-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Waterlogged Rust Bucket (http://forums.pelicanparts.com/showthread.php?t=519605)
merbesfield 06-10-2016 04:57 AM
Brian, how do you like that gear shifter? Looks like a Wevo? Beautiful car.
sf911 06-10-2016 07:59 AM
Brian , all I can say is WOW ! I have been following your build since you sold me the ducktail in 2010 and I couldn't wait to read updates as the build progressed . You must be proud of how it is now , compared with what you had to start with . I hope that one day I will see it in person .
Congratulations !! From one Single Malt Guy to another .
Scott .
blee 06-10-2016 08:18 AM
Hi Scott - I remember your black Carrera with the cool ducktail;) Very nice. We're practically neighbors - I too hope we get to meet someday, cruise, talk cars and maybe even enjoy some tasty beverage. Cheers!
merbesfield - it is a WEVO. Takes some getting used to and have had to make lots of adjustments to get it right, but she's like butter now. No slop or flopping around. Stiff & precise. I'm liking it.
blee 03-19-2018 06:47 PM
Still at it!!!
http://forums.pelicanparts.com/uploa...1521513887.jpg
Link to the muffler project: https://forums.pelicanparts.com/porsche-911-technical-forum/963985-sport-muffler-v2-0-a.html
blee 03-19-2018 06:52 PM
More new pics ;)
A place they used to call Experience Music Project
http://forums.pelicanparts.com/uploa...1521514106.jpg
Road trip with hooligans
Stonehenge Washington
blee 03-19-2018 07:01 PM
Swapped the diff with a new ZF LSD unit.
http://forums.pelicanparts.com/uploa...1521514764.jpg
al lkosmal 03-20-2018 08:09 AM
nice work and pix, Brian.
blee 04-27-2018 09:52 PM
Bringing the original 2-litre motor back to life...
http://forums.pelicanparts.com/uploa...1524893327.jpg
blee 04-28-2018 01:32 PM
http://forums.pelicanparts.com/uploa...1524950447.jpg
blee 04-28-2018 02:22 PM
http://forums.pelicanparts.com/uploa...1524953991.jpg
blee 04-29-2018 09:00 AM
http://forums.pelicanparts.com/uploa...1525019956.jpg
http://forums.pelicanparts.com/uploa...1525021045.jpg
RSBob 04-29-2018 06:51 PM
Brian, you are truly a wizard. Amazing work on many levels, but watch out on the company you keep. Consorting with hooligans will certainly lead to no good.
ADDvanced 04-30-2018 07:26 AM
Just read this entire thread, amazing transformation.
I have a question about the rust repair; many of these areas show corrosion up 'behind' the metal; in the corners you replaced the metal, but isn't there still rust INSIDE the pillar, just above that? Did you sandblast up into the pillars to treat this? Prior to paint, it looked like the car was 100% rust free, I am just wondering how you treated the rust that wasn't on the exterior, and was instead hiding in the inner panels.
blee 04-30-2018 01:00 PM
Good question - the thought crossed my mind too. Short of dunking the whole car in a solution bath, I don't think blasting would address hidden rust either. I used everything I could think of that would delay the inevitable(?) - Por15, Silver Bullet, epoxy primer, rust converter, etc. You have to remember that whatever coating you apply on the underside will melt or burn during the welding process, which defeats the purpose. Weld-through primers work to a certain extent and I liberally brushed on rust converter in the many hard to reach places, like inside the torsion bar tube. Used an angled brush attached to a long broom stick for example.
I figure I did what I could to the best of my ability and if there is anything lurking underneath, it will take many, many years before it rears it's ugly self. When & if that happens, either I address it or the new caretaker will have to get intimate with the car. As you know, these cars are "always in progress" anyway. I'm hoping I'm good for at least 20-years?
Cheers!
blee 04-30-2018 07:18 PM
http://forums.pelicanparts.com/uploa...1525144163.jpg
blee 05-10-2018 07:02 PM
http://forums.pelicanparts.com/uploa...1526006593.jpg
lvporschepilot 05-11-2018 03:52 AM
That should go just fine! Those cast iron liners will be fine too, way over debated subject.
blee 05-12-2018 11:19 AM
Thought the motor was a factory replacement case with no serial number stamp - turns out, its a '70 914-6 motor! #6404534.
http://forums.pelicanparts.com/uploa...1526152663.jpg
http://forums.pelicanparts.com/uploa...1526152322.jpg
blee 05-12-2018 11:27 AM
http://forums.pelicanparts.com/uploa...1526152925.jpg
kalinsd 05-12-2018 12:02 PM
See that the cylinder tin mod was done to this engine. Came this way to you or did you do the mods?
Have really enjoyed your thread.
Thank you.
blee 05-15-2018 07:16 AM
Yup, snipped the tins myself. I'm hoping that it'll be a cool running, leak free motor - used Henry Schmidt's sealing kit/process.
RSBob 05-15-2018 07:37 AM
You know Brian, if your objective is to make the rest of us look bad, consider it Mission Accomplished. You can stop any time now. ;) or not.
kalinsd 05-15-2018 01:54 PM
Great. Just did mine on our '71T. Installing new drain tubes this week and other components once the tins are blasted/painted.
Hooligans. Do you post here when a drive is planned? Any drives planned for the Olympic Peninsula this year?
Great thread and enjoy seeing your nicely done work, actually, masterful work!
DJ.
blee 05-16-2018 08:57 PM
Thanks DJ.
Haven't made any runs recently to the Olympic Peninsula, but ya never know.
You can check the PNW forum here for announcements re. major events/drives.
Hope we meet up some day. http://forums.pelicanparts.com/support/smileys/wat6.gif
In the meantime, motor is done!
