how take out the alternator
Hi I would like to know if there is a guide or someone to help me to remove the alternator from my 1984 911 to put a new one,, because I having a lot of irregular voltage problems
Pelican Technical Article: 911 Alternator & Voltage Regulator Removal/Replacement Jerry M '78 SC |
Coram Deo
It's not a complicated job. Work slowly and deliberately and take lots of pictures as you go (this aids in reassembly!)
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio |
Band aids !
Ernie 81sc |
muck-raker
the hardest parts that you may encounter are:
1) plopping the fan and alternator out of the fan housing, and 2) plopping the alternator itself out of the fan. There are tons of threads on replacing your alternator, a proper search with a cold beer will produce fantastic results. Not a real difficult job, good luck. P.S.---this is a great opportunity to clean up the fan and housing, just to make the engine compartment a little more presentable.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations ![]() |
thanks for all your help
Driver
When I read a manual that listed the project time as something like 4 hours, I was shocked. There are only about 3 things to take apart. It's very simple conceptually. But there are a few small screws/bolts in hard-to-access areas. When you actually start unplugging the (4?) wires to the alternator, remember to label them with different colored tape or something, and write it down or take a pic. It'll help you remember which plug goes where come reassembly time. The only part I didn't do myself was removing the alternator from the fan assembly. I tried the mallet/block of wood technique and it wouldn't budge, so I wound up taking it to my mechanic to press out. Not a big deal, as he was selling me the remanufactured alternator, anyway.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Please disconnect the battery before you start. There red wire on the alt goes to the starter and to the battery.
Hardest part is removing the air deflection plate. |
Thread Tools | |
Rate This Thread | |
