For 1965 to 1973, there is the spring and bushing replacement. This thread has interesting discussion: https://forums.pelicanparts.com/porsche-911-technical-forum/1043621-early-911-upper-steering-bushing.html for 1974+ there is the 928 metal sleeve or the alternative bushing. https://www.pelicanparts.com/More_Info/RENI69.htm?pn=REN-I69&bt=Y&fs=0&SVSVSI=789
My car is 1985. Any installation instructions in the forum? Is it required the use grease or other lubricant?
Thanks 1985 911 Carrera 3.2 euro specs. |
i think mitch sold idea to rennline?
Yes - that is correct.
I purchased / installed one recently (purchased here on Pelican)... https://www.pelicanparts.com/More_Info/RENI69.htm?pn=REN-I69&bt=Y&fs=0&SVSVSI=815 |
the Rennline isnt a 100% replica of Mitches? Ironman..how dod the install go..same process and mitche's?
1986 Bosch Icon Wipers coupe. |
I recently installed the Rennline steering wheel bushing and am pleased with the results. I’d add 2 points to the above-posted video. First, before removing the steering wheel, make a mark using chalk or the alike across the steering wheel and column, to show you the proper placement of the steering wheel on the spline upon reinstalling. Second, when tapping in the bushing, I used a pvc fitting from Home Depot and a rubber mallet which evenly distributed the force around the bushing.
1984 911 Carrera 3.2 Targa |
Thanks!
84 911 Cab 87 911 Targa 88 930 Cab M505 Slant Nose 62 356B Gone
A short piece of 1" PVC does the trick here...
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
