Spraying the Blade ??
I have started to try clean up my engine now and im wondering if anybody here could point me in the right direction on spray painting the cooling blade ??
Or is it a bad idea ??? |
You might try a search. There are pages on polishing, powder coating, cleaning and painting the blades.
Painting doesn't seem to last that long. The magnesium doesn't seem to like paint. |
Have it powder coated and be done
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
I painted mine with corrosion inhibitor to try to get a stock look (I just snapped this pic this evening - my car needs a wash).
Friend of Warren
I spray painted mine with K-Mart Krylon 15,000 miles ago and it still looks just fine.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I found someone to powder coat it, would it be wise to get the engine tin-ware coated also ?? ?
ok so its ok to do the 4 covers & the tin - ware, then i could cut the coating off the "PORSCHE" writing....!!!
Depending on your driving environment will have a lot to do with weather paint would last. Powder coat is definitly longer lasting. if you get the blade coated, you may need to cut the coating off the blade ends, I've heard of people that the fan scrapped with the think coating on the end. especially if you do the housing as well. Make sure it turns without scrapping anyting before final assemply.
John Snodgrass 1973 Porsche 911 "Barney" (race car for sale) 2008 Nissan Maxima - Daily Driver 1999 F350 Diesel Crew Cab - Tow Beast 1990 Airstream 36' Land Yacht - Home Away From Home |
You can do the manifolds too
This one isn't mine.
I rattle caned mine in '98. The leading edges of each blade accumulate dirt. Other than that, it's still fine.
![]() Sherwood |
The fan may be worth powder coating (I did mine), but I'm confident that painting the engine tin would have been fine. It wasn't worth the extra $300 or so I spent on the tin.
For a rattle can job that looks great, and 10 years later.
What rattle can did you use and hopefully Cali hasn't made them change the formula. Dave |
Powder Coated
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
I plan to go the electroless nickel plating route for both the fan & shroud.
Check out: http://www.magplate.com
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
Looks great by the way.
The paint wasn't anything special, Krylon from the hardware store. It's probably more important to clean and prep the base metal thoroughly. The center metal hub was masked off. I think 3-4 coats were applied. Sherwood |
