Are my plug wires shot? Ohm readings...
In trying to track down ignition problems on my '67S, I measured the resistance of my plug wires.
#1 = 1.256k #2 = 1.267k #3 = 1.012k #4 = 1.041k #5 = 1.057k #6 = 1.024k I'm finding various answers about the readings I should get. How do the above numbers look to the Pelican experts? Thanks.
David 1967 S |
To clarify, I measured resistance with the plug connectors still attached.
David 1967 S |
I find it very odd that they are all that low. You should be seeing close to 4 for each wire. I could see one or two with low numbers, but not all of them, I guess unless they are all really old. Have you checked your multi-meter against a resistor to check it's accuracy? The leads on multi-meters have a finite life.
EDIT: oh wait, 67's I have no idea about those wires, ignore me.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Actually, your advice may be spot on. My multimeter does act a bit weird at times.
David 1967 S |
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
What are the symptoms? What makes you think they're ignition-related?
Sherwood |
Resistance tells you nothing about the insulation which is what keeps them from shorting out.
Those look about right for a copper core wire with a 1k resistor in the connector. What is your ignition problem? Is it missing? Is it cutting out?
If you have a wire that is shorting out you will get a miss. Unless it's the wire from the coil then it could cut out. If you don't have a miss then the problem is not with the spark plug wires. -Andy
72 Carrera RS replica, Spec 911 racer |
