Carbon Emitter
I 'd like to see a picture of the special tool the hood strut installer gets to use at the Porsche factory.
Friend of Warren
Try working on the back of the dash on an MGB. At the factory they install all the wires and gauges for the dash while it is out of the car and then weld the dash in place! No access through the fire wall. You have to reach up behind the dash in a contortionist fashing to do anything.
Kurt V No more Porsches, but a revolving number of motorcycles. |
cycling has-been
73 911T MFI, 76 912E, 77 Turbo Carrera |
Michel
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses. |
I've installed the hood struts twice now, once on my SC and once on my 3.2. If I were to do it again now, as it needs, I'd feel like Lewis and Clarke going back to do another journey of discovery.
All time hardest job was changing the rear wheel bearings. Least favorite is repacking CV joints. Imagine the shmuck who had that job at the factory!! Makes wiring the defroster look like a job for wimps. |
Replacing the speedometer cable on my '72 was the worst... so far.
'72 911T '73 MGB (sold) '71 Alfa GTV (sold) |
Clutch pedal spring - YIKES!
I nearly shot my top row of teeth out...
78 SC Coupe Silver 79 SC Coupe GP White - sold |
Tom 88 Targa - Mostly stock except cat bypass, SW Chip. 06 Audi A4 2.0t Quattro 02 Saab 9-3, 06 VW Passat, 06 Chevy Cobalt |
Gon fix it with me hammer
4mm door gaps on a 30 year old Targa that's been apart for paint
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Doors, hood shocks, alternator bolts, SWB guages are all good ones but I think the biggest PITA is... aligning door window frames. I dont mean just bolting them in but getting them perfect! There are a million adjustment possibilities and I think I could build a whole 911 in the time it takes to get that damn door to shut correctly once the window frames are in!!!
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
I've done the alternator twice. It's nothing like my Chevy truck...
Hood shocks twice also. Used long needle nose pliers while rocking lid up/down with my head after supporting lid in open position with piece of wood. Lots of light help also. Least I forget ... removing front caliper bolts AFTER mechanic tighten them to 100 ft-lbs AND removing the tie-rods when turbo tie-rod instructions FAILED to mention loosening locking plate to rack/pinion steering. |
