83 911 Production Cab #10
Maybe the Chinese are now using lead alloy or Post Canada is trying to avoid bankruptcy ![]() I'll redo the measurement when I'll change the tires.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
I picked up a set last month for my 77 930
17x9 17x8 they fit nicely to just inside the guards with 215 fronts and 245 rears
Wheels Last row 1977 3.0 930 260hp built, still reassembling Row 1998 996 MK1 3.4 296hp new daily driver |
Ive updated on my 930,
the calipers were rubbing on the inside of the rim so i shaved the vents/grills? back about a quarter inch in order to fit, no issues with it so far
I just had a bare Euromeister 17x7 wheel weighed on the scales at the Fedex store and it came in at 17.3 lbs. That still strikes me as very impressive for a knock-off, given most people consider replicas to be synonymous with overweight.
BOOM:
Pelican Parts Vendor
Paul Eddleston BRAID Wheels USA Team Illuminata Motorsport |
I was just reading the rules for our local PCA DE classes and they state that replica Fuchs are not allowed. Do other regions allow them?
Wheels Any safe wheel, except aftermarket cast imitation Fuchs alloys, are acceptable. Carefully check older wheels for cracking at the lug seat. Insure valve stem brace is installed, if applicable. Check that valves & valve stems are secure. We recommend Porsche original hardware. Under no condition should a repaired alloy wheel be used!
1982 911 Targa, 3.0L ROW with Webers |
I can understand the need to check old Fuchs wheels. Those buggers are starting to fall apart but WTF have they got against "cast imitation Fuchs alloys". That's just going to make people run 30 year old crack-riddled Fuchs longer than they perhaps is wise. Not to go all self promoting here but our Fuchs replicas were designed to TUV standards for historic rally use in Europe and have been extremely successful in that and other facets of motorsport for years now. Good enough for racing, good enough for DE. And "We recommend Porsche original hardware" just sounds snooty too.
I don't have any. I saw the Union Jack and thought you might find the Aero analogy funny. I should have put a question mark by it.
My local PCA's DE/AX rules state: All wheels, other than Porsche OEM wheels, must meet SEMA spec 5‐1A or be subject to approval by the tech inspector.
Any idea if Euromeister's or other Fuch replicas meet this spec? I've never heard of it, and don't know where to find compliance information.
~Brian 1987 911 Carrera |
GOM (Grumpy Old Man)
I ordered a set of 17X8 and 9s for my widebody in December. I finally received them from Automotion/Ecklers a couple weeks ago. They blamed it on the west coast longshoreman's strike. Whatevs. They do look awesome for reps and I am having them installed tomorrow. Will post pics. I'm running 225/45 in front and 255/40s in the rear. I put my wheels on my bathroom scale (granted, not the most accurate) and they indicated:
17x8: 18.2 lbs 17x9: 21 lbs Still, not bad. Great wheels for the price.
Instagram: @3pedalposse |
newb.
A responsible sanctioning body is better safe than sorry in most cases, it seems.
keith '75 RS/RSR-look | '73 CB750 | '70 TD250B r gruppe #436 |
newb.
Certainly their supplier has manufacturing resources at least equivalent to Euromeister? Why the delta?
