-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Waterlogged Rust Bucket (http://forums.pelicanparts.com/showthread.php?t=519605)
blee 09-09-2011 08:54 PM
The suspension pan came out without too much drama:
http://forums.pelicanparts.com/uploa...1315626612.jpg
http://forums.pelicanparts.com/uploa...1315626654.jpg
http://forums.pelicanparts.com/uploa...1315626717.jpg
http://forums.pelicanparts.com/uploa...1315626803.jpg
blee 09-09-2011 09:06 PM
Lots of patching and fabricating...
http://forums.pelicanparts.com/uploa...1315627076.jpg
http://forums.pelicanparts.com/uploa...1315627151.jpg
http://forums.pelicanparts.com/uploa...1315627225.jpg
http://forums.pelicanparts.com/uploa...1315627275.jpg
http://forums.pelicanparts.com/uploa...1315627350.jpg
http://forums.pelicanparts.com/uploa...1315627470.jpg
blee 09-09-2011 09:34 PM
There were signs the car had incurred some front-end damage in it's past. Thought really hard about replacing the whole front clip, but ultimately decided to save as much as I could. The nose seal strip, on the other hand, had too many holes and wrinkles so it came out.
http://forums.pelicanparts.com/uploa...1315628707.jpg
http://forums.pelicanparts.com/uploa...1315628626.jpg
http://forums.pelicanparts.com/uploa...1315628759.jpg
That's when I discovered how much of the damage was "not" repaired...
http://forums.pelicanparts.com/uploa...1315628942.jpg
http://forums.pelicanparts.com/uploa...1315628989.jpg
The nose was pushed in more than 1 1/2 inches in the middle - there was no way the hood was going to latch in that position.
blee 09-09-2011 09:51 PM
This called for drastic measures... the mighty hydraulic fluid, arrghh! arrghh! arrghh!
http://forums.pelicanparts.com/uploa...1315629711.jpg
http://forums.pelicanparts.com/uploa...1315629750.jpg
... and beating on it with a 20 lb. mallet: much better.
http://forums.pelicanparts.com/uploa...1315629778.jpg
blee 09-09-2011 10:06 PM
Tank support in, passenger-side battery box removed, multiple coats of etching primer, rust encapsulator, "Rust Bullet", seam sealer, and Wurth undercoating. She's not going to rust anytime soon.
http://forums.pelicanparts.com/uploa...1315630913.jpg
http://forums.pelicanparts.com/uploa...1315630965.jpg
http://forums.pelicanparts.com/uploa...1315631003.jpg
http://forums.pelicanparts.com/uploa...1315631032.jpg
kenikh 09-09-2011 11:03 PM
He lives - was just talking about your project the other day, hoping you hadn't given up. Great progress. Have you seen Bryan's (combatic) identical pan repalcement last week? Two Br(i/y)ans, same neighborhood, same project, same week...what are the chances?
ant7 09-10-2011 05:56 AM
hi Brian,
realy great work, [Hard work] looking forward to seeing the progress as it happens, should be a neat car when your done!:)
Anthony.
scottb 09-10-2011 08:03 AM
Subscribing. Nice work!!
Rich Lambert 09-10-2011 01:47 PM
Great work Brian!
Are you coming down to Kirkland tomorrow?
CT Mike 09-10-2011 02:22 PM
Great going. Keep it up!
blee 09-11-2011 09:02 PM
Thanks for all the encouragements. I wanted to install a new bracket I fabbed to replace the fender mount that got deleted with the battery box... In order to locate it correctly, I need the fender and bumper back on, but of course, it's never that easy. Both headlight buckets were "repaired(?)" with fiberglass, requiring more drilling, pounding, & welding.
http://forums.pelicanparts.com/uploa...1315799240.jpg
http://forums.pelicanparts.com/uploa...1315799208.jpg
http://forums.pelicanparts.com/uploa...1315799503.jpg
http://forums.pelicanparts.com/uploa...1315799404.jpg
http://forums.pelicanparts.com/uploa...1315799589.jpg
It'll require some additional massaging, but it sure beats creating from scratch. Had I known the rust was beyond the buckets, I would not have been so brutal in removing the donor buckets. Created more work than necessary. :(
blee 03-14-2013 09:28 PM
Still here...
