Sometimes the extention will get loose in the socket
Old 04-08-2012, 07:04 PM
Sears has those locking extensions. Might save you some time going to a local Sears store.
Old 04-08-2012, 07:25 PM
fxeditor's Avatar
Thanks for the tip, I'll check it out in the morning!
-- '87 Diamond Blue Coupe
-- '92 Miata
-- '06 Scion XB (the wife's)
-- '01 Audi S4 (Sold)
-- '17 Tesla Model S60
Old 04-08-2012, 07:29 PM
Oracle's Avatar
Originally Posted by rusnak View Post
take the valve cover off
+1 :-(
We're all in the gutter,but some of us are looking at the stars.
-Oscar Wilde
Old 04-09-2012, 02:56 PM
porsher
aston@ultrasw.c's Avatar
Originally Posted by fxeditor View Post
Removing the valve cover was the first thing I did. The problem is since it's cylinder 6, it's all the way at the front so you really can't see down there without a inspection mirror and a flashlight. My problem isn't that the the socket is dropped in the tube, it's full on stuck!
It sounds like the socket is still engaged with the plug and it did turn a little you said.
Why not simply try more force.
I am not suggesting a breaker bar but maybe you are being too.... ahhh.... judicious.
You already flooded it with PB, now pull on it!
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 04-09-2012, 03:33 PM
this has me perplexed. How badly can it be stuck? Obviously, you dont want to pull so hard that you break the ceramic tip, and let debris fall into the head. But it should be free by now.
Old 04-09-2012, 05:42 PM
fxeditor's Avatar
Haha Success! A big thanks to everyone for help on this especially aston@ultrasw.c! I took your advice and gave cranking it out one more try. It took an awful amount of force but the PB blast did its job and the plug came out!
The socket is still fused to the plug but at lease it's out of the car now! I have a feeling the plug had been cross threaded based on the difficulty getting it out and the evidence of residue on the plug's threads.
I have bought a Amazon.com: Powerbuilt 640811 14mm Back-Tap Thread Repair Tool: Automotive to hopefully restore the threads and I'll be getting the Hazet spark plug tool for when it's time to install the new plugs.
Thanks again for all the help!
-Michael
-- '92 Miata
Old 04-10-2012, 01:29 PM
dshepp806's Avatar
Might someone comment on the thread integrity of the pics? They look ok to me? Pic #1 DOES show (at least, seems to show) some thread issues towards the spark plug tip....(this doesn't really show on the subsequent pics....
Thanks for the info!
Best!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-10-2012, 02:05 PM
looks ok
I agree looks OK to me as well. try to put the plug in hand tight to do this put a piece of hose on the plug and start to thread it in. That way you can't harm the threads.
A VW guy starting to work on Porsches
Old 04-10-2012, 02:28 PM
Counterclockwise?
Can you show a pic of the different plugs side by side?
That plug looks like it came out of the Titanic
Rod
1986 Carrera
2001 996TT
Old 04-10-2012, 02:30 PM
Well you said "spark plug socket stuck" not that it's cross threaded.
Dont use a tap unless you want to get metal shards into your engine. The aluminum is soft, and will damage easily.
Old 04-10-2012, 02:33 PM
Banned
I don't see anything about the threads on the pictured plug that would worry me (maybe a little debris/distortion on the second row from the top?). Cross threading usually causes much more carnage than that. I definitely would not go running any thread chasers down there before attempting to install a plug.
Old 04-10-2012, 02:41 PM
rfuerst911sc's Avatar
Get a new spark plug and add a light coat of anti-seize compound. Some say you have to use the copper based but I've used " regular " anti-seize for 30+ years with no problems. Start the new plug by hand with the factory or Hazet tool. Go gently and you should be able to get the plug in with minimal issues. Agree with others do not chase the threads with the heads on the car, too risky to get metal shavings into the cylinder. You should anti-seize all the plugs. Knock on wood I've never had a stuck plug when using anti-seize.
Old 04-10-2012, 02:44 PM
rnln's Avatar
use copper antisieze so next time it won't be that hard. I used the silver (aluminum?) before switching to copper, big different.
Fat butt 911, 1987
Old 04-10-2012, 02:51 PM
fxeditor's Avatar
the initial problem was that the socket was (and still is) stuck on the plug. The plug itself was also stuck in the plug well and I wasn't able to move it counter clockwise (loosey) anymore. I think the PB blast loosened the plug enough for me to remove it.
-- '92 Miata
Old 04-10-2012, 02:57 PM
fxeditor's Avatar
I may have over-reacted but there seemed to be a lot of debris in the threads of the plug when it finally came out. I will try putting an "anti-seized" plug in using the hose method before doing anything with the thread chaser.
-- '92 Miata
Old 04-10-2012, 03:01 PM
fxeditor's Avatar
What size hose do I use?
-- '92 Miata
Old 04-10-2012, 03:03 PM
Banned
The hose needs to fit as tightly on the plug post/stem as possible (maybe go halfway down to the socket head or so - ew, that sounds "wrong") . . . really you're just giving yourself something to turn with finger power only and the hose is easier to grip than extensions are.
Old 04-10-2012, 03:11 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Sometimes a plug reaches into the chamber a 1/2 thread too far.
If so...the carbon buildup on that last thread can make it very difficult to remove later.
Make sure the head was not resurfaced in the outside plug area (the seating area for the plug washer/seal).
Bob
Bob Hutson
Old 04-10-2012, 03:28 PM
docrodg's Avatar
Bob
Been there, done that... got the bloody knuckles. Not to mention that 1/2 thread can get hot and cause pre-ignition. Indexing plugs is a help there...
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 04-10-2012, 08:41 PM
