How important is a G50 Transmission in a 3.2 911
I am deciding between an '87 and '86 911 that are the same price. The '86 has less miles and is in very slightly better condition. With all things equal, how important is the G50 transmission in the '87?
Slumlord
Haven't you driven them both?
In terms of driving experience you should be able to determine that by comparing the two cars. Most, but not all, prefer a G50. I certainly do. In terms of reliability the G50 is better, but the 915 is no slouch. And the 915 is fairly easy to fix. In terms of resale value? The G50 is going to hold it's value better, but it is not going to be a huge difference. Drive both cars, buy the one you like the 'feel' of.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
AutoBahned
The G50 detracts from the true sports car nature of the car*
* which is to make driving as difficult as possible so that only the skilled who are willing to compromise features, luxury,, and ease of use will be able to drive it. Extensive discussion a few weeks ago if you search. |
Recreational User
I'd go with the '86 because of mileage and condition. Which tranny it has would be a minor point.
The G50 is more expensive to fix, more expensive to replace (if you ever need to), about 25 lbs. heavier, and has a 9:31 final drive ratio compared to the '86 915's 8:31. But, it's generally a little smoother shifting than the 915. Like Porsche Monkey said, you really won't know unless you drive them both. But even then, a fair comparison can only be made if both transmissions, clutches and shift linkages are in good working order. Many 915 shift linkages are not (a condition which is easy to fix). |
I've driven both, and except for the shift pattern, I can't tell the difference. Buy whatever car is in better shape.
Howard 2003 996tt 1997 911 Coupe Artic Silver (sold) 1988 Black 911 Coupe (gone but not forgetten) |
Would anyone say that the 911 turbo should have a weaker 915 transmission to make it a true sports car? Now when i test drove a few Boxsters, I really disliked that transmission since it kind of felt like a toyota..;-) I like my 3.2, l like my G50, and I like having a cab. To each their own I guess.
Luis "once was - Wickd89" Carrera 3.2 - "Faster, Stronger, Better" -- 2008 Toyota Camry SE V6 (mine) -- 2005 Toyota Sienna (hers) -- 1989 911 Carrera Cabriolet -SOLD |
I has in the same position a few years ago.
Found a nice 86 and then drove a few 88 and 89. G50 was my choice and I love it... Excellence mag would agree overall.
one of gods prototypes
i have driven both, my 915 was tired so i always thought the g50 felt better.......
then i had my 915 rebuilt and changed my mind...... imo a perfect shifting 915 adds a visceral feel to a 911, although the g50 is a very nice transmission it doesn't have the same personality
Brought to you by Carl's Jr. |
Turbonut
3.2 got G50 in 87 and Turbo didn't have G50 until 89 model year, the final year. And to be correct, 930 gearbox is NOT 915, but in fact, 930. It's different inside and most parts are not directly usable between two. And besides, 930 gearbox is much stronger than 915.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet http://www.facebook.com/vemsporsche |
The G50 is more robust and seems to last longer in terms of maintaining shifting bliss. There was a recent thread on how no one posts about rebuilding g50s; partly because they are newer, partly becasause it is not straightforward. When both are newly rebuilt (and the 915 with a few upgrades) I would take either. The G50 is more modern and consistent (even when cold) which is important to me. Porsche changed for a reason.
1988 Carrera Coupe |
Got a -84 with the 915 and a -87 with a G50.
I would say that they are very equal.. I personally prefer the 915 over the G50. The clutch for the 915 is lighter and the shifting with a good 915 transmission is great. The trick is to not shift up until you hit about 4000revs. The gearbox is a bit heavy and hard to get into 2 gear at low revs but the more you rev the easier it gets! The hard part is not to grind the gears shifting from 5-4 when it is easy to hit reverse. The G50 is smooth all across the rev range and is possibly a little better if you are using the car as a daily driver. Just my thoughts! //Patrick Hansson
Track day car: 911 3.2 915 Black 1984 Daily driver: 911 3.2 G50 Blue metallic 1987 Winter car: Volvo XC90 2003 |
AutoBahned
not weaker -- harder to use
what you want in a sports car is maximum difficulty and extreme compromise with luxury, comfort, etc. keeps away the Lexus drivers |
My understanding is a little different. Porsche Turbo had G50.1 for a few years. In 87, a G50.2 version was used on the 3.2 Carrera, and then (maybe 89), the turbo got a newer G50 version than those. Anyone else with more details.
No, the 930 didn't get the G50 tansmission until 1989. The Carrera 3.2 got the first one in 1987.
JR |
Have owned both and much prefer the G-50 -- every wrench I have asked only had to rebuild 915's. Even more importantly, 911 Carreras from 1987 onwards had improved hydraulic clutch, 14 more HP, halogen headlights rather than sealed beams, and electric oil cooler fan.
Agree; that's why I'd pick the lower milage 86 I also prefer crank-start over an electric starter. I think the electric starter is a huge diservice to driver-car bonding.
-Todd '82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs. Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete |
I'd buy the car that is in better condition, regardless of the transmission.
JR |
Javadog is right. YMMV.
Black Widow Blk on Blk '86 911 "...the secret to Porsche: we do things others cannot" |
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
1984-911 M491
Replace all these bits and your 915 will be fine.
1984-911 TLC......SOLD |
