Did not see answer to OP question on paint tag.
Drivers Door Jamb has Paint Code Tag (at least it does on my '73.5 & '76), a series of numbers with the first three being the factory paint color. Looks like wonderful project!! |
Hi
What I did on my 1971 T motor, was pull plugs, put in 5th gear and you and friends push the car and watch the crank......if it moves freely, good.
On my engine, it moved freely, but took engine out and tearing down to the case. Engine had much old oil, gummed up, has been setting since 1993. Carbs bad, heads dirty, pistons seem OK, need to slit case... |
As Joe Bob said, someone did something strange with the original crank pulley. However, it does look like you could get a long flat-blade screwdriver between the center shaft and one of the nuts and turn by prying, again clockwise. It wouldn't be surprising if there was too much resistance to turn it by the fan belt, but could easily be broken free on the crank.
Give that a whirl and report back. Nice project BTW! Mike
Michael Caterino Clemson, SC 1970 tangerine (=Tiger Orange) 'T' targa restoration: mk911.blogspot.com |
Dave & Tonya
You've got a great survivor here that doesn't look like it's going to require a lot of body work, but plan on barakes and an engine rebuild. It's set too long. Even it turns over it probably needs rings, valves and guides, and resealing after all that time. But this is a great project!!Keep us all posted!
The screwdriver approach has potential. Thanks. Tried it but things aren't breaking free yet. I'll let it soak some more and keep trying.
Jess 1988 911 Carrera Coupe 1971 911T (Sold) 2003 Harley Davidson Lowrider |
Welcome to the longhood club!! Your car certainly looks like a great candidate for a restoration. I went down the same path as Combatic suggested and did a piece by piece restoration so that I could enjoy my car as a driver during the project. The first things I did on mine included the flexible brake lines, brake caliper and master cylinder rebuild, and shift linkage and throttle linkage bushings. Here is a link to my thread http://forums.pelicanparts.com/porsche-911-technical-forum/660560-saving-rat-restoring-69t.html
If you have any questions this forum is a great place to learn as I learned most everything during my restoration here. Best of luck getting the engine to turn over. Cheers, Kristoph
1969 911T - The "Rat" 1997 A4 Quattro 2.8 (270k) - Black Kaniget - Dead but not forgotten 2010 Jetta TDI Sportwagen - Egg Butt (also Spewing Dragon) 2001 Eurovan Weekender - Bruni |
oh geez that original paint has a glorious patina! Please don't respray that car!
____________________ 1985 Carrera: Big Reds = Ass Saver |
![]() This (violet bracket) is an aftermarket A/C adaptor. The A/C pulley (now missing) was originally mounted on the end of the adaptor. The adaptor is bolted (red arrows) to the original Factory fan belt pulley. The original pulley-to-crankshaft bolt can be accessed in the middle of the adaptor (green arrow). You may need to use a ‘deep’ 3/8” drive socket for this. Install the socket on the bolt and then attach a long-handle ratchet wrench. Sell the adaptor on Pelican. Someone will find a use. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Thanks Grady. The PO indicated that at one time there was an aftermarket AC unit in the car. It's long gone but that explains the pulley. Access is very limited but we'll find a way...
Cheers,
Czar of C.R.A.P.
There seems like no better time than to suggest you jump right in and drop the engine and tranny. It is going to need to be done anyhow so just do it. You just about drop the engine on a porsche to change the air filter. Nothing to it after you have done it.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
How about cutting off the belt and using a strap wrench either on the pulley or on the outer flange? You might need to put a cheater pipe on the strap wrench handle...
HTH. Good luck!
1984 Targa Last edited by scottb; 08-23-2012 at 01:02 PM.. |
THAT is a great idea!
David 1972 911T/S MFI Survivor |
Every decade or so I have a good one...
![]() Seriously, though, maybe even something like this adjustable handle chain wrench would do the job. Or something like this chain wrench with a long breaker bar. A traditional strap wrench, though, might be better in that the adjustments aren't limited to the size of the chain links. All you need to do is break it loose, and when trying to do that leverage (and liberal use of Marvel Mystery Oil) is your friend!
1984 Targa Last edited by scottb; 08-23-2012 at 01:41 PM.. |
Under the radar
Deja vu. My '71 looked EXACTLY like your car when I first bought it. Is that the original paint or color?
Fix the mechanicals, leave the paint alone and drive it. Awesome car, nice find.
Hi,
+1 on the above. Dont tear too much into it, keep it on the road instead! I have seen guys just tearing down a nice driver to give it a total restoration, ending up with an empty shell and 50 boxes of parts that sits for decades. The best advice so far on the engine (when breaks are working) is to roll it outside, put it in 5th gear and take the help of some buddies. First, start by having it in gear, gently rock it back and forth (only push on the "forth" to keep the engine potentially moving in the right direction) and check for movement. Then you push harder and harder, until the tires are slipping. When you feel you have nothing to loose, you cant get it to move no matter what, you could always ask your buddies to push it hard, put it in first gear and release the clutch quickly when you are at speed. BUT, that might break stuff, so be cautious!!! If the engine is frozen, my guess is that you will break the crank pulley bolt before it moves. Ask me how I know.... ![]() Regards, Johan
-14 Cayenne S Diesel, DD -92 964 C2 convertible, RS -92 look and feel😃 -73 T US MFI Targa, restored -70 T Coupé Hot Rod, painted waiting for assembly -72 T Coupé, US numbers matching under restoration |
Gotta love the voice of experience! I'll finish up the brakes and try taking her for a "push" around the neighborhood.
I like the advice to get her running and just drive it. She's solid enough to do that and I don't need a bunch of boxes of parts sitting around. And no new paint. I've hit a couple of spots with some polish and wax. She'll clean up nicely. Thanks
Im probably going to get slammed here but I'd be too tempted to just change the oil, purge the gas and put in new and turn the key and see what happens before I'd drop the engine. Its not like its been sitting n a barn for 20 years. Even the oil on the outside of the case is visible.
Looks like a lot of fun, Do some rust searches here to learn the hot spots and dig around the front pan and jacking points. Nice find though, mind letting us know what you paid?
79 SC unmolested 75 911 backdated RSR widebody 71 911T having fun skinny 63 356 outlaw frustrating purists 25 GTS |
I would rather be driving
Will it turn with the starter? I would try that first. Even with old oil you will not do any damage spinning at 200 rpm with the starter for a few seconds. Just disconnect the CDI unit so that it can not fire.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Unmolested. The best kind. Good job with purchase!
Update?
Johan
