Member 911 Anonymous
DRACO A5OG's Avatar
PCV 3.2 Does she need it or TEMINATE? How?
Hey Fellas,
How many of you have Capped Off or Terminated the PCV. Pics Please ???
Today my wrench told me if it fails it will mess with the idle, creating a vacuum leak of sorts.
What are your experiences?
Can it be cleaned?
PCV & Rubber Sleeve "baffle" are NLA PAG or PPB so that sucks
Compliment of GH85Carrera:
TIA
'85 Carrera Targa
PCA/POC
Old 06-14-2011, 10:20 PM
DRACO A5OG's Avatar
Oh Crap, FLAPS has it for $9.99
and the Baffle, I can't believe it:
'85 Carrera Targa
PCA/POC
Old 06-14-2011, 10:27 PM
Flat Six
Flat Six's Avatar
Hey DRACO, you have a part number / source for the PCV valve?
TIA
Dale
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 06-15-2011, 09:45 AM
DRACO A5OG's Avatar
PCV AZ# 4298 $9.99
Baffle AZ#5333 $9.99
Special Order to home or store.
'85 Carrera Targa
PCA/POC
Old 06-15-2011, 10:07 AM
Flat Six
Flat Six's Avatar
Originally Posted by DRACO A5OG View Post
PCV AZ# 4298 $9.99
Appreciate it, bro -- thanks.
Dale
Old 06-15-2011, 10:34 AM
DRACO A5OG's Avatar
Just order mine at store in 2 days
'85 Carrera Targa
PCA/POC
Old 06-15-2011, 11:29 AM
Hey that photo looks familiar!
Old 06-15-2011, 12:01 PM
DRACO A5OG's Avatar
Hey Glen, hope you don't mind?
BTW, what did you do with your PCV???
Jim
'85 Carrera Targa
PCA/POC
Old 06-15-2011, 12:02 PM
DRACO A5OG's Avatar
Update: The Baffles will not work, but the PCV looks proper, will install and report
'85 Carrera Targa
PCA/POC
Old 06-16-2011, 08:56 PM
DRACO A5OG's Avatar
Installed, no change.
Next Fuel Pressure Regulator (FPR)
'85 Carrera Targa
PCA/POC
Old 07-27-2011, 09:29 PM
Diss Member
Quicksilver's Avatar
As a rule removing a PVC valve by blocking it off will cause an engine to build up pressure in the crankcase causing it to leak oil like crazy. The layout of the oil system of the 911 motor is a fair bit different from the average wetsump system but I can't see how it could avoid the same problem. If there was any openings that could release the crankcase pressure those openings would also allow dirt into the system.
So either you must have a PVC (which you have found for cheap) or you must have a breather (which would fail emissions).
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 07-28-2011, 05:45 AM
(man/dude)
Jonny042's Avatar
I may be wrong, but thermo swtich on the TB opens the path to that hose only during cold weather.
The two large hoses provide all the pressure relief you need, and the vapors are fed into the intake. The entire crankcase/oil tank is under "semi" vacuum, the vacuum that exists after the AFM, but not full intake vacuum that exists after the throttle plate.
FWIW, mine is blocked off. No ill effects.
Old 07-28-2011, 07:08 AM
E Sully's Avatar
It's to prevent icing on the throttle body in cold temps.
I just capped it off on my 3.2, but I don't drive it in cold weather.
Ed
1973.5 T
Old 07-28-2011, 10:08 AM
DRACO A5OG's Avatar
Do you have a pic of the cap off? SoCal has no icing issues
'85 Carrera Targa
PCA/POC
Old 07-28-2011, 10:14 AM
Northern, CA
Hose Clamps
I don't want to intrude on this post put the picture of the PCV with the hose clamps got me wondering. I've never tried to remove that type of hose clamp. Is there a secret?
It looks like it takes a special crimper to replace with the exact type clamp. Do you just open it with a screw driver or something and replace it with a conventional hose clamp? Thanks.
1989 Carrera Coupe
Old 07-28-2011, 02:27 PM
DRACO A5OG's Avatar
Oh No intrusion Brother.
Yes indeed it uses a special crimper or a Wire Nipper $12.00 at an Hardware store. BUt only to crimp on, it needs to be destroyed if removed to get it off. So I used the nipper to cut it off but used a Standard hose clamp to put the new PCV valve on around the OEM baffle.
'85 Carrera Targa
PCA/POC
Old 07-28-2011, 02:42 PM
Oetiker clamps. Easy to put on. Not easy to re-use.
Pliers are shown as 'manual closing tools' on this page:
Installation Tools Products Clamps and Rings OETIKER International
Old 07-28-2011, 04:24 PM
Thanks for the info I will call a dealer tomorrow.
Old 05-12-2013, 01:29 PM
What is FLAPS?
I need those parts:
PCV AZ# 4298 $9.99
Where do I get them?
SMS
Old 06-05-2013, 12:07 PM
DRACO A5OG's Avatar
FLAPS = friendly local auto parts store
Found it at zone de auto :-D
'85 Carrera Targa
PCA/POC
Old 06-05-2013, 12:24 PM
