just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
3.2 intake
everybody seems to go on about exhaust and muffler for a 3.2 motronic engine.
how good are things on the intake side?
I know the "cold air" filters are not better, and MAF sensors are expensive for the amount of power they deliver over stock.
what are the possiblities for improving the stock intake?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 02-04-2010, 05:05 PM
Years ago there was a lot of porting and polishing done on them.
What would be done is cutting each side in half, right through the word PORSCHE, then port, polish and weld back together.
I havent seen this done in 15 years but I was out of the loop for several
Bruce
Old 02-04-2010, 05:30 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
The stock intake is as good as it gets. Minimal gains can be had by smoothing the manifold innards, and the MAF would flow better than the barn door, but there's not much there without changing the whole shootin match.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 02-04-2010, 05:31 PM
just me
paulgtr's Avatar
interesting. was there any marked advantage from it? or is the intake pretty well done from the factory?
Old 02-04-2010, 05:32 PM
UFLYICU
ZOA NOM's Avatar
Factory did the best, right down to the airbox cover. Most will make less horsepower with a modified (opend) cover. The choke point on these motors is on the bottom. That's why so many go on and on about exhaust/mufflers/headers, etc.
prc-racing.com
Old 02-04-2010, 05:39 PM
UFLYICU
ZOA NOM's Avatar
There are gains in the fuel maps, and timing, and those are obvious first choices when optimizing these motors. The best changes come with a comprehensive approach to the chip maps and exhaust setup.
prc-racing.com
Old 02-04-2010, 05:43 PM
just me
paulgtr's Avatar
so the next step is the cylinder heads and cams. are there gains there on a stock displacement 3.2?
Old 02-04-2010, 05:46 PM
MBruns for President
JeremyD's Avatar
Lots of answers here
911Chips.com - Porsche Performance Chip Tuning
Old 02-04-2010, 05:49 PM
just me
paulgtr's Avatar
I've read a lot there and have a SW chip. just curious to hear what folks have done on the intake side
Old 02-04-2010, 06:18 PM
JeremyD's Avatar
Usually you extrude hone the intake to even up the flow - minimal increase - especially if you are optimizing. As others have said - Porsche did the top right. Any gains that don't cost cubic dollars are found in the chip and the exhaust.
On the cam front - depends on your delivery
More aggressive and you run out of room with the motronic - so probably something similar to 993 SS cams and you can still maintain and idle. Get more aggressive and you need to switch to PMO's or ITB's. Then of course you need to worry about piston to valve contact so switch out the pistons and cylinders too.
Old 02-04-2010, 07:08 PM
just me
paulgtr's Avatar
it is what I figured. maybe something to look at down the road. juust rebuilt the engine so I have plenty of enjoyment before I need to upgrade anything!
Old 02-04-2010, 07:12 PM
Porsche designed several intakes, including the 3.2, to actually compress air at higher rpm. That means you get more air going into the cylinders than the actual displacement. As for modifying the intake? Move along, nuthin to see here folks.
Old 02-04-2010, 07:23 PM
What about this, I am thinking of buying one:
911 and Porsche World Magazine Visit AmD.
http://www.gekkatec.com/Products.html
Old 02-04-2010, 08:22 PM
UFLYICU
ZOA NOM's Avatar
If you plan to spin the motor beyond the factory stock limiter, you should replace the rod bolts with ARP racing bolts. The Carreras were reduced to 9mm bolts which have seen issues when revved too high.
prc-racing.com
Old 02-04-2010, 08:31 PM
a.k.a. G-man
Geronimo '74's Avatar
About Us
Don't expect too much HP gais with a hot wire system, you'll gain some, but as usual, manufacturer's claims are seldom reached.
Throttle response will improve though.
I have the LB1 kit from FVD, a similar system.
Old 02-04-2010, 10:01 PM
I figured on 10hp over 5000rpm and ftlbs coming in a little earlier form idle. Not much but in the independent tests I have seen that seems to be the result. I will be happy with this.
I need a new AFM anyway so will give this a go for the $500 difference. No matter what I do the present one is reading too lean......
I already have two dyno runs, one stock and one with the SW chip so will post the diference once it gets a little warmer and I can purchase and install this.
So are you happy with the FVD system?
Old 02-07-2010, 07:44 AM
