Cleaning Windshield
I have no idea what is going on with the windshield of my 1987 911. Ever since I bought the car in February of this year, the windshield gets a film on it, both inside and out. I can it and it is nearly impossible to clean without streaking. Then, in a day or so, a film reappears. It is making me crazy. I have tried numerous cleaners.... even vinegar. I can get it clean, but it always films back up. Any advice?
Old 09-28-2013, 09:00 PM
tuchan's Avatar
Send a message via MSN to tuchan
I use regular window cleaner from the shop, then I wax it.
Goose- "nothing a year in the tropics wouldn't fix"
Old 09-28-2013, 10:56 PM
Are you driving the car in the time the film is reappearing? Your heater system could be putting oil smoke in to the cabin, causing the residue. I have the same problem with mine. I THINK I finally figured out the stupid controls to turn off all air entering the cabin.
Old 09-28-2013, 11:05 PM
Sounds like Rain-X and/or ArmorAll...
Old 09-29-2013, 01:34 AM
'82 SC TL
canamfan's Avatar
Considering HVAC setting as mentioned, also ensure your heat exchangers/hoses in & around engine for heat are absolutely tight & in good condition, clear from any allowable intrusions of engine oil and fumes. However slight & tiny any cracks, openings or misaligned/loose connections there might be, will make it possible for burnt oil/fumes & even smoke to make there way into the cabin as that same residue collecting on windshield. You should (when needed in winter) be able to keep warm air/defrost setting @ desired setting "without" any fumes/oil residue entering the cabin if all components are in top shape. Check it out to be safe.
76'S 1st Porsche white/can/can early rebuild (boo)
'84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1)
'87 Carrera cpe white/blue short flirt
'89 Anniv. sil/linen very pretty miss her
'88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Old 09-29-2013, 04:58 AM
Thanks for the advice all. It sounds like the "oil smoke" coming into the cabin is probably what is going on.
Old 09-29-2013, 10:39 AM
Registered Cruiser
jorian's Avatar
I had this issue on my 87 as well.
Drove me nuts until I got after all the leaks. All the usual suspects were leaking including the heat exchangers. The HE had a film of oil on the top sides. Cleaned these and a few months later I noticed the interior windshield glass stayed clean.
Didn't figure out the correlation until chatting with a buddy about it.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 09-29-2013, 01:06 PM
Isopropyl alcohol is pretty good at removing oil film from glass.
Oil fumes account for the interior film; I'm guessing you've got Rain-X on the outside if that is also building a film. Rain-X starts to film over when it wants to be renewed.
Old 09-29-2013, 02:05 PM
crustychief's Avatar
It could be the cleaning / preservation products applied to the interior and seats.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 09-29-2013, 02:22 PM
S2GART's Avatar
Film on the inside of a windshield comes from products like Armor-All gassing out. Use a micro fiber towel to clear it away.
The "collection"
1983 911 SC Targa (1 of 1430 imported)
1994 MB E320 Coupe (1 of 825 imported)
1992 MB 190E 2.6
2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
Old 09-29-2013, 05:50 PM
Try this: never leave the car with windows fully closed, the fumes & heat build
up will do that. I always roll down my window by 1/4" on both sides to let the
interior breathe
Old 10-03-2013, 06:29 PM
Eva
911SauCy's Avatar
Exactly why all HVAC has been removed from my SC Targa
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 10-03-2013, 06:34 PM
My '89 had a similar condition, where it seemed there was a film on it - you could wet it and it would appear to go away until it dried. In the end I replaced my 20+ year old windshield and it was well worth the effort - best maintanence I ever did! Having a clear pit-free windshield really improves the driving experience. Now it's been 50k or so miles and it's starting to pit again a little :-(
Chuck.H
'89 TurboLookTarga, 364k miles
Old 10-04-2013, 06:55 AM
The 9 Store
Clean it with white vinagar and water 50/50.
Old 10-05-2013, 12:37 PM
Try using a fine finishing polish, the type you would use on your paint, if there is something on the glass it will take that off and leave you with a real clean windshield.
Old 10-05-2013, 02:17 PM
porwolf's Avatar
Has anybody ever tried "soft scrub" kitchen cleanser? Shouldn't hurt glass.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 10-05-2013, 02:56 PM
Halm's Avatar
I routinely use "Bon Ami" or "Bar Keeps Friend" on the exterior portion of my windshields. They do a really nice job of removing road grime and oils. I also really like Eagle One Glass Cleaner for the interior and polishing the exterior. It is ammonia free and thus doesn't streak when hit with water. It works well on PC and smartphone screens too.
'17 Cayenne
Old 10-05-2013, 03:34 PM
Vinyl off-gassing. Certain products can accelerate the gasses given off by the vinyl in your interior. I have found that as mentioned above armour all,is one of the worst. Also it seems that when the interior heats up and you keep your windows up it is worse as well.
To counter off gassing I simply wipe the interior with a damp rag, and don't park in the sun. When it is in the garage I keep the windows cracked open.
Another thing that helps is a dash cover.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 10-05-2013, 03:55 PM
