-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Waterlogged Rust Bucket (http://forums.pelicanparts.com/showthread.php?t=519605)
merbesfield 06-10-2016 05:57 AM
Brian, how do you like that gear shifter? Looks like a Wevo? Beautiful car.
sf911 06-10-2016 08:59 AM
Brian , all I can say is WOW ! I have been following your build since you sold me the ducktail in 2010 and I couldn't wait to read updates as the build progressed . You must be proud of how it is now , compared with what you had to start with . I hope that one day I will see it in person .
Congratulations !! From one Single Malt Guy to another .
Scott .
blee 06-10-2016 09:18 AM
Hi Scott - I remember your black Carrera with the cool ducktail;) Very nice. We're practically neighbors - I too hope we get to meet someday, cruise, talk cars and maybe even enjoy some tasty beverage. Cheers!
merbesfield - it is a WEVO. Takes some getting used to and have had to make lots of adjustments to get it right, but she's like butter now. No slop or flopping around. Stiff & precise. I'm liking it.
blee 03-19-2018 07:47 PM
Still at it!!!
http://forums.pelicanparts.com/uploa...1521513887.jpg
Link to the muffler project: https://forums.pelicanparts.com/porsche-911-technical-forum/963985-sport-muffler-v2-0-a.html
blee 03-19-2018 07:52 PM
More new pics ;)
A place they used to call Experience Music Project
http://forums.pelicanparts.com/uploa...1521514106.jpg
Road trip with hooligans
Stonehenge Washington
blee 03-19-2018 08:01 PM
Swapped the diff with a new ZF LSD unit.
http://forums.pelicanparts.com/uploa...1521514764.jpg
al lkosmal 03-20-2018 09:09 AM
nice work and pix, Brian.
blee 04-27-2018 10:52 PM
Bringing the original 2-litre motor back to life...
http://forums.pelicanparts.com/uploa...1524893327.jpg
blee 04-28-2018 02:32 PM
http://forums.pelicanparts.com/uploa...1524950447.jpg
blee 04-28-2018 03:22 PM
http://forums.pelicanparts.com/uploa...1524953991.jpg
blee 04-29-2018 10:00 AM
http://forums.pelicanparts.com/uploa...1525019956.jpg
http://forums.pelicanparts.com/uploa...1525021045.jpg
RSBob 04-29-2018 07:51 PM
Brian, you are truly a wizard. Amazing work on many levels, but watch out on the company you keep. Consorting with hooligans will certainly lead to no good.
ADDvanced 04-30-2018 08:26 AM
Just read this entire thread, amazing transformation.
I have a question about the rust repair; many of these areas show corrosion up 'behind' the metal; in the corners you replaced the metal, but isn't there still rust INSIDE the pillar, just above that? Did you sandblast up into the pillars to treat this? Prior to paint, it looked like the car was 100% rust free, I am just wondering how you treated the rust that wasn't on the exterior, and was instead hiding in the inner panels.
blee 04-30-2018 02:00 PM
Good question - the thought crossed my mind too. Short of dunking the whole car in a solution bath, I don't think blasting would address hidden rust either. I used everything I could think of that would delay the inevitable(?) - Por15, Silver Bullet, epoxy primer, rust converter, etc. You have to remember that whatever coating you apply on the underside will melt or burn during the welding process, which defeats the purpose. Weld-through primers work to a certain extent and I liberally brushed on rust converter in the many hard to reach places, like inside the torsion bar tube. Used an angled brush attached to a long broom stick for example.
I figure I did what I could to the best of my ability and if there is anything lurking underneath, it will take many, many years before it rears it's ugly self. When & if that happens, either I address it or the new caretaker will have to get intimate with the car. As you know, these cars are "always in progress" anyway. I'm hoping I'm good for at least 20-years?
Cheers!
blee 04-30-2018 08:18 PM
http://forums.pelicanparts.com/uploa...1525144163.jpg
blee 05-10-2018 08:02 PM
http://forums.pelicanparts.com/uploa...1526006593.jpg
lvporschepilot 05-11-2018 04:52 AM
That should go just fine! Those cast iron liners will be fine too, way over debated subject.
blee 05-12-2018 12:19 PM
Thought the motor was a factory replacement case with no serial number stamp - turns out, its a '70 914-6 motor! #6404534.
http://forums.pelicanparts.com/uploa...1526152663.jpg
http://forums.pelicanparts.com/uploa...1526152322.jpg
blee 05-12-2018 12:27 PM
http://forums.pelicanparts.com/uploa...1526152925.jpg
kalinsd 05-12-2018 01:02 PM
See that the cylinder tin mod was done to this engine. Came this way to you or did you do the mods?
Have really enjoyed your thread.
Thank you.
