Undocumented User
I'm due for pads and given the consensus in this thread I'm thinking of going with the PFC97. Quick look and it seems our host doesn't sell them and all I'm getting with online searches is fragmented results that don't really list the pads for both front and rear and have a generic Porsche 911 1969-1989 which isn't very comforting to buy.
I haven't tracked my car yet, but it's a possibility, I basically just autocross 6 to 8 events a year. So feel free to chime in if something else would suit me better. Also, anyone have a good source and specific part number for fit? I've got an 86 Carrera, with the steel A caliper, wide. |
Northern Motorhead
I don't think the PFC 97 compound exists anymore ... from what i gather it has been replaced by the 06 and 08 compounds !
You might want to try Apex or OG Racing,they still might have some 97's Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Yes, Wildcat is correct. I would run the 08's but for your application I would choose another pad altogether. The PFC's are not designed for cold operating ranges as you will see in Autocross. Track is a different animal.
I don't autocross so hopefully someone else who does can make a good recommendation for you. Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
Schleprock
PF97 still exist. They're just slowly being phased out. I asked a friend in the parts biz what the deal what and he said PF is just not producing pads for certain sizes any longer. Also said if you order 10 sets, they'll make them up for you!
Agreed the PFC 06 supersedes the 97 and now the PFC08 is superseding the 06. OG racing is a great resource. Suppliers who used to carry both the front pad size (45 pad designation) and rear pad size (31 pad designation) for 76-89 SC/Carrera are not showing the rear pads for a lot of different brands. That's troubling. For autocross I would think something like Hawk HPS would be a good choice. They're a step up from typical street pads and give good cold bit. Although OEM Textar, Jurid brand Porsche pads are VERY good pads. I would think they'd be plenty suitable for autocross. They can withstand road course use, I know that from experience. They don't last long but they still can manage without fading!
Kevin L '86 Carrera "Larry" |
Undocumented User
Thanks for the feedback guys, this place never disappoints.
I have rarely if ever had a fade problem, but my 3.2 is 2500 lbs.
Brakes are stock, lines are stn stl on rears and new oe on front. I would bleed those lines well first, then duct. Could be driving style, i tend to consider the car to the point of being on the slow side..
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels |
Go Speedracer, go!
I had trouble with boiling fluid for my first few DE's. What worked for me was:
Carrera front brakes (thicker rotors) Motul 600 (fresh for each event) Removed rotor baking plates 993 air diverter scoops Experience! I can now get through a weekend without boiling fluid. Now my problem is transferring too much pad material onto the rotors. I'm using Ferodo DS2500 pads, which last about 2 weekends. I think I'm going to switch to PFC next time to see if that helps. Also, I still cook the dust boots on the rear calipers after one to two events.
1981 SC ROW Coupe |
Mike '89 CARRERA #402 |
On the advice of one of the most respected wrenches on the forum, I tried Pagid Oranges on my SC for a couple of events. They were absolutely terrible. When I changed cars and went to the 996, I also went to PFC 97's with ATE fluid. What a completely different experience. No fade and great stopping even at the end of a 30 minute session. Back to ATE Super Blue for a minute. I still have half a liter from when I flushed my brakes less than 60 days ago. How long is it safe to use the rest of that can, assuming the top is on tight and stored properly?
'17 Cayenne Last edited by Halm; 10-14-2012 at 06:22 AM.. Reason: spelling |
Undocumented User
I went with a set of the Hawk HPS Plus pads since the autocross is my primary objective and they seems very street-able pads as well. Anyone know if they're able to accept pad wear sensors and if for the front glue or notch style?
It should be fine to use as top up fluid until you flush it again using ATE Gold before your next event. I think if you have that much fluid remaining in the bottle you might not be getting all the old fluid out. I usually have an inch or two of fluid remaining in the can when I'm done flushing the brakes.
I had the Padig BLACK on my 3.2 and they really rocked on the street and track - very "grippy" - I really liked them but wore out a complete set in less than 1 season - as for the comments of no brake fade on that 2500# car...I didnt fade either - till my "slow car" started being driven faster
![]() upgraded to 964's with Pagid yellow's NOW the real reason for my visit - What are the 993 scoops, what's the part number and who has a picture of them installed !!
Ed M 86' Coupe |
Undocumented User
http://forums.pelicanparts.com/porsche-autocross-track-racing/494992-993-brake-air-deflectors-my-911-not.html |
Northern Motorhead
I think you'd be better off with an AjUsa type of front brake cooling ... i tried the 993 type deflectors and they are really too low for our cars.They're relatively cheap at $16.00 each but i tore off two of them going over speed bumps before i made my own brake cooling system ! Cheers ! Phil
awesome - going to get a set I think!!
Ed M 86' Coupe |
OH crud - AjUSA?
linky?
Ed M 86' Coupe |
Project Addicted
I ran this cooling system when I was doing track days with my 87:
if you know where to get those for less than $400 I would be very interested ---- I just cant swing that much - the 993's scoops are really more my price range -
maybe for christmas - HUNNY, I "need" some ducts!!
Ed M 86' Coupe |
Northern Motorhead
Ed,
Tarret has the cheapest price on those brake cooling kits ... i had to make my own due to my 996TT brakes but they are identical to the AJusa kit,just a little bigger ! It's really quite simple to make your own,if you want some details PM me your email address ! Cheers ! Phil
Spiderman
Also, don't confuse bleed with flush. Flush for me is basically around a quarter of the new can pushed out of each corner. Bleed to some folks is simply going to each wheel and making sure there are no bubbles coming out when they open the valve. ( I witnessed this first hand with a couple of guys at DE's who were troubleshooting issues "losing their brakes. ) I usually finish with just a little left which I carry to the DE and then never use.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