It's been a looooong 16-months since my last post, but I did manage to make a little progress. Reached a few milestones actually. I'll try to bring you up to date: first the fenders. The passenger-side headlight bucket just required a little more massaging, but the driver-side was a basket case. I decided to just cut-off the lower turn signal area and graft it onto a '74 fender. Thanks to Johnny Walker for the fender.
http://forums.pelicanparts.com/uploa...1363321468.jpghttp://forums.pelicanparts.com/uploa...1363321610.jpg
http://forums.pelicanparts.com/uploa...1363321626.jpg
http://forums.pelicanparts.com/uploa...1363321649.jpg
blee 03-15-2013 06:31 AM
http://forums.pelicanparts.com/uploa...1363353726.jpg
As you can see, the big milestone came when the shell was stripped, cleaned, and epoxy coated.
http://forums.pelicanparts.com/uploa...1363353871.jpg
http://forums.pelicanparts.com/uploa...1363353890.jpg
http://forums.pelicanparts.com/uploa...1363353914.jpg
http://forums.pelicanparts.com/uploa...1363353930.jpg
http://forums.pelicanparts.com/uploa...1363353969.jpg
http://forums.pelicanparts.com/uploa...1363353986.jpg
http://forums.pelicanparts.com/uploa...1363354000.jpg
http://forums.pelicanparts.com/uploa...1363354017.jpg
http://forums.pelicanparts.com/uploa...1363354060.jpg
blee 03-15-2013 06:42 AM
Passenger-side rocker:
http://forums.pelicanparts.com/uploa...1363354468.jpg
http://forums.pelicanparts.com/uploa...1363354506.jpg
Uh-oh. Didn't anticipate messing with the door hinge post.
http://forums.pelicanparts.com/uploa...1363354546.jpg
http://forums.pelicanparts.com/uploa...1363354561.jpg
Dug deeper.
http://forums.pelicanparts.com/uploa...1363354600.jpg
http://forums.pelicanparts.com/uploa...1363354617.jpg
Be mindful of this shelf hidden behind the hinge post panel - good thing I was taking my time cutting.
http://forums.pelicanparts.com/uploa...1363354651.jpg
http://forums.pelicanparts.com/uploa...1363354743.jpg
http://forums.pelicanparts.com/uploa...1363354760.jpg
Rich Lambert 03-15-2013 06:50 AM
Brian, I was wondering if you'd given up. It looks like you're getting pretty good at rust repairs.
Actually, I was just thinking about you yesterday. Someone offered me a free 1958 Mercedes 300D that's been sitting outside for years and the first thing that came to mind was rust.
blee 03-15-2013 07:57 AM
Still here Rich. I have decided to consider this a "hobby" and not stress myself out by rushing through the process. Plus I really do enjoy the build process. Glad to hear that my name is synonymous with "rust." Thanks bro!
The old Benz are beautiful cars - too funny, just saw a slammed four-door 240 the other day too. Thought for a "second" how cool it would be to build one, then I slapped myself out of it. Don't you still have the Rover to finish?
Rich Lambert 03-15-2013 08:14 AM
Yeah, the LR is first in line. But hey, I'm retiring next week so I'll have lots of time.
blee 03-15-2013 08:21 AM
No friggin way!!! Wow, I had no idea. Congratulations dude! Then hell yah, go snag it. You know what that means:
http://forums.pelicanparts.com/uploa...1363360850.jpg
Rich Lambert 03-15-2013 08:39 AM
It means you're going to buy me some $700 scotch?
SWEET! You can come over and drink some.
blee 03-15-2013 09:02 AM
No, it means your wife is getting that for you and I'll come over to help you drink it.
http://forums.pelicanparts.com/suppo...s/beerchug.gif[img]
