'89 930
blinker problem
Hi All,
Recently finished up re-installing all lights and now the blinker "relay" is acting up and going "dinker dinker" at all times with the key on. The turn signals all turn on and off and work properly, the hazard works properly, the parking lights and headlights all work properly. Anyone have any idea as to what is going on? I now hear that darn dinker dinker in my sleep. Its driving me crazy.
'89 930 3.4, twin plug, crank fire, K27, cams, B&B I/C, coil overs, EVO '73 911 'ol Yeller - 3.0 ST Clone '74 911 green with NV - 3.6 RSR to be '87 951 Red Vitesse Stage 3r, AOR, Ruf, Motion Control '01 996 ECU flash, 911Tuning exhaust, DV, Techart |
Recreational User
You mean it's clicking but not activating the turn signal lights? That's really odd. Sounds like it's time for a new relay.
'89 930
Exactly, it's clicking all the time, yet when I activate the turn signals or flashers, they work fine. Of course, the clicking continues as it should at that time. Is that a sign of a relay going bad?
try giving the relay a couple of light taps..... sometimes that works....
_____________________ '73 RSR Interpretation ---------------------------------- |
one of gods prototypes
check the rubber plug under the dash opposite the flasher relay, mine did that once when it came a little loose....
Brought to you by Carl's Jr. |
'89 930
Thanks Staygold and Bell. Strange, but it turns out to be a faulty brake warning switch on my recently replaced master cylinder. This is the two plug styler warning switch that is on a new 23mm Master that I up graded for use with the 930 calipers. Didn't realize that could cause a problem, but it seems to make sense....now. Thanks all.
