Dyno numbers for stock 3.0, 3.2, 3.6
I'm playing with weights trying to see where my and a couple other's cars fit into the NASA GTS formulation. I haven't had a chance to Dyno mine so I wonder if anyone has run theirs recently. A friend just did his 3.2 (chipped/headers/open exhaust) and got 210HP/185 TQ . How does that compare to stock?
Gary R. |
Gary, stock 3.6 with 3.2 heat exchangers M&K sport exhaust from a 95' 993:
255RWHP/249TQ Dyno'd at Auto Associates in Canton, Ct. Boy those Alton Fuchs are nice aren't they??
O2 In Sully We Believe |
Thanks Mark, and yeah I am really enjoying the hell out of mine.....
Gary R. |
82 3.0 SC, PMO 40s, SSI, = 179 RWHP 183 ft lbs
joe ------------------ '69 911 E Targa - aka "RoxiE" |
One thing to keep in mind that not all dyno's will return the same results all else equal. A competent operator, identical conditions and the same dyno should give a good comparison, but altitude, humidity, ambient temps all play into the equation.
1976 911S Targa, Carrera bodywork, 3.2l engine. |
I wasn't clear but I would like numbers from stock cars, i.e SC's from 78-83 (non-euro), Euro SC's, 84-89 3.2 Carerra's, 90-94 964's, and 95-98 993's for a general comparison. Thanks!
Gary R. Last edited by GaryR; 10-12-2009 at 06:46 PM.. |
Hmmm, the unfair advantage? Dyno shops in Denver???
![]() Seriously, I don't know how they're accounting for all the varaiables. Maybe NASA has a data base that they're using???
Lots of dyno plots at ww.911chips.com.
My 3.2 w cat delete and chip at 215-217 rwhp. Sounds like the keys to being competitive is going to be the motor with the widest power band, best gears, & weight to tire size. |
88 3.2 with: cat delete, muffler delete, K&N drop in, Steve Wong chip.....
228whp and 200tq http://forums.pelicanparts.com/porsche-911-technical-forum/467938-dyno-whp-tread.html
1988 Porsche 911 3.2 (cat delete, K&N drop in filter, chip) |
After spending 30something hours on the dyno, same car, same dyno, varying atmospheric conditions I saw peak numbers ranging from 198-238RWHP on a dyna-pak.
A dyno is a tuning tool, numbers will vary, this is a proven fact. Every day I would do a baseline on a stock tune and work from there. Gains measured from that baseline, that day, and had absolutely no bearing or correlation on the numbers from the other days. That's just how it is. |
The numbers will depend on which brand of dyno you use. After dyno tuning hundreds of 911s on machines such as Mustangs, Dyna-packs, Dyno Dynamics, Superflow, Land&Sea, Dynojets, the most consistent numbers come from Dynojets, close enough that the same car dyno'd on one in Los Angeles will be within 3-4 hp SAE corrected of one in South Carolina. There's no operator alterable factors that can fudge, either accidentally or intentionally the HP and torque numbers, why many racing organizations use Dynojet numbers to classify cars. Given the same state of tune and chip program, I typically get hp and torque curves within 1-2 hp of each other between runs, even on different days. A 40 hp spread from a dyno is horrible resolution!!
The 210 rwhp numbers you quote sounds like a Dynojet number for a 3.2 and if so, is not bad for headers and an open exhaust on pump gas - 217-221 would be better. Well tuned 3.6s with headers and a racing exhaust typically come in between 250-263 rwhp SAE on a Dynojet. Divide the above rwhp numbers by 0.89 or 0.88 to get the approximate engine HP as Porsche would rate it. |
Bill, I belive it computes it based on rpm and roller speed.
Here is one for a 3.2, Steve Wong chip (about 8 years ago AFAIK), B&B headers, open exhaust. Weird drop around 5K, what could cause that?
Gary R. |
Not sure on that drop, but it could be from an sudden AFR change right at 5200 - would have to see the AFR chart to determine that. However the drop is so abrupt, and continues quite smoothly, it appears almost as if the full throttle microswitch is not activating, or possibly on edge so that right at 5200, the shift in the engine under load is just enough for the linkage to change the engagement of it, having the tune go to part throttle. |
I chose the dyna-pack because it takes the wheels out of the equation, and they actually tend to give the most realistic and consistent numbers of any of the other makes I've ever dealt with. I can cause any roller based machine to change output by changing the tire pressure. An operator or anyone else can also use the winpep software to display the run in many ways, and manipulate many variables. Dynojets tend to read higher than other dynos, just as Mustand dynos do. In fact, the Mustang dyno has a 'dynojet' setting to emulate a dynojet, and it will indeed yield a higher output number. While a good dyno will indeed do proper SAE correction if told to, that doesn't negate the fact that the car does not produce the same power and have the same volumetric efficiency on a 45 degree low humidity day as it does in 90 degrees with 80% humidity. I don't think anyone will argue that. Regards, Russell |
Bland
a 964 with driver could well weigh close to 3700 lbs. my 90 c4 targa weighs 3300 lbs without driver.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
In 2005 my stock 1982 US 3.0 measured:
155 WHP --> 180 hp at the crank (assuming 14% driveline loss) . The window sticker says 172 hp. 164 ft-lb at the wheel = 191 ft-lbs at the crank.
Mike '82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar. |
+1
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
