djcdmv's Avatar
wheel spacers on widebody
I 've searched the threads and have seen some people put too big of spacers on and ended up hitting the tire on the wheel well.
Does anyone know the stud length and widest spacers to get to fill out the fenders of an M491 front and rear with original Fuchs? Thanks in advance.
Dave
Black 1985 911 Carrera M491
Old 09-30-2010, 10:33 AM
MBruns for President
JeremyD's Avatar
What size fuchs? 7's and 8's? How low are you? On a properly set up turbo bodied car (like the m491) you can fit some serious rubber.
Old 09-30-2010, 10:51 AM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
m491s don't use spacers on the rear.....just a 16X9 Fuchs wheel....
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 09-30-2010, 11:01 AM
Stormmaster:
I don't think that is universally correct.....some M491 used 8" rear Fuchs with spacers. I've seen 21 and 32 mm spacers used for 930/M491...and it changed over the years... IIRC.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 09-30-2010, 11:12 AM
My apologies....was speaking from my brothers 89 m491....however from my understanding the difference between the 8 and 9 inch Fuchs is all on the inside depth not the outer depth.
Don Booth
70 911 T Coupe
74 914
Old 09-30-2010, 12:13 PM
Quote...." however from my understanding the difference between the 8 and 9 inch Fuchs is all on the inside depth not the outer depth...."
That's incorrect also....
See this posting ---> my post # 4 within---> http://forums.pelicanparts.com/porsche-911-technical-forum/290040-anyone-have-928-21mm-spacers-911-a.html There, I say ( by verifying records)-->
"... Basically, a 911 8" Fuchs places all of its extra 1" width ( compared to a 7" Fuchs) toward the outside of the car, relative to the original mounting hub. Therefore , when I added a 21mm spacer with my 7" Fuchs.... it was just shy of the 1" ( 25.4mm) extra width that a 8" Fuchs ( w/o spacer) would have done for me. It means I could have gone another 4 mm to "exactly" place the outside edge of the rim like a 8" Fuchs would .
However, you're starting off with a 8" Fuchs. By comparison, a 9" Fuchs ( w/o spacer on the original mounting hub) would place * it's * extra 1" of width the following way... an extra 10 mm toward the outside...and an extra 15mm toward the inside. Not all 25 mm is toward the outside !..."
Wil Ferch
Old 09-30-2010, 12:26 PM
wannabee wannabee
WIL84911's Avatar
Originally Posted by stormmaster View Post
.... from my understanding the difference between the 8 and 9 inch Fuchs is all on the inside depth not the outer depth.
That's what I also thought...
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 09-30-2010, 12:31 PM
You thought wrong....check the backspace and the dimensions....and do the math...or draw it all out on graph paper.
Then there's this...there are 2 different 8" Fuchs. Maybe you're thinking a comparison of 9" Fuchs with 944/951 8" Fuchs.
Wil Ferch
Old 09-30-2010, 12:34 PM
wannabee wannabee
WIL84911's Avatar
OK... thanks for the clarification.
Old 09-30-2010, 12:59 PM
Bill Verburg's Avatar
these were used on a '79 930 w/ 7 & 8" Fuchs
pn#477.501.701 hubcentric 21m
pn# 930.331.611.04 hubcentric 28mm
additionally there is another 21mm spacer pn# 930.331.611.04, one of the 21's is much more expensive than the other so check prices
Bill Verburg
Old 09-30-2010, 01:09 PM
My '89 factory TL came with 9" Fuchs, and huge rear spacers (like 52mm maybe?). I have the m491 on the hood option plate and from what I can tell it (was) all original.
When I changed the wheels to kinesis 17x11's I cut down these rear spacers to about 30mm to just fit the tires inside the wheel wells. 315/35's fit with no rubbing!
HTH,
Chuck.H
'89 TurboLookTarga, 320k miles
Old 09-30-2010, 01:22 PM
I just checked my notes and back to the question of the 2 styles of 8" Fuchs....
911.362.117.00 = 911/930 style and has 10.6 mm offset ( about 112 mm backspace)
951.362.117.00 = 944 Turbo/951 style and has 23.3mm ofset ( about 125 mm backspace)
So....The 951 version of the 8" Fuchs brings the wheel about(12-13 mm) or 1/2" more "in" toward the car compared to the 911 style 8" Fuchs....so NOW compared to a 9" Fuchs...almost all of the extra width comparing 9" to THIS, 951 style 8" Fuchs, is on the outside.
Wil Ferch
Old 09-30-2010, 02:06 PM
HTH,
Chuck.H
The rear spacer on an '89 TL is the 28mm, 930.331.611.04, noted above
Bill Verburg
Old 09-30-2010, 02:07 PM
80-911SC's Avatar
ooooouuuch ........ my head fuch'ing hurts from reading that ....
thanks guys ........ although the info is greatly needed .....
most don't know what fuch they have on ........ but they do look fuch'ing awesome if righ
Old 09-30-2010, 05:28 PM
djcdmv's Avatar
Thanks for the help. I may be an idiot, but I think the rears are 8". The tires are 225/50/16 if that means anything. I'm including pictures for your opinions. I just think the tires front and rear need to be pushed out a bit so they don't look like they are so far inside the wheel well.
Dave
Old 09-30-2010, 06:18 PM
Dave:
Look here for what you will find as to identifying markings on the backside of the wheel....on the spoke area--->
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/564841-fs-one-genuine-fuchs-7-x-16-wheel.html
If you take one of your wheels off...and get the grime off the spokes...you will see 8J x 16 if it's a 8" wide wheel. The part number will tell you if its a 911/930 pattern 8" wheel....or if its a 944/951 pattern 8" wheel which has a different offset and brings the 951 wheel "inboard" (toward the center of the car) another ~ 1/2" compared to the 911 pattern.
I thought the turbos and turbo look cars were fitted with 245/46-16 rears?. Maybe you have 7" rims with the 225's of the narrow body car on your wide-body?
Wil Ferch
Old 09-30-2010, 06:59 PM
JeremyD's Avatar
That's why I asked - earlier turbo look had 7's and 8's later cars had 7's and 9's.
Tough to tell by looking at the difference between the 8's and 9's - most of it comes from the more recessed lug holes.
You can measure the approximate distance from the outside of the tire lip to the inside of the fender lip and then look for spacers of that distance (I did that on my 1987 carrera) amazing how close I could get with a ruler.
Remember too - that tire sizes by manufacturer can also differ. All things to ponder
Old 09-30-2010, 08:45 PM
Thats also why I sent a set of 16X7 Fuchs to TruDesign in Colorado. Turned them into 17X8 and 17X9.5....They fill my wheel wells quite nicely and no spacers of any kind are used...I got to choose the backspacing I wanted.
Don Booth
70 911 T Coupe
74 914
Old 09-30-2010, 11:58 PM
djcdmv's Avatar
How pricey is that?
Dave
Old 10-25-2010, 03:38 PM
TKO TKO is offline
Will F, Bill V, or others:
Did both widebody years (16x8 and 16x9) use the 28mm spacer for the rear? Or, did only the 8's get the spacer? If only the 8's used the spacer, does that mean the outside face of wheel/tire was actually further out then 9's???
Thank you in advance, Merry Christmas!
Tom
IG@tomkearns
'94 WTL 964
Old 12-24-2010, 12:19 PM
