View Poll Results: Is there a really good decriptive repair manual for the 911. l
No! Support your local mechanic! 0 0%
Buddy it is black and white stop reading the gray! 4 57.14%
Yes but it never covers tricks to the trade. 3 42.86%
Yes there is let me send you a link 0 0%
Multiple Choice Poll. Voters: 7. This poll is closed
Question Can not seperate Alternator fan from Housing
I followed the tutorial and it says to just tap the bolts lightly to get the housing to separate from the alternator. I am afraid if I tap the bolts any harder I will flatten the threads. I did remove the nuts from the bolts. I can not find any additional documentation. Does anyone have any tricks or tips on how to get these two separated?
I have tried the Technical article below
http://www.pelican parts.com/tech articles/911_alt_replace/911_alt_replace.htm
I have also tried the suggestion in, "101 things to do with your 911"
I need a way to get the two apart without breaking anything
Old 02-01-2009, 11:18 AM
any tutorial that says to beat on the bolts is to be ignored. fold several rags to use as a cushion and lay them on the floor, or get a chunk of wood and do the same. hold the unit in both hands, fan facing down, and knock the edge of the housing firmly on the rags/wood. turn 180° and repeat until it falls out.
206 637 4071
Old 02-01-2009, 11:48 AM
Paul K's Avatar
FWIW, I dropped mine onto a couple of 2x4's setting on a towel and it came right out. Also, welcome to the forum- please add your location to your profile so we can better help you.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 02-01-2009, 11:52 AM
+1 What John said. It seems so simple to get it out once it is "knocked loose."
Of course 98% of the time, John's advice should be followed. The other 2% is for the process that have two perfectly good way to do the same thing.
Old 02-01-2009, 11:55 AM
Put a couple of nuts on the bolts before you beat on them to protect the treads.
John
997 C2S 2005 "Slate grey"(special order 1965color)
911 SC 1978 Silver/black 34.000 miles from new!
911 2.2 S 1971 Albert Blue/Black and 911 2.2 T 1971 Tangerine/Blood Orange/Black
Sold: 911 2.4 S 1973 Viper Green/Kelly Green; 993 C4S 1996 Black/black; 993 C4 1994 Black/Black; 996 C4 2000 Black/Black; 996 Turbo 2003 Silver/Black
Old 02-01-2009, 01:29 PM
Shaun @ Tru6's Avatar
Just did this yesterday with JWW method. worked perfectly.
Tru6 Restoration & Design
Old 02-01-2009, 01:36 PM
safe's Avatar
You see? The workshop manual is right here!
Magnus
Old 02-01-2009, 02:15 PM
I'm trying to break my fan assembly down and having very poor luck. As far as the upside down tapping method I think I could throw mine off a cliff and it'd stay together. I left the housing on the wood blocks after some spirited dropping and took a drift around the alternator as close to the edge as the housing will allow but it still hasn't budged.
Just to be sure - all that is required to remove the alternator from the housing is to remove the 6 nuts from the studs that protrude through the Fan housing, correct? I suppose I should just hit it harder but I think I'm on the verge of hitting it hard enough to cause damage as it is.
1989 Carrera 3.2L in 993 bodywork
Old 03-24-2009, 02:15 PM
Of all the ways, I prefer the 2, 2x4s and drop the housing on them..But you should pull the fan first.
Bruce
Old 03-24-2009, 02:47 PM
I've had the same frustrating experience… Was also at the point of worrying about damaging something so I decided to end the effort and consult an expert. I put the unit in the back of my SUV and took it by a friends shop at lunch the next day. I went in the shop and explained my dilemma… got the unit and my 2x4's out of the car, (it was very hot late July - Aug in NC) and the 1st bump the thing fell apart... so this type of heating works well!
83 911SC
70 911T
Old 03-24-2009, 03:04 PM
Senior Member
Superman's Avatar
Twice I have failed to follow John Walker's advice and it was a mistake each time.
Mocha 1978 911SC. "Coco"
Old 03-24-2009, 04:04 PM
steely's Avatar
+1 for the John Walker method (thank you JW).
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 03-24-2009, 04:07 PM
I used some PB Blaster on it before I came in and wrote the reply. I went out and got creative with a 2-Jaw puller and a pry bar to remove the fan and then got progress almost immediately when I started tapping the housing. Either removing the fan made a big difference or the penetraiting oil did; not sure which.
Old 03-24-2009, 06:17 PM
sudo apt-get purge 930
equality72521's Avatar
That's the way I did it and it worked great.
--clutch-monkey
Old 03-24-2009, 06:29 PM
+1 on the JW method, I bent my bolts banging on them before I heard about it, didn't get it out that way, AND it cost me some money on the core charge for refurbishment. Regardless of what some people may tell you, as long as the housing and alt are original, it is NOT a press fit, it's just tight and sometimes gets stuck, but be patient and it'll come out.
1987 911 Carrera Targa
2007 Audi A3 2.0T DSG
Old 03-24-2009, 07:16 PM
Band.
PO of my alternator DID not follow the JW method, and one of the studs is gummed up and will not take a nut.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 03-24-2009, 08:00 PM
Assuming they are so bad you can't start chasing them typically you can take a file starting further back on the stud/bolt where you have good threads and work your way out. If it's bent, straighten it first. Most threads can be saved in just a minute or two. Theres so much extra stud on these you could just clip the damged end off, more than likely.
Old 03-24-2009, 08:27 PM
JW's method works like a charm!
But how do you separate the fan from the alternator's shaft, looks like a pretty difficult job and I just sprayed penetrating fluid and wait for miracle.
'87 3.2 Targa
Old 04-26-2009, 08:03 AM
I threaded 2 holes on the fan, screwed in 2 long bolts, and used a puller. That worked.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-26-2009, 08:21 AM
Tags
alternator , fan housing , how to , repair fan housing
