Mo money = mo parts
Reviving an Optima
My boss is a muscle car guy and sometimes shares his Hot Rod with me. There are often some pretty good general DIY articles. One in the September issue on charging a dead Optima.
I scanned the article to a .pdf, but can't do an attachment in my post. Here's photo from the article that kind of sums it up. Optima recommends that you first hook a good battery in series to the dead one (pos to pos, neg to neg), then hook the good battery to the charger. Hot Rod claims that tried it multiple times successfully. They also claim it work on non-AGM batteries too. It's a 3 page article in the Sept issue, if you are near a magazine stand, you can read it in a few minutes. Thought it was a great tip and wanted to pass along. PS - sorry about the poor photo quality, but think you can still make it out ok.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
AutoBahned
that is in parallel NOT in series
Paul - pwd72S - posted this in OT IIRC but it won't hurt to alert others |
IMHO, if you own an Optima or any AGM you MUST use a battery tender. If you use a battery tender these will last and last. Consumer reports recently rated the Diehard Platinum, Deka and Optima as the top 3 in group 34R which is what we use. Yes. Top 3 are all AGM's. However, Once you allow it to go dead... (i.e. you have not taken care of it...) your probably going to need to replace it. I keep mind on a permanent tender when its not being driven.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. Last edited by brads911sc; 07-26-2010 at 07:50 PM.. |
It was here...here's the link:
http://forums.pelicanparts.com/porsche-911-technical-forum/553744-battery-testing.html Randy, are you already having "senior moments"???
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
My Optima revival technique was to buy an Odyssey.
You can try this though. http://forums.pelicanparts.com/porsche-911-technical-forum/517984-how-recharge-deeply-discharged-optima-battery.html |
I have done the same thing on an Odyssey after leaving the interior light on. It does work. The battery hooked up to the charger alone was not working, by running the second, good battery, it charged fine. It will also hold the charge without issues.
