break fix drive repeat
What to do while the engines out of the car?
My drivetrain's coming out this winter to refresh some of the transaxle synchros and pop in a new clutch. My car's an 84 with 64k miles, and the engine is bone dry right now...but...I hope to not drop the engine again for a loooooooooooong time.
Even though I have no oil leaks, I will have access...so...should I replace some of the oil seals as preventative maintenance, and if so, which ones? (What else would you guys do with the engine out of the car?) Please use small words as I'm not yet the 3.2 guru I hope to soon become. Thanks! Rich |
Been here a while
do the main crank seal while the clutch is out.
do the 'holy trinity'---the oil temp sender, the thermostat gasket and the crankcase breather cover gasket, middle of the motor at the rear. check all hoses, I found a few sources of vacuum leaks. you might want to check all the fuel injector seals and clamps....and clean everything, valve adjustment, etc
looking for 1972 911t motor XR584, S/N 6121622 |
there are many threads on this you can find with a search. also much stuff in 101 projects book.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
The most expensive phrase on the planet: "While I am in there"
Wayne dreams of hearing that from all of us.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
83 911 Production Cab #10
Apply for a Line of Credit
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Take one of those goofy pictures of you inside the hole in the back end.
'84 Carrera (recently sold )'67 MB 250SL A few Italian motorcycles ......and a minivan for the crew |
Craig T Volvo V60 - Daily Driver (I love it!) 997 Turbo - FVD Exhaust, GIAC Tune - 542 dyno hp on 93 oct 1972 Chevy K-10 Pick-Up Truck Hugger Orange
Oh for sure, that is a given. Ya gotta do the pic!
Spiderman
30 years old and only 64k miles. (2k miles per year) I wouldn't do much of anything if it ain't leaking. Its certainly not being driven much so just do the clutch.
Change the oil maybe.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Just get in there an clean, clean, clean anything that's dirty. You have the perfect opportunity to inspect the rear brake lines for corrosion too! I know my banana's
and the rest of the rear suspension were very dirty ( I mean black!) but of course my car is earlier and was neglected for years. HTH, Cheers! Steve
'74 T Targa being now being driven ' 66 Sunbeam Alpine |
French Import
Check the valve adjustment, check for broken studs, replace fuel lines tightem intake manifold...
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Engine Pad, definitely. Yours has probably broken down by now, and you can lose some weight with the new pads.
well it's been 2 years, the car has 68k miles, I rebuilt the entire suspension front and rear along with new shocks and t-bars (thanks elephant!!), new rotors, pads, calipers on all 4 corners, powdercoated most components while off the car, clutch cable, omega spring, fluids (oil, trans, brake), new dash and windshield (that was fun), and did a bunch of other stuff I'm not thinking of...it's all in my binder.
And now I'm FINALLY dropping the trans for the rebuild! I am very excited for this thing to shift the way it's supposed to. (Note that I also have added another child to our household, which is what's causing the delays) I'm still on the fence about replacing seals that aren't leaking, I think Im going to order them and make the call when I'm staring them in the face. |
Connect the radio and play "I'm going to the Led Zeppelin concert". That's what I did when waiting on my 56 bug rebuild back in 69. Jeez, we got baked and it never moved.
I will use a FAF when I am dying of thirst
non-whiner
Clean everything and then pray you figure out how it all goes back together.
"Too much is just enough." |
Best of luck my brotha, mine has been on an engine stand since June. Between the family, the job, daughter's gymnastics, time and money in general it just takes awhile to get everything back together. Especially when you're working on something and you get inspired to take those extra steps to make whatever it is just that much nicer. It doesn't make that particular item any better and no one will notice the difference but because your did whatever it was, it matters and makes all the difference in the world. Believe me, there are a lot of us out there that can't wait to get their cars running again. You are not alone!
Mike '89 CARRERA #402 |
Yes. My weapon to battle inertia is that I am taking a week off, completely, to do nothing but work on the car. That should get me to the point where the only thing left to do is bolt engine to trans, reinstall, and drive away.
The best laid plans... |
Rich, we're all pulling for you.
Just thought I'd close the loop on this. Car is back together. 1k miles on it since the work was done. Runs beautiful. No leaks. Shifts great. Burning very little oil. Valves are quiet.
I think my car is driving better than when it left the factory. It feels amazing. Thank heavens for this forum. Sent from my XT1575 using Tapatalk |
