Josh
Basic Electrical Question
The windshield wipers on my car have been inoperable since I brought it home. After checking the fuse my next stop is the wiper motor. My question is can I just hook my car battery up to the wiper motor to check it? Is there a better way?
Old 02-29-2012, 03:31 PM
Danny_Ocean's Avatar
Yes, the motor is 12vdc.
Better way is to use a test-light to see if the motor is receiving 12vdc.
Old 02-29-2012, 03:32 PM
Member 911 Anonymous
DRACO A5OG's Avatar
You may be missing or have faulty Wiper Contact Switch
Does your horn work?
'85 Carrera Targa
PCA/POC
Old 02-29-2012, 03:36 PM
Josh
Thanks Danny - that's two of my questions you've answered in the last 24 hours (San Diego shop was the other).
Old 02-29-2012, 03:37 PM
Recreational User
porschenut's Avatar
There's a relay mounted to the tub underneath the wiper motor. If the motor itself checks out, my money's on a failed relay.
Old 02-29-2012, 03:42 PM
Josh
Draco - the horn does not work. I'll pick up a test light and check out the motor first.
Old 02-29-2012, 04:09 PM
ROW '78 911 Targa
timmy2's Avatar
Spend the money on a decent digital combination volt/ohm/amp meter. You'll need it with these cars if you want to troubleshoot electrical safely and properly. The light will help too for simple circuit checks.
Have a fuse in line with the power from the battery when you use it for applying test voltages.
I work on 500,000 volt equipment but a car battery will kill you just as fast!
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-29-2012, 05:49 PM
Josh
I'm planning on getting a multimeter. I didn't make it to the store. I started trying to get to the wiper motor but getting past the blower equipment is taking longer than planned - it doesn't help that I'm screwing' around on the computer now.
Old 02-29-2012, 07:40 PM
DRACO A5OG's Avatar
Okay, you found the most likely suspect, remove the steering wheel and check the contact switch,to see if it is connected and the ground also is connected. the wiper and horn will not work if this component is disconnected or broken.
Also check to see if the round relay at the fuse panel is plugged in, it should be number 3 plug, check your fuse panel cover for it's location.
Jim
'85 Carrera Targa
PCA/POC
Old 02-29-2012, 08:30 PM
Josh
Draco - I pulled the steering wheel today. They wiper switch looks good. The metal strip is intact and relatively clean the the wire was connected on the back. Anything else I should look at on the switch? I didn't have time to look at the motor yet.
Old 03-02-2012, 06:44 PM
DRACO A5OG's Avatar
There is also a ground connection at the bottom right mounting screw of the clam shell half.
Ground/close the switch to see if the horn sounds. If not, check to see if the round relay is plugged in at the fuse panel?
Swap the relay around to confirm it is not the relay.
'85 Carrera Targa
PCA/POC
Old 03-02-2012, 06:49 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/440814-electrical-troubleshooting.html
This may help also...
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 03-02-2012, 11:38 PM
Josh
So I need a little more edumacation.
I went to buy a test light and after discussing what I was doing with the hardware store guy he said I needed a continuity tester. After getting home and reading about how the tester works I'm confused. I have a hard time conceptualizing electrical problems so let me explain how I was thinking about the problem and then you can explain the error of my ways.
In testing the wiper motor I thought the idea was to see if power is going to the motor when the wipers are switched on. There are then two possibilities:
A - Power is getting to the motor - this would indicate the motor is not working.
B - Power is not getting to the motor - this would indicate that something else is at fault and really give me no information about the motor.
The continuity tester doesn't look for existing power but rather creates its own to look for a complete circuit. How does this help me? If there is a complete circuit through the motor does that mean that the motor should work? Or did I buy the wrong kind of tester?
Also there are several wires to the motor - which ones do I test? The red/white wire comes from the fuse and brown goes to the ground - are these the wires to test?
Old 03-03-2012, 02:26 PM
ROW '78 911 Targa
timmy2's Avatar
Get this meter or one of equivalent quality and read up on basic electrical testing.
NEW FLUKE 15B F15B Digital Multimeter w/ Carry Bag | eBay
Dennis
Old 03-03-2012, 05:31 PM
Josh, post#12 will guide you to find your problem.. However, as Dennis says above, you need to read up on basic electrical testing and get a meter.. The Fluke he posted to is simple to operate and 'a lot of bang for the buck'.
84 Mustang Turbo GT
Old 03-03-2012, 06:47 PM
HarryD's Avatar
You can get by with one of these as well for a lot less:
Digital Multimeter - Save on this 7 Function Digital Multimeter
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-03-2012, 11:14 PM
ROW '78 911 Targa
timmy2's Avatar
True, Harry, it is cheap. As a professional electrician I would never ask a person with limited electrical knowledge to even begin to try and use that. Multi scaled with limited protection for the user is not good for learning.
The fluke is almost foolproof with auto ranging and has built in safety features that protect the user.
Kinda like the difference between a 911 and a Yugo...
The on-off button looks good though...
Dennis
Old 03-03-2012, 11:29 PM
rnln's Avatar
timmy2,
can you please go into a little more detail of waht kind of protection you were talking about?
Fat butt 911, 1987
Old 03-04-2012, 02:25 AM
ROW '78 911 Targa
timmy2's Avatar
Internal fuses comes to mind. The quality of a $5 meter is questionable. Leads fall apart etc.
Most people will end up using it on higher than 12 volt systems once they have the knowledge of how to use a meter.
Dennis
Old 03-04-2012, 02:36 AM
