner's Avatar
KOOL KATZ would replace it with one from low miles wreck at 20thstautoparts.com. no rust here and wayy cheaper than new juan! thereby saving big bucks to feed KOOL KATZ KAVIAR!
Old 08-30-2006, 02:42 PM
The real issue with used oil tanks is the condensation starts the rust from the inside. Very common in low mileage older cars.
IslandmanFL
hear BEBE purr!!
92 325is
Old 08-30-2006, 02:51 PM
what about vatting one out just like a radiator???????
Old 08-30-2006, 03:15 PM
i'm hoping someone will respond that maybe has had good results repairing or otherwise!
PS: Katz LUV friskies!
IslandmanFL
hear BEBE purr!!
92 325is
Old 08-30-2006, 03:27 PM
zotman72's Avatar
I had mine in my '72 (the rare tank) repaired by brazing. It was less than $120 for the work. YMMV
Bill
'72 911T-2.4S MFI Vintage Racer(heart out), '80 911SC Weissach,'95.5 S6 Avant Wunderwagen & 2005 997 C2S new ride.
Old 08-30-2006, 03:31 PM
How long has it been and hows the repair holding up?
IslandmanFL
hear BEBE purr!!
92 325is
Old 08-30-2006, 04:07 PM
zotman72's Avatar
It has been two years and the patch is still holding.
Bill
Old 08-30-2006, 04:50 PM
Mine started leaking, upon dis-assembly it was susted out in multiple area's. I found a good used one for replacement.
harry
1974 911 2.7L coupe with sunroof
Old 08-30-2006, 04:57 PM
I had a leaky one as well. Ordered a used one from EASY. Garden hose with water, gasoline, then 1/2 quart of oil rinse while getting everything out that might be inside.
Repaint outside - working very well..less than $200 if I remember correctly.
Curt
Old 08-30-2006, 05:09 PM
I did mine two years before I took the car off ther oad and when I took the tank lout ast fall to check it was still dry.
83 SC
Old 08-30-2006, 10:03 PM
mjw mjw is offline
I had my 1973 oil tank cleaned, repaired and tested at a local radiator shop three years ago, no problems. It's not pretty, but I haven't had to look at it since stuffing it back into the rear fender.
Marty
'73 911T 2.4 MFI
Old 08-31-2006, 11:46 AM
Grady Clay's Avatar
If you have the choice, replace it with new.
That may sound extravagant to many here but consider the consequences.
Our wonderful dry-sump 911s do not have oil filter protection from any debris in the oil tank (like rust particles). Every piece of crud is delivered to your main bearings, rod bearings, piston squirters, cam lubrication and more. Is this what you want?
The only “safe” early 911 engines are ones with the 906 and later screen filter in place of the engine mounted oil cooler. Those are usually only Factory race cars.
This is only one reason why I would like to see someone produce an engine mounted replacement oil tank like the GT3.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 08-31-2006, 12:11 PM
