Innocent Bystander
Noisy Door Stay
The door stays on my 79 911 pop loudly at the very end of the opening range. Is this normal? Both sides do it. I just removed the drivers side to have a look. It is clean, no damage evident. I greased it with white lithium and put it back in. Seems to pop even louder now. Is it worn out and I just don't know it?
Old 11-19-2011, 12:47 PM
drive out the pin and use a 6mm bolt and nyloc nut. tighten until it quits snapping.
206 637 4071
Old 11-19-2011, 12:53 PM
Innocent Bystander
If I'm understanding what you're suggesting, just replace the pin with a bolt and tighten it so that the slack is no longer there?
Old 11-19-2011, 12:58 PM
yeah, bind it a bit.
206 637 4071
Old 11-19-2011, 01:11 PM
When I replaced mine with new stays, they make a noise at two spots. The first click is when the door is mid-way open and the second one is when it is all they way open.
I believe the noise is a result of the nub on the stay that is holding the door in the partially, or all the way open position.
It seems that your mid point stay may be worn and you are just hearing the all the way open cling.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 11-19-2011, 01:34 PM
redstrosekNic's Avatar
I was able to stop my door stop from popping with some white lithium grease.
Dustin
Old 11-19-2011, 01:40 PM
Send a message via Skype™ to Porboynz
I think the strap hole elongates a little and the spring loading changes suddenly from a pull to a push when you open the door causing the pop noise. If you replace the pin with a bolt and load it up it will stop for a while. I welded up the holes and redrilled them to size. Easy job to replace with new straps from Pelican, unless it's the holes in the body mount ears that have elongated.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 11-19-2011, 01:57 PM
Innocent Bystander
Well, thanks to all for the advice. I replaced the pins as suggested and tightened them up and... problem solved. Thanks again and on to the next problem.
Old 11-19-2011, 04:16 PM
Member 911 Anonymous
DRACO A5OG's Avatar
I just tapped down the OEM pin so the arm can ride on a newer un-worn surface on the pin.
Greased as well.
'85 Carrera Targa
PCA/POC
Old 11-19-2011, 05:31 PM
jetstar911's Avatar
I replaced both of my door stops thinking they were bad. The "pop" was still there. Replacing the pin and installing a 6mm bolt made all the difference. Worked for me.
FUNFGRUPPEN
Old 11-20-2011, 12:45 PM
