moneymanager's Avatar
Craig,
Thanks for this thread. Two questions: you pulled the hub off the trailing arm before removing the trailing arm. Was that necessary or did you just do it then because you were going to do it eventually anyway? And, second, is it feasible to remove and replace one side then do the other side, or must both sides be done at the same time? Many thanks,
Jim
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 02-18-2015, 03:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #781 (permalink)
brings back memories
Great job there.
Brings back memories. I did this same suspension rebuild to my 83 911 SC in 2011.
Poly bronze bushings front and rear, new bilsteins, new seals, bearings everything.
Cleaned up painted and put back together. All the plated parts replated, all new brakes.
Its a big job. And things didn't want to come apart after nearly 30 years of togetherness.
But its been awesome on the road ever since.
Best of luck to you.
Old 02-18-2015, 04:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #782 (permalink)
sugarwood's Avatar
Craig, can you explain that homemade rod bearing pressing tool?
You are basically using a bolt/washer to push something along that rod?
The other side of the rod needs to be anchored to something via a large washer?
It's basically like a C-clamp kind of ?
Also, why is the rod so long? (T.W.S.S.)
1986 Bosch Icon Wipers coupe.
Old 02-19-2015, 12:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #783 (permalink)
sugarwood's Avatar
Originally Posted by Craig_D View Post
Continued:
The final bearing is seated deep.
It doesn't look like the flat wrench you used would be able to have clearance to spin the bearing rold tool bolt that deep.
How did you get it that far down into the cavity?
Old 02-19-2015, 01:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #784 (permalink)
This shows where he pressed the hub into the bearing, not the bearing into the trailing arm. There are washers under the closed end wrench and probably a suitable sized socket (that's what I used) on the backside to catch the lip of the bearing and keep it from being forced out the back side.
Here's the same process in my thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/735959-71-coupe-project-4.html#post8269143
1971 Light Ivory 911T - Gretchen - sold
Looking for Engine # 6114097
2010 Cayman
Old 02-19-2015, 01:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #785 (permalink)
sugarwood's Avatar
It's funny how a thread will have different impact on people.
Some are inspired. Personally, I am now having 2nd thoughts, and thinking this is beyond my capability.
It took Craig, someone with far more experience and tools than I, over 3 months to do this work. (8 months if you count the troubleshooting!)
The big fear on a project like this is biting off more than you can chew. Once it's disassembled into a non-roller, you can't even tow it to the shop to finish what you can't do.
At some point, I will research which smaller steps are the most realistic for the novice who is just looking to do a basic refresh a 30 year old OEM suspension.
Old 02-19-2015, 01:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #786 (permalink)
sugarwood's Avatar
Sorry, but I wasn't able to follow the photos. It's not clear what was being removed or installed. No idea what the large socket was doing on the other end, or how it was secured. Not a big deal, I think I understand the basic idea of using a rod with bolt to force things down an axis. Thanks.
Old 02-19-2015, 02:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #787 (permalink)
French Import
zippy_gg's Avatar
When you reach that point you can always remove the trailing arms and take them to a machine shop where they can use a press to do the work.
Of course this means you disconnect your entire rear suspension, which may or may not be OK depending on the scope of your project.
If you only want to replace the bearings and not touch anything else then you are correct about thinking to take the car to a shop.
If on the other end you are refreshing bushings and brakes then take the whole thing apart and use a machine shop for pressing bearings in.
I made the tools shown in Greg's pictures and it worked great!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 02-19-2015, 02:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #788 (permalink)
i followed Craigs work here step by step behind him- it took me 4 weekends to do everything he did (except wheel studs, and i went tarett bars) its not that bad when you dive into it esp when you have this thread as a referance. i am so happy i took the time to learn about the suspension. it has made it a lot easer to adjust at the track and understand how it works.
good luck either way- it is a lot of work, very rewarding.
Old 02-19-2015, 03:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #789 (permalink)
Air Cooled
Craig_D's Avatar
Hi guys, thanks for the feedback. It's gratifying to know that my thread is still helping/inspiring people to work on their own cars.
I'm just getting back online after being under the sun in Cancun for a week, and am now awaiting the biggest predicted snow storm for the Denver area in over three years! Wish I could go back to the beach!
