Banned
Well, since my decree is the only one that really matters, from this point forth, all of you shall refer to all non turbo flared 911s as "narrow bodies" as they do, in fact, have very narrow bodies relative to the turbo flared variants!
And 14 and 15 inch RSR flares make your turbo flares look like goosebumps, where does it end ? |
Banned
Guess I need to amend my decree so as not to create more confusion!
Banned
Yeah narrow body is prior to 77
Anything else is either SC flared or carrera flared if they are not Turbo flared. Thats what i was told anyways
1975 Aubergine 911S - Barney "When that doesn't work, and it doesn't quite often, it's as though your face has been amputated." - Jeremy Clarkson |
too many projects 1983 sc
and some are narrower than others..pre-69 cars then 69-77 same flare. ben
There are only 3 body styles, not counting cab and targa and some racing permutations from 1969 up
narrow body, 4x 5.5 or 4x 6" wheels stock, no flares to speak of 1969-1977 SC/Carrera body, 6 & 7 or 7 & 8 or 6 & 8 wheels, rear flare is called a 9" flare, front is as on n/b, 1973-77 Carrera 2.7 7 3.0, 1976-89 SC & Carrera 930/RSR body, 6 & 7 or 7 & 9 but w/ big spacers f/r, front is a 9" flare rear is an 11" flare, 1973RSR, 1974 Carrera 3.9RS, '75 -89 930
Wider is Better
The issue I have with them is they are 1 inch taller than 245/45/16. This is roughly a 4% increase in the distance of the axle center from the ground with an associated loss of acceleration. I don't know if the loss of acceleration would really be noticable, but it would mess with my head.
Wider is Better |
Bill:
So just to be a delinquent , what's a SWB flare? Their even smaller than the 69 since that is from the 911R...*hides behind large object* t
1967 912 with centerlocks… 10 years and still in pieces! |
Whoopsies I was banned!!!
Drola,
Let us know how it turns out and post some pics! For my 84 which has the non-turbo standard fender flarings (same body style as your 87) I have 9x16 rims in the back. It is lowered, and I could not tolerate anything larger than 245/45. And that is with some rolling of the fenders. |
Wholberg,
If you are after spool-up, change to x15's and machine your flywheel ![]() Yes, there's more inertia to overcome which penalizes acceleration, but there's also more inertia available to you into, through, and out of the turn ! |
The swb cars built from '64 -68 were n/b too and didn't even have the slight hint of a flare seen on the '69-77 n/b cars they came w/ 4 x4.5 or 4x 5.5 or 4x 6" wheels.
245/45 on a 9x16ET15 wheel should be an easy fit w/o an extra work and w/ plenty of clearance at any ride height. I used to run 275/40 on 9.5 on my '76 C3, but have gone back to 255/40 x17 on the same 9.5's for street use, this is also an easy fit w/ SC/Carrera flares and the correct wheel o/s
225 50x16 on 7" and 245 45x16 on 8" no spacers no rubbing but not lowered to euro height yet, waiting for t-bars
I don't know about a 16x9, but I ran 245/50-16s Goodyears on my stock 16x7s for over a year with no issues. I had a rear tire blow out and when I went to a friend of mine that is a tire dealer, he had a pair of take offs he offered for free. Since a 7.0" wide wheel is the minimum spec wheel for a 245/50, I had them mounted up. My SC was still at the stock ride height at the time, so it didn't like awkward with the tall sidewall like it does on some of the lowered cars in this thread. Despite the narrow wheel and sidewall flex, I never had rubbing issues even when cornering at the limit. Handling improved a lot over the old 225s where the back end stayed a lot more in check under braking and in corners it would nicely pivot on the inside rear tire. Never really found a negative to it, but I would have preferred a wider wheel if I had a set. Sorry, I never took any pics of it with the medium rear tires.
There is nothing wrong with running a big tire as long as you have enough room to properly fit it. I have no problems with the 335/35-17 I run today on 17x13's, which are a little taller than 245/50-16's: ![]() The fronts are 245/45s on 17x9.0" wheels, which are the same height and width as the rear setup discussed in this thread. When I was measuring for the backspacing for the new wheels, I used the 16x7's with 245/50s on the front to do the measurements. Last edited by 10 GT3; 08-30-2012 at 08:43 PM.. |
