OK...I'm fairly sure I have to pull the engine to get rid of the oil leaks.
I'm just trying to confirm the engine before I go ahead with the pull. My engine serial number is - 63901804 ... Do I really have a 69S engine? Thanks Bob
Bob Hutson |
Bob ,
do you have the type of the engine? ex. 901/03
1960 356 BT-5 Aetna blue 1973 911 RS récréation 1960 VW panel Dove blue 1971 914 barn find ! |
Hilbilly Deluxe
Thanks guys....
Now I suppose I have to get it out and clean it properly. I can't seem to find the last little oil leak...and it bugs me (smoke coming out of the engine). I fixed the leaks in the rocker shafts with seals...and put in new valve cover gaskets...although I do have 2 minor cracks in the top covers (they do not seem to leak). I guess the only way to be sure is to do a partial engine job (top end) and seal everything properly. Thanks Bob
Bob Hutson |
Warren Hall Student
With the serial number 63901804.
The first digit "6" is for a 6 cylinder. The second digit "3" is for an S type. 1 and 2 stand for T and E respectively. The third digit "9" is the year as in 69' The remainder digits are the sequential build numbers. Bobby |
