Idle Adjustment
1986 Carrera 3.2 Could someone please give me a definitive answer when adjusting idle. Is it done with the Oxygen sensor inside the engine compartment attached or unplugged?
Old 03-24-2013, 01:32 PM
ruf-porsche's Avatar
I was under the impression on DME cars that one couldn't adjust the idle. It was all done by the komputer.
Old 03-24-2013, 02:06 PM
Idle Adjustment
Wrong impression. Anybody have the answer?
Old 03-24-2013, 03:13 PM
emac's Avatar
Quite a blunt answer for someone offering his advice. Why don't you Google it
Ernie 81sc
Old 03-24-2013, 03:53 PM
Idle Adjustment
Bluntness unintentional. Apologies. Adjustment is after a chip replacement and I just want to dial in the idle. Nothing definite on Google.
Old 03-24-2013, 03:59 PM
Hunt3R's Avatar
Base Idle is adjusted with O2 attached, but ICV disabled by putting a jumper in test ports B-C so that the ICV won't try to adjust the idle for you while you're setting it. You're trying to set a base point that the ICV can adjust around during normal operation.
Base A/F Mixture is adjusted with O2 detached so the DME won't use the O2 reading to adjust the mixture while you're trying to set it. But no jumper, ICV enabled.
Old 03-24-2013, 04:33 PM
I've been puzzling (as usual) over the sequence for adjustment. I'm assuming you set the air fuel ratio first, then set the idle as you have indicated.
I don't have an air/fuel ratio gauge so will have to set the a/f first based on the oxygen sensor connector reading (unplugged) then the idle with the oxygen sensor connector plugged back in.
Thank you for your response. Much appreciated.
Old 03-24-2013, 04:47 PM
Nine9six's Avatar
Did you do a search on idle adjustment? This topic has been posted many times with photos.
Prior to posting, its always a good idea to SEARCH. Even a google search on "idle adjustment, Porsche 3.2" would give you the results you desire.
When I started reading through the thread and I got to the RUF-Possche response, I thought exactly as the next sequential reply. Yeah the reply may have seemed a bit abrupt, but it was spot on as flagging it as incorrect.
Try this link...
http://forums.pelicanparts.com/porsche-911-technical-forum/740130-idle-adjustment-screw-what-tool.html
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 03-24-2013, 04:49 PM
