Somewhere in the Midwest
Actually, I'll smooth and prep the gelcoat and spray a clear coat on it. All the body panel will be exposed carbon fiber but for the roof.
Wow, somebody plans on losing some serious weight! That's going to look awesome Souk!
Michael Sans Porsche...for now 2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy 2010 Subaru Forester X Limited - wife's daily driver |
loose nut behind wheel
Since the fenders and hood line are higher, I think the front nose does sit on top of the cannels. When mine gets back from the painter I'll get some pics of how they did it since I scraped the fiberglass nose that came with the car and got a new one to put on.
80 911sc/993 GT-2 body/3.6L motor 71 VW Convert (300 hp 2332 FI turbo) 97 Passat TDI 320K miles and counting |
The sincerest form of flattery is copying perfection -
87 911 97 993 prior p-cars: 76 912E 85 targa |
Pictures would be great. The bumper will sit higher even if I channel/cut the flange down...so I wasn't sure without fitting the fenders too. It was getting late last night and my garage time was coming to an end (read...wifey and crying infant waiting at the back door) so I didn't go further.
Got my Getty Design GT2 rear decklid in, decided to cry once after buying a bolt on wing from PP and it came in damaged, PP said they were discontinued and they didn't have another to replace it with, so I bit the bullet and got the built in decklid one from Niel at Getty. So if anyone wants to buy a GT2 bolt on for a 993 that need work I'm open to offers! Black one is Getty.
So with all these 993 conversions I have to ask. How are all of your hood seals done? I still have the original track to put a seal in but the hood is higher at the front with the 993 body work and it rises away from the seal. This and the lack of access-ports for the rear t-bars are the only concerns I have with the body on my car.
1989 Carrera 3.2L in 993 bodywork |
Schleprock
You got it all fitted-up by now, right Souk?
Big weekend ahead- git 'er done!!!
Kevin L '86 Carrera "Larry" |
Mine came with a "L" shaped piece that gets attached to the fender to basically raise the channel that the hood seal sits on, the PO actually didn't have them installed, but included them when I bought the car, so I had my body guy install them, hopefully either this weekend or next I'll be getting the car back and can take a bunch of pics.
cant wait to see the finished product, Kevin
anyone have any updates? Mine is still in getting the new tail fitted and painted.
Does anyone know if the 993 door windows and frames will bolt on to a 80 911 door shell?
Up dates? Cool stuff, Kevin
I got the engine and trans in, fuel system done, 993 oil tank lines done, now I need to finish up the electrical. I did install the 993 door window frames and glass, and ineer and outter scrapers. Since my brother is good at electrical, I'm waiting for his help to finishe the wiring, so in the meantime I'm installing a new headliner. Once the headliner is done I can put the 1/4 windows and front and rear glass in, then start on the interior.
The start... Bringing the 82Sc on the left home....
![]() The fitting of panels, just to check the gaps ![]() Cutting the quarters off done... ![]() ![]() ![]()
Love the kit.... Source?
Howard 2003 996tt 1997 911 Coupe Artic Silver (sold) 1988 Black 911 Coupe (gone but not forgetten) |
you may try mashaw, americaninternationalracing.com b-w getty-design.com , Kevin
That is a Getty Design wide body kit. Call Neil or Mark at Getty.
