Member 911 Anonymous
PCV 3.2 Does she need it or TEMINATE? How?
Hey Fellas,
How many of you have Capped Off or Terminated the PCV. Pics Please ??? Today my wrench told me if it fails it will mess with the idle, creating a vacuum leak of sorts. What are your experiences? Can it be cleaned? PCV & Rubber Sleeve "baffle" are NLA PAG or PPB so that sucks ![]() Compliment of GH85Carrera: ![]() TIA
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 06-14-2011 at 10:34 PM.. |
Oh Crap, FLAPS has it for $9.99
![]() and the Baffle, I can't believe it:
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Flat Six
Hey DRACO, you have a part number / source for the PCV valve?
TIA Dale
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
PCV AZ# 4298 $9.99
Baffle AZ#5333 $9.99 Special Order to home or store.
Flat Six
Appreciate it, bro -- thanks.
Just order mine at store in 2 days
Hey that photo looks familiar!
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Hey Glen, hope you don't mind?
BTW, what did you do with your PCV??? Jim
Update: The Baffles will not work, but the PCV looks proper, will install and report
Installed, no change.
Next Fuel Pressure Regulator (FPR)
Diss Member
As a rule removing a PVC valve by blocking it off will cause an engine to build up pressure in the crankcase causing it to leak oil like crazy. The layout of the oil system of the 911 motor is a fair bit different from the average wetsump system but I can't see how it could avoid the same problem. If there was any openings that could release the crankcase pressure those openings would also allow dirt into the system.
So either you must have a PVC (which you have found for cheap) or you must have a breather (which would fail emissions).
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
(man/dude)
I may be wrong, but thermo swtich on the TB opens the path to that hose only during cold weather.
The two large hoses provide all the pressure relief you need, and the vapors are fed into the intake. The entire crankcase/oil tank is under "semi" vacuum, the vacuum that exists after the AFM, but not full intake vacuum that exists after the throttle plate. FWIW, mine is blocked off. No ill effects. |
It's to prevent icing on the throttle body in cold temps.
I just capped it off on my 3.2, but I don't drive it in cold weather.
Ed 1973.5 T |
Do you have a pic of the cap off? SoCal has no icing issues
Northern, CA
Hose Clamps
I don't want to intrude on this post put the picture of the PCV with the hose clamps got me wondering. I've never tried to remove that type of hose clamp. Is there a secret?
It looks like it takes a special crimper to replace with the exact type clamp. Do you just open it with a screw driver or something and replace it with a conventional hose clamp? Thanks.
1989 Carrera Coupe |
Oh No intrusion Brother.
Yes indeed it uses a special crimper or a Wire Nipper $12.00 at an Hardware store. BUt only to crimp on, it needs to be destroyed if removed to get it off. So I used the nipper to cut it off but used a Standard hose clamp to put the new PCV valve on around the OEM baffle.
Oetiker clamps. Easy to put on. Not easy to re-use.
Pliers are shown as 'manual closing tools' on this page: Installation Tools Products Clamps and Rings OETIKER International
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Thanks for the info I will call a dealer tomorrow.
What is FLAPS?
I need those parts:
PCV AZ# 4298 $9.99 Baffle AZ#5333 $9.99 Where do I get them? SMS |
FLAPS = friendly local auto parts store
Found it at zone de auto :-D
