MBruns for President
JeremyD's Avatar
A little help on starter connection
Unfortunately - have a page missing from my bentley manual -
Getting ready to do some connections and didn't take a before picture...
Is this right for connections?
C or D for for yellow??
Old 09-09-2011, 10:39 AM
JeremyD's Avatar
help with a picture
Old 09-09-2011, 10:40 AM
Tired Member
DaddyGlenn's Avatar
Just pulled mine off this weekend. IIRC "C" is yellow and your "A" and "B" are correct. I can double check my "before" picture when I get home.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 09-09-2011, 10:44 AM
Originally Posted by JeremyD View Post
help with a picture
The terminal you marked (A) is the current path from the solenoid to the starter motor. The connector wire is already there. Nothing else needed unless you want to activate an accessory that only works during cranking.
The B terminal is the junction connection for the red alternator output wire (engine compartment) and the long positive cable from the battery (the negative cable in the trunk is grounded) - plural if you have multiple batteries.
When the solenoid energizes, it creates an internal connection between A and B. Same result as connecting yellow wire connector to B, in effect what the ign. switch does in the "start" position.
Before you play with these wire connections, make sure you first disconnect the battery ground cable(s).
Hope this helps,
Sherwood
Old 09-09-2011, 01:11 PM
JeremyD's Avatar
Thanks Sherwood!
Quote de JeremyD
help with a picture
Hope this helps,
Sherwood
Old 09-09-2011, 01:34 PM
