-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Waterlogged Rust Bucket (http://forums.pelicanparts.com/showthread.php?t=519605)
john walker's workshop 06-14-2014 03:22 PM
yeah, special......
Shaun @ Tru6 06-14-2014 04:35 PM
I vote Bahama Yellow, mostly because Signal Yellow is one of my favorite colors. for me, the Chartreuse would be great for a month, then it would get old. It's just too much IMO
blee 06-26-2014 07:52 PM
http://forums.pelicanparts.com/uploa...1403837495.jpg
http://forums.pelicanparts.com/uploa...1403837511.jpg
Rich Lambert 06-26-2014 07:57 PM
Cool!
kenikh 06-26-2014 08:55 PM
Nice booth! Did you shoot it or finally hand your hard work over to someone else? Gotta say, balls out, man.
kenikh 06-26-2014 09:00 PM
Originally Posted by kenikh (Post 7466042)
This is the only reason you considered chartreuse, isn't it?
blee 06-27-2014 10:32 AM
I think that was one of the reasons why I chose not to!! Seriously, Chartreuse is a really cool color and the decision was very tough. Can't tell you how many times I changed my mind.
The booth is at a friend's shop, and no, he refused to shoot it for me. I tried to talk him into it, but he insisted that I would appreciate it more if I finished it. What a royal pain in the ass! Fish eyes, runs, you name it - everything that could have gone wrong did. But, he was kind enough to patiently walk me through on how to mitigate everything, and in the end, after two days of sanding and shooting, it all worked out - beautifully, I might add. :cool:
I still have the body and fenders to do, but I'm almost there! Glasurit is a wonderful thing.
kenikh 06-27-2014 10:35 AM
Your friend did you service. When you're within sight of the finish line, is no time to hand off the baton.
Lapkritis 06-27-2014 10:36 AM
I've been lurking this thread but just now posting to say you're doing a great job. Really enjoy watching it come together.
Shaun @ Tru6 06-30-2014 06:48 AM
Brian, if you have some time and inclination, please post some notes about the painting experience. What you did, what you didn't do, what you wish you had done...
blee 07-08-2014 10:25 PM
Well Shaun, I don't think there was anything I didn't do! Now I see why they charge so dang much for paint jobs. A lot of work goes into painting a car - gobs of hours. Stripping the car to bare metal, inside & out, engine bay, under the front hood, as you can imagine, is very labor intensive. Then you gotta clean, vacuum, blow it out, wipe it down, vacuum, blow it out, wipe it down..., in preparation for epoxy coat. Once the epoxy has been applied you're ready for body work. For me, that's where a lot of time was spent/wasted and the one thing I wish I could have done differently. But, it was a learning curve, and since it wasn't going to get done on it's own, I had to keep at it until it was done. Hammer & dolly is one thing, but the body filler really took me for a curve. I made the mistake of trying to fix "the spot", over and over, instead of covering a wider area with the filler, which is what was required to finally get it right. I can't believe I went through a whole gallon can of filler on the car! Mind you, most of it was sanded off, but the mere fact that I had to re-apply & sand multiple times on the same spot, just killed me.
It felt wonderful when it was finally smoooooooth, but that phase just took too much time. Some things just take longer to learn I guess.
Of course you blow through areas of the epoxy while sanding so you have to re-apply epoxy in those areas, again & again, but I won't go into that.
Then you sand down the whole car, again. Clean, wipe, vacuum, ... Apply two coats of 2K primer. Apply guide coat and wet block sand the whole car, again. Inevitably, there were low spots & highs, so you break out that can of filler & go to town again. Only this time, you have to go easy as to not break through to bare metal. More cleaning, then another coat of 2K primer followed again with guide coat. Wet block sand, and holy ****, it's silky smooooothe & straight! That was/is a good feeling.
Up to that point I did everything in my makeshift carport but used a booth to apply the sealant & paint. Of course there was more sanding because I wasn't used to the different spray gun, air pressure, lighting, nicer environment, and nerves, which caused massive runs, fish eyes, dry spots, and orange peel.
I was really happy to learn, from my buddy who owns the booth, that I wasn't done with "sanding" yet. Apparently, I have to block sand the whole dang car "again" and buff & polish, if I desire that showroom finish. :eek: I do not like this sanding.
kenikh 07-08-2014 10:28 PM
Prep and primer are my favorite part. OCD on top of OCD.
blee 07-09-2014 07:33 AM
Dude, how many sets of S-cams are you going to acquire? Really?
kenikh 07-09-2014 08:00 AM
S cams or Solex cams...my favorites. :)
Need a set? I just horde them, but am happy to let them go to those in need.
blee 09-07-2014 10:15 AM
In production...
http://forums.pelicanparts.com/uploa...1410110041.jpg
Rich Lambert 09-07-2014 11:58 AM
No way! Wow!!!
kenikh 09-07-2014 09:16 PM
Wow is right!
blee 09-07-2014 11:21 PM
It's about time, right?
kenikh 09-08-2014 09:55 AM
I still can't believe where this car started...what a transformation.
axvel 09-08-2014 10:26 AM
wow looks great, from ugly duckling to a perfection with all the workmanship that went in, just wow
