9x16" wheels on a Carrera
Will this:
Fit on a 1974 with Carrera-flares ??? Or will I have to go with 8x16" instead ?
Regards, Heine Hansen http://www.carnut.dk/us - http://www.policecar.dk http://www.youtube.com/user/danishcarnut 1963 Mercury Marauder - 1974 Porsche 911 2.7 1961 Porsche Speedster "Replica" - 1971 Plymouth Fury - Walnut Creek P.D. |
Can't see what offset these wheels have but it is my understanding that the original 9" "sticks out" just as much as the 8". The extra inch is added to the inside so to speak. In other words I'd assume a 9" would fit if you can fit an 8". Someone else pls correct me if I'm wrong.
Can see that it is Sierra Madre Collection that advertise these wheels. Admittedly I have only bought from them once. Fortunately the good I bought was cheap, since what I received was junk. Their response when confronted was a little disheartening; QUOTE Yes you are right, the horn button you purchased was very cheap in price and it's quality. UNQUOTE Why one would knowingly offer junk is beyond me.
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold Last edited by H-viken; 12-26-2009 at 03:01 AM.. |
The offset is 15mm. Think the original 8" is 10.5mm
Only bought from them once, and it was okey. Bought a Bursch muffler.... But don't know if their wheels are okey ? Maybe someone here has an answer to that ??
They sell the same brand, Euromeister, Fuchs replica that our host sells.
Check out the prices on Pelican before you buy here
'82 911 SC |
Then you should be fine. 911 Wheel Weights
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
ET 15 is the correct o/s for 9" wheels to be used w/ rear SC/Carrera flares. There is actually some flexibility w/ this as the ET can go a bit lower and still fit.
Still, ET15 9" is what I would want on my car.
just me
how does putting 9's on the back affect handling compared to 8's? if you have 7 x 16's in front with 205 55's?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
zugelassener benutzer
I have run both and unless you are doing track events, or have some giant hp motor, the tire you choose will probably make more of a difference in actual feel while driving than the extra width. It sure as hell looks more badass.
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing 7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo 32C #7 |
for max performance you will always want to use a wheel at the wide end of design spec. for a given tire
just me
so an optimized tire for a 9 inch rim would be? a 245? will that be too much tire compared to a 205 front and cause understeer? would a 215 sit well on a 7 inch rim?
Driver
Instead people think along the lines of: I can go with a 9" wide wheel, so should I go for a 235 or a 275? (Assuming both tire widths will fit under your fenders). Disadvantages of a wider tire: weight, cost, and possibly heavier feel to steering.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa Last edited by Noah930; 12-26-2009 at 08:26 AM.. |
16x7 fronts = 205/55
16x9 rears = 245/45 this are the size tires/fuchs wheels I run on my '74 carrera |
just remember to think through want you want when it's done(they're never really done but do think about what you want and how irt will be used) front fit is increasingly difficult as the wheel and tire width and height increase. 205/55 on a stock ET23.3 Fuch is already a tight fit on a lowered car. You can go wider w/ increased ET(up to around 31mm) up to 245 but each incremental increase is exponentially harder to achieve, 225/45 on 8ET28 +/-3 w/ 245/45 on 9 ET 15 +5 is a really good set up
Yes, the 9" Fuchs do look bada$$.
Mike |
Danishcarnut,
Just to emphasize, the ebay auction you linked to is for "FAKE" fuchs. Other than the "fuchs" name, they have little if anything in common with the original brand wheels. Also, you would likely want to purchase the 7" version of the FAKE fuchs so that the front/rear wheels match.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
In that case I'll need the fronts too, as You mention. In fact I don't really know if the ones I have on the car now, is original Fuchs or not ???
I have 9x16 Fuchs'on my Carrera 3.0 and the only problem that I have had was clearance between my tyres and the aircon tubes under the right rear fender. Too wide a tyre rubbed against them during track days.
Richard.
Life is not a journey to the grave with a pretty and well preserved body but to skid in sideways, used and worn out saying " What a trip! |
Northern Motorhead
I'm presently using nine inch Fuchs replicas along with 245/45/16 tires on the rear of my 89 narrow body Coupe with no issues whatsoever.If you can find a good set of 951 offset eight inch rims for the front you will have the ultimate set up as far as 16 inch wheels go !
As far as having replicas on your car,for street use there is no problem,just don't use them for track days ... Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
86 Carrera Cabriolet
Is it ok to put 225/50/16 tires on the 9' wheels for the rear and 205/50/16 on the front?
Also, is it ok to use the Euromeister 9' wheels on track days? If no, why & what is the limit when not on the track? Are these wheels for looks only? Thanks for your input. |
you can use 205/50 front and 225/50 rear on 6 & 6, 6 & 7, 7 & 7, 7 & 8 or even 8 & 8 if you choose. I'd use 7 & 8 myself you can also use 205/50(or 55) & 245/45 x16 on 6 or 7 front and 9 rear You can use them but do monitor them carefully, even the much stronger oem Fuchs will eventually crack and fail, a less robust wheel will just fail sooner. The issue is delayed by using street radials and not R radials
