Did my first valve adjustment, what a pain the process is. However, it was still way easier using the Kirk tool. While there, I installed new oil filter and oil, rotor and distributor cap. Spark plugs were still good. Engine had been running rich for a while, so I checked exhaust and adjusted the fuel mixture using my Innovate tool - for me, worth the money. Day and a half worth of work.
Bob '82 911SC Guards Red |
Innovative tool???????? Now you have to describe that.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
83 911 Production Cab #10
Innovate Tool (as posted): Digital Monitoring Products, Tuning Tools, & Controllers. Innovate Motorsports
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Ok I gotcha. Mine is older and not so high tech, kind of like me.
Cars Ruined My Life
Thanks, next major cleanup will be the electrical... Its a real mess.
Went to a car show
I'm the 3rd car in ![]() Decent view on the drive down, following an R33 GTR and an NSX ![]() Lined up with a few of my friends ![]() Buddy's 964 on his new Works brombacher wheels, pretty nice ![]()
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end. http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html Last edited by Bergo; 07-11-2016 at 11:11 AM.. |
![]() 😃/😢 Day. Pulled drivetrain out of our wrecked 993 today. Many parts will live on in our new Guards Red '95. Back in late 2014 my poor wife hydroplaned in her Gpx White daily driver "Harold". 231k miles of smiles out of him! Porsche safety engineers did their job and she walked away fine! We moved on to Mushu, she chose the Martini livery.
I installed magnetic stone guards from MagnaGrafik. Excellent quality product.
"There is no old Porsche, just a new Porsche owner"
New steering wheel from Renown, mounted with a Snap Off quick release.
Washed my red devil...
My friends call me Phish
I got tired of trying to find a radio knob for my '65 Blaupunkt radio, so I decided to design one to get one printed.
https://www.instagram.com/p/BH-Btq1gpyH/?taken-by=pemz0r&hl=en |
Jacksonville, Fl
After BAT auction results on '89 911, and high heat idexes, am thinking upgrading AC to 1971 Celica standards would be wise!
Anxiously awaiting this from Kyle at Rebadge tomorrow!
Wingnut
Have spent the last couple of weeks trying to figure out what cooked my starter. The starter was engaging when the ignition switch was in the run position. Replaced the ignition switch as it was getting loose and wonky, so I figured this was the most likely culprit. Big pain in the arse to replace and no love, still engaging from the run position. Started looking for places the yellow wire from the ignition switch (terminal 50) and the red/black wire (terminal 15) could be shorting to each other.
After much pain and angst, and some help from my buddy Larry, we found it inside the connector that fits to the back of the ignition switch. Check out the pictures below, it took 38 years, but the back of terminal 50 had rubbed through the insulation of the red/black wire. I feel lucky to have found it. ![]() ![]()
Tom There's a hole in my garage where the money goes... |
1985 M491 Carrera /Turbo-Look Registery #1727 / White Gold Metallic / Leather Recaro Pole Positions / Wevo shifter & shift joint / Fifteen52 Outlaws - 15x8 & 15x10 / Fabspeed RSR Headers and Muffler / AC delete / Appbiz RS Carpet Kit / Lakewell dash / Stratton Duck w/Al Kosmal grill / Elephant Racing 19mm spindles, coilovers, and quick-change camber plates / SW chip & throttle body |
I've been picking away with assembling the car since i got it back from paint. Yesterday i decided to start it up as it hadn't run in about 4 months and i just wanted to hear it purr. So, installed the battery, turned the key and it cranked but wouldn't fire!! Last thing i wanted to do was spend time chasing a new problem when i have a mountain of work already with body and interior assembly. Luckily, i notice something when i tried to crank it, a clicking behind the centre of the dash. Tried several times and then the light bulb in my head went off - alarm problem! The original alarm horn was eliminated when i rebuilt the front end last winter but the rest was still in place i expected. I did some research last night to refresh my mind on this issue and found the thread about installing 2 jumpers. I guess the body shop guys messed up the wiring when they pulled the doors off and put them back one. This eventing I tore the ventilation system out and found the module (well hidden!!). A quick attempt to start the car confirmed this was indeed the source of the clicking. Ii made two jumpers and installed them and sure enough it came alive!! What a sweet sound the air cooled engine is when you overcome a problem like this. Now I'm drinking beer and feeling pretty good. I also installed the fuel filler neck, rubber boot/grommet, keeper wire ring (PITA), and associated items. All in all a great night!
84 911 Targa Carrera currently getting renewed |
Do you think that is the popular cause for ignition switches going bad? Seems like a little electrical tape reinforcement in that screw area would go a long way. This is worth posting on the tech forum.
Can you open the ignition switch back without removing too much stuff?
1986 Bosch Icon Wipers coupe. |
| Tags |
| fuchs are ugly , stock sucks |
