Young enthusiast
Porsche 911's Avatar
3.2 rapid consumption of motor oil
Had a standard valve adjustment done about a month ago, including a complete oil drainage & fill-up of 11 quarts of 20w-50. At the time, oil level showed slightly overfilled at about 2mm above the upper hash on dipstick.
25 days and 730 miles later, oil level only shows 30% up from lower hash mark. I know a "healthy" engine eats up about a quart every 1000 miles, so I'm pretty certain this amount drop isn't normal.
I constantly peak beneath the engine when the car is parked to check for any signs of oil leak, but have not noticed any puddles or even drops of oil the last couple of months. I'm pretty certain I'm taking measurements correctly - after the engine temp is warmed, car idling on a level surface - so I don't believe that's the issue.
Any ideas for the rapid drop in oil level?
TIA
BULLET
1989 Porsche Carrera 3.2 coupe
Old 07-10-2011, 05:51 PM
RETIRED
Joe Bob's Avatar
Try using Valvoline VR1 RACING 20/50.......if the same consumption, try a straight weight. Otherwise, top end time.
Do you have smoke on decel?
2012 ML350 3.0 Turbo Diesel
Old 07-10-2011, 05:59 PM
mrk_d's Avatar
From what I understand, your oil consumption will be quicker if you fill all the way to the top mark. Maybe try topping off to the halfway mark, and tracking consumption from there?
Mark
1987 Carrera Coupe
http://nvrmndclothing.com/
Old 07-10-2011, 06:02 PM
check the engine after it's warmed up on level ground, and idling for at least a minute.
Old 07-10-2011, 06:03 PM
Porsche-Poor
bcoats's Avatar
could be getting into the intake manifold when over filled, also notice much smoke? Did it smoke before at all?
1979 911 RS clone hotrod
1983 930 turbo-sold, will be missed
1992 964 C2 Coupe-regrettably sold
1980 911 SC Weissach-regrettably sold
1975 911S-sold but not forgotten
Old 07-10-2011, 06:06 PM
Drisump's Avatar
Firstly, my car does seem to go through more oil if on the high side of the HI/LO marks. If she would ever be above the HI line, I think she'd go through a lot. But if I fill her to half way between the marks, she will go thousands of miles before needing a quart. If there is no outside evidence of leaks you would think that there must be some smoke. If there is no smoke and no evidence of leaks, I'm thinking that either the method of checking the original level or subsequent levels were at fault. At the risk of starting a firestorm of controversy, what kind of oil is it?
Old 07-10-2011, 06:10 PM
Young enthusiast
The VR1 20w-50 racing is what's in there.
I don't notice any obvious smoke on decel - visually or otherwise. Sometimes I'll notice what seems like a slight burning smell, though it's hard to tell if it's my car or the surrounding city traffic. Should the colored smoke be obvious on decel?
I'll keep tracking.. hopefully the next 730 miles won't take off as much as the previous 730. Top end don't sound like fun.
BULLET
Old 07-10-2011, 06:13 PM
Young enthusiast
I typically check dipstick level immediately after driving the car hard while engine is idling, not after waiting at least a minute at idle, if that makes a difference.
BULLET
Old 07-10-2011, 06:17 PM
RETIRED
Joe Bob's Avatar
Correct as long as it is warm...meaning that your oil temp gauge has gone it's max (180-190F) then dipped a bit indicating your thermostat is open. Depending on ambient temp....that can be 5-20 minutes.
BTW, I'm not a fan of synthetic oil on air cooled engines.
Old 07-10-2011, 06:21 PM
Young enthusiast
It smoked & leaked a few months ago before the O-ring was replaced, but not since..
BULLET
Old 07-10-2011, 06:23 PM
Young enthusiast
I'm not a fan either, but I thought VR-1 Racing is not synthetic? I'm looking at the bottle and the word "synthetic" is not written anywhere.. I'm pretty sure it's this one:
VR1 Racing 20W-50 - VR1 Racing - Valvoline
Btw on the long drive today, oil level gauge on dashboard (which I typically ignore) showed completely empty most of the time, which is what caught my attention in the first place.
