WOW! I don't know if I'd have time, money or ambition for a project like that!
My car had no rust and still broke me with upgrades and repairs!http://forums.pelicanparts.com/uploa...1267458502.jpg |
I was right there with you too.....my rear parcel shelf was nothing but fiberglass bondo. Such a mess but now replaced and all is right in my porsches world!
:D |
Tip closer and check the Argon flow - got it! Thanks Gary. The metal is so thin, I'm afraid I'll blow holes if I get too close or stay on the trigger. I need to practice on some scrap pieces before moving forward.
Subscribed, I have a 1970T with similar issues, they are a labor of love.
It looks like you got your hands full, good luck! |
So much for the first weld - it was rubbish I tell you! Found a bunch of pinholes after applying primer. Had to go back and re-weld until all the pinholes were gone. Turning the power down on the welder helped too.
http://forums.pelicanparts.com/uploa...1268799056.jpg http://forums.pelicanparts.com/uploa...1268799081.jpg It doesn't look like I'll have to cut the rain chanel on the driver's side? http://forums.pelicanparts.com/uploa...1268799360.jpg And, as expected, found more rust and fiberglass in both rockers. :o Doesn't look too bad though, I might be able to get away with patches instead of replacing the whole thing. (it seems for now anyway) The journey continues... http://forums.pelicanparts.com/uploa...1268799803.jpg |
Really curious about how you're gonna solve that issue with the rockers. Our '67 has the same issue right now
The inners look nasty too. Spotweld cutter and new outers/inners..... I have sets waiting to go into my car too. My car looked pretty good.... till I ground like 1/2" of bondo off the rockers, and could see the inners :p
Careful with cutting too much at once. I know it seems like an oxymoron, but the rsuty panels still lend some rigidity to the body. Cut too much out and you'll wish you'd welded in a body jig. Take it slow, replace one piece at a time, ensuring one repair doesn't get in the way of the next.
Good work man...you sure do take on a project with gusto. Anyhow, the local guys are here to help, if needed. Just ask.:) |
I was thinking that your Porsche was either parked next to your Pacific Ocean for awhile, or it's from the Salt Capital, Detroit!
Hey , Brian
It looks like you've got your work cut out for you for the next year or so ! I've just finished mine , Your Duck Tail turned out great , I'll post some pics this weekend ! |
Thanks for the support and kind words gentlemen. I was just about to throw in the towel...just kidding;)
While we're here, does anyone know what this is: http://forums.pelicanparts.com/uploa...1268924744.jpg Is it factory or another patch attempt? I've seen rectangular stampings in this location on other cars but never saw it in "bare metal" form. It's very soft metal, I can move it around - aluminum? What's the purpose? Aren't there issues with dissimilar metals being in contact for long periods? I know it was a definite "no no" with Boeing aircrafts developing corrosion. |
Looks like lead. Probably an unfamiliar sight on a Boeing, but a great factory filler on cars!
It's lead; you'll find it on joints all over the car. I heat it up and coax it into a glass jar. If you have plans on attacking the a pillars at the cowl then you'll really get some experience with it.
What is a good alternative for its use then? I abhor body filler. Leave the gaps untouched?
:cool:
http://forums.pelicanparts.com/uploa...1269302624.jpg |
Mich Matt- Replacewith more lead. It's calming to work with and gives great results. Just watch out for signs of mercurial madness. (kidding, do the normal H&S recommendations for lead HAZMAT)
There is a good synthetic lead mimic aroud that is applied the same way- blowtorch etc. Can't remember the name but I've use it with reasonably good results. The real deal is much better though, just be careful. Now, where is my hat? lol. |
I've seen "plumbers solder" used for the same thing.
You know the big thick bars of solder plumbers use for sealing gutters. If you know someone who works/worked in the telecommunications field they may be able to put you in touch with a linesman. They make gas tight seals in cable with solder... These guys are good. Anyway I watched one of these techs re-lead a friends ancient Austin Healy. Just plumbers solder, a gas torch and a swipe of leather. He made it look easy. |
| All times are GMT -8. The time now is 12:19 AM. |
