Engine Identification ? ? ?
I recently purchased a 1975 911 3.0.
But when removing alternator last week I discovered that it had the later Bosch unit with a built in voltage regulator. So I assumed it was an upgraded alternator on an older engine. But then this weekend I went about changing the oil and discovered that the engine had no sump screen, it just had a bung to the left hand side of case. I believe this is a change porsche made quite some time after 1975. Does anybody know what year and engine size this is. The case number is 930 101 104 5R and the fan casing is 930 106 667 4R. Thanks Niall
1975 911 3.0 Carrera (964 Lookalike Weekender) 1975 911 2.7 (Project) 1979 Ford RS2000 1980 Mini 1275GT 1998 BMW 320i (Daily driver/Reliable Work Horse) |
Best way I know is to look on the right side of the Alternator stand - you may need a torch and you should see something like 930/??. I have a '74 with a '78 ROW 3.0 and it has a 930/03 type engine. Once you know that type number then you can work out what you have.
1974 Carrera Track Car - 3.0 Webers Headers and Flowmaster. 915 with Wevo Shifter, Tarrett 22mm ARB's, Elephant Racing Polybronze Bushings and Monoballs |
Just checked, their does not seem to be any numbers here.
antaircooled
Does your motor have the sump screen and same fan casing numbers?
Definitely has the sump screen - where do you get the fan casing numbers from?
On top of the casing when you look directly down on the casing from above, beside the strap.
Those numbers in your first post are casting/part numbers. The engine number is to the right if the fan and is on the side (vertical plave) and the engine type number is on the flat just right of the fan housing. Search here for engine number location and you should find some pictures of exactly where to look.
Post both numbers and you will be told exactly what you have, assuming no engine mods were made from original.
Tony G 2000 Boxster S |
Result.
I found those numbers! The engine serial number is *6660175* and the Type number is 930/20 Now can anybody tell me what they actually mean?
TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
Racer
Looks like it's time to change your signature...nice little surprise you got there.
Preston Brown Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn) 1965 356 C Coupe | 2010 F250 (support vehicle) Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera |
Hey its like all my birthdays have come at once.
The guy selling the car knew zero about 911's (a little less than me at the time, but i'm learning fast). He told me it was 3.0 he had taken in on trade in. I got it cheap, because it was running like crap, he just wanted it gone as he figured it needed a lot of engine work from the running condition. I knew after a few miles it was only broken down HT leads. So I bought it, took it home, changed leads, plugs, filter, oil etc and its now sweet as a nut. This porsche is seriously growing on me. I must post some pictures soon. By the way, I assumed as I was told by seller that it was a 3.0L 1975 and bought plugs, leads etc for that model and fitted them. Is there a difference between the 3.0L 75 gear and the 3.2L 84 to 86 gear? Do I need to get different plugs?
super old thread I just came across but you sure you are not dyslexic? should be a 930/02 with that serial number