Ready for a trip to the "X-Factory" for a test run.
http://forums.pelicanparts.com/uploa...1526530348.jpg
Trackrash 05-17-2018 07:55 AM
I just read through this thread again. The work and result is simply amazing.
And now the motor..... This is Porsche jewelry.
blee 05-17-2018 12:12 PM
Thanks for the encouragement Gordon!
Trakrat 05-17-2018 01:00 PM
I have a couple of questions...
1.) I'm curious about your method of taking everything apart and keeping it organized?
2.) Did you have any background with welding/metal fabricating before this project?
3.) What would you have done differently now that you can look back at it?
4.) For someone who is looking to do the same... any advice?
5.) And finally... I'm looking at trying to document my project with pictures and updating my post... what method of documenting worked best for you? (ex... did you stop in the middle of a task to upload your pics to here and type it up, then go back? did you take a bunch of pics throughout the day then post it all up at the end of day/week? etc...)
kalinsd 05-17-2018 02:37 PM
Originally Posted by trackrash (Post 10040420)
i just read through this thread again. The work and result is simply amazing.
And now the motor..... This is porsche jewelry.
+1!
blee 05-22-2018 02:49 PM
Rick,
Here's how I see it - if a person has just "one" Porsche (myself included) then the related projects and maintenance work is not so daunting. Whereas, a person with a stable of Porsches (Ahem!)... I don't see how they do it? Now, that truly is a feat! http://forums.pelicanparts.com/support/smileys/wat6.gif
You're a rock star.
blee 05-22-2018 03:26 PM
Trackrat -
1) "Everything" gets bagged and labeled - everything! Then the bags go into a box that lists on the outside, which bags are in the box. This way, you can take a quick glance at the boxes and find the part(s) you are after. I can't tell you how many times I've opened the same boxes, over and over, in search of a particular part or fastener. Mark the boxes!
2) Youtube is my friend. Kinda handy in general, but never mig welded or painted a car before.
3) I did what I could under the circumstances. Set-up a canvas carport in my yard to do most of the heavy work. I particularly didn't enjoy patching and fixing the tarps after every wind storm!!! Things might have progressed a little faster if I had a large heated garage, but all in all, no regrets.
4) Think about what your goal is and stick to it. If you're going all-out, don't cut corners on anything. If you don't want to or think you can go all-out, set smaller goals and get them done. You can always do more later. For example, if the car just needs a little work to get it road-worthy, start there and enjoy it for awhile. It was really hard not being able to drive my car for 6-years.
5) It's really easy to be "in the mode" when you're getting things done and want to finish. Have a dedicated camera in the garage, or carport in my case, at all times and remember to take pictures. I took pictures and updated my thread as progress was made. Sometimes, it could be months between posts/updates - life happens. Take pictures before you dismantle, as well as during the resto. They can be great resources to remind you of how things were before you took it all apart, as well as documentation of all your work.
There's my pep-talk. Now, get out there and get 'er done!
P.S. My good friend John Walker once gave me some advice when things were dragging on and my motivation started to wane - he said, "if you can devote just "one hour" a day to working on the car, you will see progress and things will eventually get done." I would recommend spending more on the weekends, but one-hour per day is the mantra. You can do this!
rwest 05-22-2018 04:08 PM
Great work Brian,
Where did you source those nice red plugs for your intake and exhaust ports?
Thanks,
Rutager
blee 05-22-2018 07:58 PM
Originally Posted by rwest (Post 10046684)
Great work Brian,
Thanks,
Rutager
McMaster-Carr has them. It's a little tough getting the right size though as they have them in increments of 1/16" so double check your holes before ordering. And they usually come in packages of 100! Took me several tries to get the right sizes.
If what I have is the size you need, I'd be happy to send you some if you pay for postage. I sure don't need a hunred of'em.
Cheers!
RSBob 05-22-2018 08:08 PM
Brian, exceedingly kind words from a man with more skill I than I can dream of. For me vision and skill are what counts and you have both in spades. It has been a pleasure to follow Your amazing thread. It’s an honor to call you a Porsche brother and am looking forward to seeing your master work.
Now get back to work.
al lkosmal 05-23-2018 07:59 AM
Brian's 911 turned out right....and this engine is turning out right too! Brian's work on these is excellent and shows what can be accomplished by the DIY person...with mad skills and YouTube access..
regards,
al
kalinsd 07-01-2018 12:52 PM
Have missed reading new updates in this great thread! Thank you.
rwest 07-01-2018 01:38 PM
Cheers!
Sorry, I asked the question and didn’t read your follow up until now. Looks like my exhaust are 1.52” and intake 1.37. Let me know if you have any.
kghjr 07-02-2018 08:28 AM
Just saw this. Read the whole thing. What a fantastic build. Beautiful.
rennch 07-02-2018 09:41 AM
I had missed this as well. Just blew most of my morning going through the thread. Great stuff!
al lkosmal 07-05-2018 09:15 PM
it's on fire!!!
Brian stopped by this week to test out his newly rebuilt 914-6 motor. A very sanitary job on the rebuild. ( Note that the carbs were rebuilt by local Zenith expert John Ploeger).
All in all a very nice job was done on this rebuild and the attention to detail was apparent........ After very basic carb balancing /timing/tuning. It is running very well and strong.
I spend most of my time playing with EFI....but sometimes it is cool to get back to the basics. It was a day well spent with good friends...... and here is a video of the results.
Nice work Brian
https://www.youtube.com/watch?v=KmUq2_vUrb4&feature=youtu.be
blee 07-06-2018 04:38 PM
Much thanks to Al & John!
http://forums.pelicanparts.com/uploa...1530923659.jpg
Available for purchase to anyone seeking a nice 914-6 2-liter motor.
