-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Waterlogged Rust Bucket (http://forums.pelicanparts.com/showthread.php?t=519605)
merbesfield 05-26-2010 06:28 PM
Take it slow and steady. You are doing a great job. Practice welding and work on the settings for your particular welder with regards to welding sheet metal. Once you dial it in, you will notice a big improvement. Be sure to mark the settings on your Mig so you do not have to do it again if they get bumped.
GaryR 05-26-2010 07:44 PM
The nasty thing about welding rusted/ground off sheet metal is sometimes it's just so thin you burn through (even on initial spark) on even the lowest setting of some MIG's. Never tried it but I suppose using a VERY thin wire and a low setting might work..
blee 05-27-2010 03:07 PM
You got that right brother. Like welding friggin tin-foil, even at the lowest settings! Then there's the grinding - it's gotta be at least two-hundred times harder than steel. :rolleyes:
carslutt 05-27-2010 04:29 PM
neat project
combatic 08-20-2010 01:53 PM
Hey Brian! SmileWavy
We need more progress pix! It has been what, 3 months since the last round? This is Bryan from last week. I was picking up my permits for the shop :D
Check out the garage progress so far (link in my signature).
Let's keep in touch. I want to see what else you have done to date. No doubt you are getting good at welding? If no one has mentioned this, on the thin stuff you might try a sheet of brass as a backer to help prevent blow outs. Steel doesn't like to stick to the brass so you can congregate your puddle and keep it in place for a sec'. I have yet to try it after reading it somewhere but I have been wanting to see how well it works after personally dealing with 'Tin Foil Blowout' syndrome on other cars I have welded on.
B
Jagshund 08-20-2010 03:39 PM
If you plan on replacing lead with lead, make sure you wash it down right before applying paint to it. Just had a talk about this with a guy who does high end jobs in Atlanta.
blee 08-22-2010 09:05 PM
Hey Bryan -
Your new garage is going to be a killer man-cave! I take it the foundation is probably poured by now? And by the way, thanks alot for resurrecting this post man! I'm almost embarrassed how little I've done this summer.
The welding is improving, mainly because I think I finally have the settings on the welder dialed-in. Here are some updates:
http://forums.pelicanparts.com/uploa...1282535080.jpg
http://forums.pelicanparts.com/uploa...1282535144.jpg
http://forums.pelicanparts.com/uploa...1282535179.jpg
This part has been a royal pain in the ass:
http://forums.pelicanparts.com/uploa...1282535411.jpg
http://forums.pelicanparts.com/uploa...1282535467.jpg
http://forums.pelicanparts.com/uploa...1282535529.jpg
After days of welding and grinding, welding and grinding, I finally had all the pinholes covered:
http://forums.pelicanparts.com/uploa...1282535565.jpg
blee 08-22-2010 09:15 PM
Then I decided it wasn't good enough, so I started over with a different approach...
http://forums.pelicanparts.com/uploa...1282535935.jpg
http://forums.pelicanparts.com/uploa...1282536001.jpg
http://forums.pelicanparts.com/uploa...1282536043.jpg
http://forums.pelicanparts.com/uploa...1282536077.jpg
http://forums.pelicanparts.com/uploa...1282536103.jpg
http://forums.pelicanparts.com/uploa...1282536127.jpg
Definitely like this route much better. Hopefully, I'll have it buttoned-down in a couple of "months" and then move over to address the rockers :eek::
http://forums.pelicanparts.com/uploa...1282536676.jpg
merbesfield 08-23-2010 06:41 AM
It is definitely easier to remove more of the rusty metal and go back to clean areas and straight lines than it is to try to fill in little spots. Looks great.
JerryL 08-23-2010 07:16 AM
What size wire are you using?? I like .023" tends to have less burn through and wets out better on the gauge of metal we are working with. You may have to buy an additional drive roller or flip one around to use the flat insted of the groove on one side depending on the make of the machine.
And as one of the guys in the shop says trying to teach new guys, " if it dont sound like frying bacon on high, it aint right"!!
Keep up the good work
Regards
combatic 08-23-2010 10:25 AM
Brian,
The pix look great! We will have to swap welding notes sometime...errr...you can tell me how to do it right..heh.
I am certainly close by so if you need a hand or get stuck without a certain tool or something give me a shout!
I want to see this project of yours once I get my current project under control =)
combatic 08-23-2010 10:28 AM
Regards
I should paint, "..if it don't sound like frying bacon on high, it aint right!!" on our welder here at work... :D
Great quote and good advice! Thanks
blee 08-23-2010 01:33 PM
Regards
I've heard that before. I'm using .030" - is there really that much difference between the two? If so, I'll go pick up a roll of .023 tonight! Fryin up the bacon.;)
Zeke 08-23-2010 02:32 PM
Yeah, smaller wire on sheet metal. You have chosen some tough areas to weld. When you can't get the gas nozzle down within a 1/2" of the work, your stick out may be too much. For the good bacon sound, get in close with the torch.
Speaking of torches, you should have a small oxy/fuel set up. When you get done grinding and find those pin holes, braze them. You could lead them too, but it takes a lot of cleaning and tinning before you can flow the solder. Brazing need to be on clean metal too, but a stainless steel wire brush will get it pretty much there.
A spot sand blaster is very handy as well for this kind of work.
You're doing an excellent job. Look for DarrylD 's posts and his web site for some really good tips on this work. He did a marvelous 912 project and documented it all.
Zeke 08-23-2010 02:34 PM
Heeeeere's Darryl: DarrylsGarage.com - Car Restorations by Darryl Deppe
Rich Lambert 01-24-2011 10:15 AM
Done yet?
I was reading about the guy who cleaned out his garage so he could work on his Carrera backdate project and thought, hey, we haven't heard from Brian in a long time!
blee 01-25-2011 07:51 AM
Not even close dude. Moved on to the suspension pan. Guess what I discovered? Yup, more RUST. Lateral tank supports are history and there is rust behind it on the inner fenderwells too. Shweet. :cool:
combatic 04-21-2011 02:38 PM
Brian?! I see you are buying parts from the Pelican classifieds! You must be making some progress. What are the latest updates?
I finally have a car and as soon as the shop sheet rock is mudded/sanded and painted I am moving in!
blee 04-21-2011 04:28 PM
Yup, trying to gather parts whenever I find them. Sounds like you'll be jumping on the "slippery slope" soon too. A 69T huh? Congrats. What's the story? I'll have to come over & take a look.
Funny that you should post on this thread now - I was just thinking how long I haven't posted...feeling a little guilty. I'll have to get back into it.
blee 09-09-2011 08:46 PM
Finally, some updates...
Skipped the rockers and stayed on the front-end:
http://forums.pelicanparts.com/uploa...1315626148.jpg
http://forums.pelicanparts.com/uploa...1315626323.jpg
http://forums.pelicanparts.com/uploa...1315626354.jpg
http://forums.pelicanparts.com/uploa...1315626383.jpg
