Blower Motor Upgrade Kit
Has anyone tried this yet? Or even better has anyone figured out a short cut? How about a disassemble view?
ScottB chime in here....
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
hey bill, can you post a link? Where did you find that?
Here is the Link to RetroAir: http://www.retroair.com/
BTW, the "Click To Enlarge" buttons in the above picts don't work - LOL
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint Last edited by brcorp; 07-11-2007 at 12:31 PM.. |
Throw it on the ground!
Bill, this won't work on a 1987. Box cover and motor mounting changed in 1986. I talked with Rock (owner of Retroair) about this during last year's sweaty season!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Tired Member
Re: Blower Motor Upgrade Kit
But it will work on a '78. So....
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
I am not unhappy about the volume of air CFM that comes through the vent, I just with it could be about 20 degrees colder. This after installing a new drier and converting to 134a (it was just air before, now it is cool air). The little resistor knob? Seems to have zero effect on the temperature.
Black 1985 Carrera ~ Whale Tail - Gone but not forgotten 2013 Boxster - Wifey Car 1969 Karmann Ghia - Next in line for restoration "Driving in its most beautiful form" |
I know Griffiths sells a variable speed fan control that doesn't limit you to three speeds, and I think it will work on the later model cars. I haven't seen any other products to increase the fan motor size or speed for the later model cars, however. You might give Charlie Griffiths or Ron Maxwell at Rennaire a call and see what they have to say about increasing the motor size. Also, several people (Jim Sims, Hugh R., and others) have installed a muffin fan over the resister pack in the passenger floorboard. Apparently the extra airflow into the evaporator helps with cooling. HTH Scott
1984 Targa |
jeffrey, the knob controls the frequency of the compressor clutch engagement. I found that the best ac cooling occurs on even freeway cruising at about 70mph because the compressor is spinning at about 2500 rpm and the motor is not throwing out much heat.
I wonder if you have dirty evaporator fins? I get 42F vent temps on a 80-85F dergree day. |
Re: Re: Blower Motor Upgrade Kit
http://forums.pelicanparts.com/showthread.php?threadid=336402&highlight=evap+assist+fan
Tired Member
Detached Member
I just went to a computer surplus place and bought three 12V muffin fans (DC of course) and screwed them into the front of the evaporator inlet behind the passenger floor board. My car didn't have A/C from the factory, so my ventilation system is very different. The A/C was an aftermarket add on, which I converted to R-134a. BTW the fans cost about $2 each. Here's a pic. Also, I don't have the bowtie thingie and the only intake to the evaporator box is the one you see. I think other 911s with factory air have another intake for the A/C. BTW. I get A/C air from my top, center and underdash vents, I think most of our vintage 911s get it from the center vents only. I also don't get squat for air velocity from the vents.
Hugh |
Thanks for the responses.
Let me restate my question. I want more velocity/cfm out of my vents, this will come at the expense of some cooling as the air will spend less time at the evaporator but I'm guessing it will be a trade off as the more air will be hitting me in the face. So is there an an existing motor / squirrel cage that would fit with some modifications? BTW, ScottB how's that additional condenser?
Tired Member
Bill,
It seems to me that these inlet fans would increase the throughput of your system and are a relatively easy modification.
The latest mod being considered is to install a rear fenderwell condenser in front of the left rear wheel, away from the exhaust system. If I ever have to do work on my system and have the R12 evacuated, I think that's the next step I'm going to take. Scott
1984 Targa |
I have the Kuel variable speed fan controller on my '89 3.2 - I was trying to both improve the velocity and also be able to better control the fan noise. The product works well for both.
Regards, David.
1997 Carrera 993 coupe - Slate Grey Metallic / Classic Grey 1989 Carrera 3.2L coupe - departed - Stone Grey Metallic / Silk Grey |
David: Was the installation of the variable speed control difficult?
1984 Targa |
![]() Scott
1984 Targa |
http://www.unwiredtools.com/utboost.html
Careful with these guys. Customer service is terrible, oh, and the product doesn't work as advertised. Save your money
Jon |
1984 Targa |