Jim
Hi Jim, I pulled the rear hubs off while the trailing arms were mounted in the car to help hold the trailing arms in place. Otherwise I would have had to wrestle with the large trailing arms in a vice, and didn't want to deal with that. For your second question, I guess you're replacing the bearings? If so, I would do both at the same time. I'm the kinda guy who likes symmetry, so I tend to replace things in pairs. In my particular case, I was approaching my project as a complete balanced overhaul, so I had planned to replace all of the "consumable" components while I was in there.
The rod bearing press tool is just a long 3/4" threaded rod with numerous thick washers. I used a closed end crescent wrench on one side, and either a socket wrench, or a closed end ratchet wrench on the other, with washers. When I couldn't get a wrench onto one end, I would use two nuts tightened together (locked) on the unreachable side, then two wrenches on the outer side (one to lock the whole deal down) and the other to tighten the active nut to press the components together.
The reason that the threaded rod is so long, is so that I could also use it to install the ER rubber bushings into my front control/A-arms. One tool to rule them all.
In the pictures shown, I was pressing the rear hubs onto the trailing arms. I actually utilized the (now unused) front strut covers to press the hubs on. Here's THE LINK to that part of my project
I can understand trepidation at undertaking a project like this, but you can do it. Just take each project one at a time, keep a clean workshop and finish each micro project before moving on. If I tackled this project again, it would take me a couple of weeks instead of months. I move slowly and meticulously when doing new projects, and since this was the first 911 I've worked on, I really took my time to understand how it all works, and what's important.
Hope these answers help!
Cheers.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 02-20-2015, 01:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #790 (permalink)
SoCalSK8r's Avatar
Sugarwood- don't sell yourself short. There is nothing in these steps that's overly hard to do. Tedious, yes. hard, no.
On top of that, you learn a tremendous amount about how your car suspension works, how the adjustments work, etc.
Where do you live? If you get stuck there's plenty of Pelicans who I'm sure would help.
Craig has laid out awesome instructions and practically makes this fool proof to tackle.
‘84 Carrera, heavily modded
Please follow me @chopped_up_fitness
Old 02-25-2015, 05:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #791 (permalink)
SoCalSK8r's Avatar
And yes, I'm a proud 'student'
Old 02-25-2015, 05:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #792 (permalink)
Nice work there, Skater. All this plating folks do nowadays looks fantastic. Sure beats rattle can silver and black. John in CT.
Old 02-25-2015, 06:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #793 (permalink)
Registered speed offender
78SCRSMAN's Avatar
Cheers.
About pressing bearings... aside from pressing the outer race you want easy rotational motion while installing, if not then you're pressing against the wrong component! Also, once the hub is in and the big nut is on, rolling the car on it's wheels without axle shafts is okay... on these cars.
If you keep looking back, you'll never move forward.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #794 (permalink)
SoCalSK8r's Avatar
Thanks , I went for Cad playing and black powder coat. The calipers were done by PMB and came out amazing.
Since I'm in CA and the car will stay out of crappy conditions it made sense to invest in some nice plating. I'm very happy with the results.
Old 02-26-2015, 08:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #795 (permalink)
Air Cooled
Craig_D's Avatar
Wow, looks great Skater! Glad I could help make it fool proof...ya know, takes one to make em that way.
'69 Honda CL350
Old 03-23-2015, 06:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #796 (permalink)
Enthusiast
jrolstin's Avatar
Craig! What the crap did you do with your sugar scoops! lol
Jonathon
1982 911 SC
www.avrmotorsports.com
Old 05-31-2015, 05:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #797 (permalink)
bugstrider's Avatar
Email sent with a couple of basic questions.
Cheers
Trevor
-Palpatine (Robot Chicken)
1978 911SC Targa
Working Projects: 1968 912
Old 08-12-2015, 06:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #798 (permalink)
bugstrider's Avatar
Sold them to me, with the exception of the bezels, lol
1978 911SC Targa
Old 08-16-2015, 12:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #799 (permalink)
JOHN21BLACK's Avatar
With all that work done. All that was missing was the 930 Turbo Brake upgrade. Nice work!
Old 09-23-2015, 04:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #800 (permalink)