My main concern would be the top end.. I guess my question is, is a seemingly leakless & smokeless but oil-guzzling 3.2L characteristic of an engine needing a top end? or would other indicators like constant leaks & smoke be more obvious "symptoms"?
BULLET
Old 07-10-2011, 06:36 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1, re-check when she is fully hot 194 degrees or 1/8" above the first hash mark on the Oil Temp Gauge. On level ground, let her settle down while idling then pop the cap and check the dip stick.
While you are drving around, you should also hear the oil passing on the pasenger side rocker from the front oil cooler to the engine and visa versa. This is a sure sign you will get Proper Oil Levels.
Checking before she is hot or immediately after a run will give you nutty readings.
The VR1 is completely DINO/Conventional NON_Synth.
The Oil Level will always show low when underload at all times. If you come to a long stop, if the Oil Level Sender Unit is working properly and your level is at OEM middle of the dip stick it will indicate it properly. Once you move off it will show low to red again. This is as PAG designed.
'85 Carrera Targa
PCA/POC
You've been advised that makes a difference. You need to learn how to check the oil properly.
Old 07-10-2011, 06:40 PM
DRACO A5OG's Avatar
No worries Porsche 911,
It took me awhile to figure out the oil level, untill I removed and fixed my Oil Level Sending Unit.
Now I have a Oil Level Gauge that works as it should of course double checked by the Dip Stick.
'85 Carrera Targa
PCA/POC
Old 07-10-2011, 06:49 PM
RETIRED
Joe Bob's Avatar
VR1 is definitely dino. It's what I use.
The gauge will read zero when driving and read correctly....as much the gauge is ....only when idling on level ground.
Old 07-10-2011, 06:50 PM
Young enthusiast
When I arrived at the many stop lights today after a hard run, the oil level gauge did rise up to about 30%, before falling back down to low red once driving off again.
The dashboard temp gauge almost always indicates between 20% and 50% "hot" from bottom when I step out of the car to check the dipstick oil level (I don't know what degrees that translates to).
While driving, I keep the driver window rolled down and I listen to the sweet 3.2L flat-six music, so I don't much notice the sound of oil passing on the passenger side rocker from the front oil cooler to the engine.
BULLET
Old 07-10-2011, 06:59 PM
Young enthusiast
I hope and pray it's the case that I simply need to learn to check the oil properly. If simply waiting an extra minute or two at idle before taking the dipstick measurement is the answer to my concern, consider me a thankful. We'll see - hopefully I won't have to re-post after checking next time.
BULLET
Old 07-10-2011, 07:05 PM
RETIRED
Joe Bob's Avatar
It's NOT an issue of waiting at idle.....it's if the external thermostat is open or not. Putting your hand on the oil lines going forward is the ultimate indicator.
If the lines under the passenger side is hot.....check the dip stick. Cold....don't.....run it some more.
Old 07-10-2011, 07:14 PM
Young enthusiast
I'll look to check the oil lines under the passenger side next time.. just want to make sure I'm checking the right pipe.
The engine had been driven for over 40 miles this warm morning when I parked the car and first checked the oil level btw.. I thought that'd be more than enough to warm her up. Later I drove her a good 15 miles before checking again and getting the same 30% reading.
BULLET
Old 07-10-2011, 07:32 PM
A good practice to get into might be to check it when you return home from a drive. That way you know its up to temp and you know its ready to go next time.
When you stop driving and let the car idle, oil gets pumped back into the tank, which is why you see the needle rise at stop lights and such.
Give it a minute at idle to pump the oil back into the tank before you check. I think your problem all along might be that you were not being consistant in your dip stick reading.
Old 07-10-2011, 08:40 PM
