naples911's Avatar
Dead Carrera '84
Cruising along at 60 mph, my '84 Carrera just lost power and shut down. After pulling to the side of the road and trying to re-start, the engine turns over fine, just doesn't want to catch. As if it's starving for fuel.
The following is new: Reference sensor, cylinder head temp sensor, coil, fuel filter, fuel pump, rotor and cap. And, I switched out the fuel pump relay on the spot, nothing!
So, I'm a bit perplexed. Today, after towing it home, I shot some starting fluid in the intake and it sounded like it wanted to start. So, i'm guessing that the fuel pump might not be delivering, however, tested that by jumping the relays and it makes noise.
What next? Is there another sensor i should be replacing? I haven't done the speed sensor yet as it felt a bit stuck when i tried, but would a bad speed sensor prevent the car from starting? My understanding is the reference sensor is for starting.
What should I be checking next? It's usually the dumbest things that work so feel free to take a shot!
Thanks.
Old 05-30-2012, 03:12 PM
Flat Six
Flat Six's Avatar
You didn't mention DME relay; I'd start there . . .
Also check grounds (esp. battery neg., cluster @ intake mainfold, and trans ground strap).
Either compression, ignition, or fuel. You might get FP sound, but check fuel pressure, too.
BTW, speed and reference sensors are not just for starting -- they provide ongoing info to DME during operation.
Good luck; keep us posted.
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 05-30-2012, 03:17 PM
KNS KNS is offline
It sounds like you have already covered the typical problem areas. Check all the wiring and ground connections - make sure clean and tight.
I don't have any other advice but it is starting to get old seeing all these Carrera dying/no start issues!
Kurt
Old 05-30-2012, 03:18 PM
naples911's Avatar
Thanks guys, I agree about checking the fuel pressure. Can I get that gauge anywhere?? I've done the ground straps before, sanded them down etc and it made a huge difference in performance.
It's funny, the tow driver said that he picks up just as many new cars of varying species as he does old ones. Mostly sensor issues
Old 05-30-2012, 06:30 PM
Originally Posted by flat six View Post
you didn't mention dme relay; i'd start there . . .
+1
O2 In Sully We Believe
Old 05-30-2012, 07:50 PM
DME Relay. My 84 did the exact same thing on the way to work one day, died while cruising on the freeway. A new relay had me on the road again.
1984 Porsche 911 Targa
1974 Porsche 911 Coupe- just a tub... for now
Old 05-30-2012, 08:07 PM
scottb's Avatar
Same here. I bought two...and keep one in my glove box.
1984 Targa
Old 05-30-2012, 08:09 PM
muck-raker
kidrock's Avatar
first thing I'd check is the DME relay.
FWIW, I once had a bad fuel pump that fooled me. When I used a jumper on the DME to "hear" the pump run, I could clearly hear it "run". But I still wasn't getting fuel. Really pissed me off, so I replaced the pump anyways. Been perfect ever since....
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-30-2012, 09:27 PM
Carry a paperclip bent into the shape to jump the DME relay in addition to a spare. Just in case they both somehow fail...
Old 05-30-2012, 09:35 PM
cary's Avatar
Did you make sure the fuel pump relay didn't fall out?
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 05-30-2012, 10:50 PM
I had exactly the same problem as you last week. Tested the 3 sensors in the engine bay, the reference and CHT were fine but the speed sensor was toast. Swapped it out with the BMW part and the old girl fired right up. Some posts say the speed sensor won't cause a 'no start' but on my 84 it did.
Scott
1984 Carrera 3.2 Guards Red
Old 05-31-2012, 01:19 AM
naples911's Avatar
The DME relay is the one next to the ECU beneath the driver's seat, correct? I changed this out but referred to it as the fuel pump relay. After a little research, i guess the fuel pump relay is the red relay under the hood. Do those go bad and if so how would i know?
Scott, how did you check the sensors in the engine bay? Thanks, i'm suspicious of that speed sensor as it's the only sensor that hasn't gone yet.
Keep you posted, thanks for the replies!
Old 05-31-2012, 06:19 AM
DME relay OR Flywheel position sensors.
Old 05-31-2012, 07:01 AM
KNS KNS is offline
One of the guys here had a similar problem, replaced all the usual suspects and then some - he and his mechanic were stumped. Turned out to be a faulty fuel injector.
Kurt
Old 05-31-2012, 07:45 AM
Naples, The procedure is outlined in the Bentley guide with pictures if you have a copy (p280-11). If not you'll need a Multimeter to test them.
From memory the speed sensor is the middle of the 3 sensors on the left hand side in the engine bay. Remove the 'clip' from around the sensor and pull straight out. The sensor has 3 terminals, the bottom one is no.1, the middle no.2 and the top no.3. Use the Meter to test between terminals 1 & 2 (the bottom and middle), this should give you a reading of 960ohms +/- 96ohms. The reading between terminals 1&3 and 2&3 should be >100,000 ohms. I couldn't get a reading at all on the speed sensor but the reference sensor tested within range. I had a mate test on the control unit under drivers seat and confirm it was faulty and the reference sensor was ok.
I hope my description makes sense and doesn't sound like i'm dribbling you know what.
Scott
Old 06-01-2012, 03:37 AM
Check out my current thread. I'm still dead in the water:
http://forums.pelicanparts.com/porsche-911-technical-forum/638355-3-2-engine-stalling-stumped.html
During a recent test, where my mechanic and I by-passed the DME relay, we fried the engine wiring harness. This weekend, we'll be replacing it (for the 2nd time). Let me know what you find out, and good luck. As Kurt said, these mid 80's Carrera's are starting to suffer the same issues - what ever that may be...
Scott
___________________________
1985 Carrera Targa - Guards Red
2006 Acura TSX Navigation - Milano Red
Old 06-01-2012, 11:50 AM
závodník 'X'
intakexhaust's Avatar
Believer in the DME relay syndrome... spare in the glovebox. One thing I've noticed if the car isn't driven often, things start getting haywire. From the age, when you seasonal drive it, things shake rattle and roll and connections loosen or fail without notice. Seals need to be worked and kept pliable too. Before you drop dollars on sensors and guessing, check and clean grounds, pull relays, check terms and spray contact cleaner, same for fuses, etc.. Check the wires going into crimps, blades, terms. You might be surprised.
Old 06-01-2012, 03:38 PM
KNS KNS is offline
Guys, for the third time, he's changed the DME relay
Kurt
Old 06-01-2012, 04:34 PM
Flat Six
Flat Six's Avatar
Naples -- Here's a FP electrical diagram that may help:
Fuel pump pressure testing is described in much detail in Bentley, 240-5. Should be getting:
~36 psi engine off
~29 psi engine running
~33-39 psi engine running w/disconnected vacuum hose to FPR
Am pretty sure speed sensor affects running condition, while reference sensor affects start/no-start condition. See:
Dale
Dale
Old 06-01-2012, 05:25 PM
Diss Member
Quicksilver's Avatar
Test the fuel pressure at the test port on the right fuel rail. Watching it as you drive will clear up any questions about fuel delivery right up to the injectors.
Test systems instead of replacing them.
To test the DME put it in a known good working car. That will clear it up and avoid the (slight) chance of damaging a known good DME because of a bad component like a shorted IAC valve.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-01-2012, 05:28 PM
