SMHemmah
Front wheel bearings replacement help
Forum,
I need my front wheel bearings replaced. I see inside and outside bearings in the new part selection. I also see one seal in the new part selection not two seals.
Thanks Steve
1969 911T Body with 1970 911T 2.2L block with 911S 2.7L P&C and crank |
Well - I just did mine about 3 months ago. My inside and outside seals looked like new - however all of the work to get it apart, cleaned, etc., I still replaced them. They are not that expensive.
Look at it this way. You get everything back together and in 6 months - an inside seal leaks. Okay - tear it down again. They are relatively cheap - replace them
08 Aston Martin Vantage V-8 (6 spd manual) (DD) 20 Cayenne white-black/red (hers) 78 930 (heavily modified) 08 GT3 RS (white/black) (modified of course) 67 911S outlaw (sold) |
Only one (inner) seal required per wheel.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Here is a good video link to you tube. It should help you do everything you need.
https://www.youtube.com/watch?v=PISdpNO8KgI
78 911 SC "Scratchy" 2004 Mini Cooper S "Pele" (gone but not forgotten) 1979 classic mini clubman-"Coolio" |
SMHemmah
Oh, only one seal needed. Ok I can buy now.
I read a few Threads on Front Wheel Bearing replacement. Replacement is more difficult than US cars with heating and cooling needed to replace a 911 bearings. Do I really need to heat the hubs and cool the races? Thanks Steve
I did mine this summer... put the hub on the grill and the race in the freezer. It did make it pretty easy to knock out the old one and put in the new one.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") |
I have not done this yet, but I saved this link for reference:
Paul’s Garage Blog » How to replace the front brakes and wheel bearings on a Porsche 911SC Hope it helps.
1979 911 SC Coupe 2000 VW Passat 1.8T |
![]() Just like chrisbruck said...personally I like my hubs medium well...and I cooked a couple of steaks on the same grille later that evening as a reward for my hard work The light aroma of bearing grease complimented the cheap wine to perfection.Get a good thick pair of real leather gloves. The hubs will be hot and those fake leather mechanics gloves will melt!
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic |
wheel bearings
I did the same as AJ and Chris. Went to my auto supply house, asked for P car front bearings/race. Crossed over to Chevy bearings/race! Installed them 4 years ago, no problem. Cheap too, around $30.00 for both fronts. If you need P/N, let me know. They were FAG bearings too, not junk.
Check this post, Craig_D explains how to do it, there are a lot of pictures
http://forums.pelicanparts.com/porsche-911-technical-forum/726309-78-sc-elephant-racing-suspension-rebuild.html |
I used the oven. If you clean them perfectly it will not stink. You do not want to overheat the aluminum as it may fatigue the metal
I use the grill too for these types of things. Best to use some welding gloves to pick them up.
1968 911S "Leona" Air goes in and out, blood goes round and round, any variation on this is a bad thing. |
heating hubs - clean first?
Was about to heat my front hubs in order to remove the bearings and thought twice. First, having read this post, I think I will use the outside grill rather than the wife's range...
But do I need to clean them thoroughly first? I am thinking of heating a (not very) volatile but still a petroleum product over a flame... Any thoughts? |
Sidenote: what type of blasting would you use on hubs to get them like this?
![]() 2013-11-14-15.32.10-HDR by chriskimmelshue, on Flickr |
Just bought a Harbor Freight blast cabinet. Haven't even set it up yet, but can't wait. What is plastic media? Haven't really looked around yet so excuse my ignorance.
Also, didn't mean to hijack the post but can I heat my hubs on the grill without having cleaned them thoroughly? A bit of grease still on them... Planning on using the outdoor grill... |
