gearhead
Yes, it all swaps over, even the mainshaft. Just update to the later beating at the same time.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 04-14-2020, 06:47 AM
Grand Am/IMSA Data Guy
Porsche84's Avatar
Here is some info I've collected
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 04-14-2020, 07:47 AM
I don't mean to hijack the thread, but my COA says my car came with a 915/61 and the car currently has a 915/63. Besides the fact that it isn't "numbers matching" is there any reason a 915/63 is less or more desirable than the 61?
IG: 911_944
FORMER CARS: 2010 911 C2S, 1984 944, 1974 914 2.0, 1974 914 1.8
CURRENT CARS: 1978 911SC RoW Backdate in Glacier Blue, 1988 US Delivered 944 Celebration Edition in Zermatt Silver, 1981 US Delivered 911SC Chiffon/Chocolate.
Old 04-14-2020, 08:15 AM
Thanks Matt.
Old 04-14-2020, 08:31 AM
Porsche84's Avatar
The /61 early was a Magnesium case (early 77), the later /61 and all /63 were aluminum. It looks like second gear might have been different and the /63 was the first to have a fine spline on the drive hub. I could be wrong on this but that's what I had in my notes.
Jerry Austin
Old 04-14-2020, 08:33 AM
Thanks, my car was built in Aug 77 (78 MY) so it sounds like besides that small 2nd gear difference they are pretty similar.
IG: 911_944
Old 04-14-2020, 08:43 AM
I have a late 915/61 (made in '79) that has the fine spline drive hubs. Like most Porsche changes, there must have been some 'fuzzy' cut offs on what parts to use...
1978 SC Targa
Old 04-14-2020, 08:51 AM
I agree 100%
My early SC has lots of factory 1977 911S parts. I have to be careful when mail ordering parts.
IG: 911_944
Old 04-14-2020, 09:32 AM
kent olsen's Avatar
Bill Verburg
If I understand your chart the 72 915 in my car has 4th gear just short of 1:1 and 5th (0.76) just a little over, interesting. I'm putting a TREMEC 5spd in my 65 Corvette and it is 1:1 in 4th and 0.68 in 5th.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 04-14-2020, 10:14 AM
gearhead
The AL /61 was used for several years in the SC and were fine spline. Only the 77 mag case version was coarse.
1974 914 Bumble Bee
2009 Outback XT
Old 04-14-2020, 10:34 AM
Under the radar
Trackrash's Avatar
I would have guessed that the fine spline drive flanges corresponded with the change from the 7:31 to the 8:31. Porsche changed form the 4 bolt 108mm drive flanges in 75 1/2 which corresponds to the change to the 8:31 FD?
Maybe the experts can confirm. I don't think there were any course flange 100mm CVs?
EDIT: Thanks Matt, you beat me to it.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-14-2020, 11:07 AM
According to PET, the coarse-splined 923 flanges were used in 915 transmissions up through 1979.
The transition occurred either during or after the 79 model year.
See Pete Z's timeline in post 12 here...
http://forums.pelicanparts.com/porsche-911-technical-forum/548265-83-3-0l-engine-trans-swap-85-3-2l-engine-trans-axle-options.html
Jon B.
Vista, CA
Old 04-14-2020, 12:28 PM
Under the radar
Trackrash's Avatar
Good to know. I was told that the 8:31 915s were all fine spline.
So if I ever want to put a 8:31 915 in my '71, I only need to find one '79 or older, and my axles will work.
Gordon
Old 04-14-2020, 12:53 PM
Bill Verburg's Avatar
Originally Posted by kent olsen View Post
Bill Verburg
IN '72 there were 5 different 5 speed 915s, counting the special order as 1 and 2 different 4 speed 915s
All 5spds except the S/O had 29:22 5th
There were numerous detail improvements/changes over the years
here are a few
1972 - Start of production; magnesium case; 7:31 ring and pinion; mechanical speedometer; early style clutch throw out bearing tube.
1973 - Change to input shaft seal design to address service issue flaw.
1974 - Change (final) to input shaft seal design to address service issue flaw. Transmission disassembly no longer required.
1975 - Midyear change from 7:31 to 8:31 ring and pinion
1976 - Change from mechanical to electronic speedometer.
1977 – Start of transition from magnesium to aluminum case. 915/60/61 aux spring on the trans exterior, - Change to 1st and 2nd synchros, split lock before, double lock after, asymmetrically pointed teeth for 1st, smaller syncro ring for 1st stronger guide sleeve 1 & 2
1978 - Reinforced differential side cover (addition of extra ribs), nodular cast iron p/p, cast iron clutch, rubber ctr clutch, All models 5 speed now
1984 - Reduction in diameter of input shaft bearing in differential case.* This significantly helped in the reduction of problems with bearing bore ovaling.
1984 - Addition of oil pump and cooler for 915/67 & 69(RoW), 915/69 uses 930 output flanges
1985 - Improved bearing assembly, input shafts uses cylindrical roller bearing from 930(smaller OD) this was actually introduced 12/16/83 on 915/67 from trans # 915/67 02340 w/ small(100mm) cv flanges, 915/68 02192 small(100mm) joint flanges, 915/69 10081 lrg((108mm) joint flanges, 915/70 10217 large(108mm) joint flanges,
double lock gear syncros for 1 & 2, 3-5 syncros have smoothed and round end syncros(R2.5), lsd modified graphite cast iron case w/ larger holes for fluid flow and fewer disk count, only 1 ea outer and inner (also far less effective than previous lsd versions(sometimes called a 'snow belt' lsd)
all have the large 105mm joint flange
1986 - End of production
Bill Verburg
Old 04-14-2020, 02:48 PM
gearhead
In all these years, I have never once had a customer call me up and tell me I sold them the wrong LSD, and I've sold a lot of LSDs for 78-79 SCs.
1974 914 Bumble Bee
2009 Outback XT
Old 04-14-2020, 07:00 PM
ADDvanced's Avatar
There's a 30lb difference between mag and al cases, so from what I read, the late 76/early 77 magnesium 915s are kind of desirable. You get all the updates but with a 30lb advantage.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 04-15-2020, 06:27 AM
Under the radar
Trackrash's Avatar
Depends if you want an 8:31 or a 7:31 final drive.....
Gordon
Old 04-15-2020, 08:15 AM
ADDvanced's Avatar
Nope. All transmissions from mid 75 onwards were 8:31.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 04-15-2020, 08:21 AM
Under the radar
Trackrash's Avatar
Yes. But some of us want a 7:31 FD. Just sayn' a '72-'74 may be what some, me included, wanted.
Gordon
Old 04-15-2020, 08:25 AM
Does anyone know when the changeover was on the input shaft?
I have an early mag case '77 trans in my car, would that have the strengthened input shaft and improvements to the 1st and 2nd gear sliders ?
Old 04-15-2020, 08:57 AM
