keep on working on your project!! i cant wait to be back in the garage)
Very clean build. You might want to add some padding under the fenders so the paint doesn't crack when the tires throw up rocks.
the loose parts on the chassis are carbonfibre
You are going to need more cooling than that
Wer bremst verliert
"320 real hp" as you said in post #1 is quite a bit, I am with Bill on this. At least a center cooler or an active fan on your fender cooler.
Nice build, keep it coming.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
My interest is for my 6 speed '89 project, engine is 3.4/PMO Intake/Motec/SSI, which is basically a street car. Expected HP is around 275 or so.... Dennis |
Thanks for the thoughts Bill!
a second oil cooler is part of the programm! an early oil cooler is bolted directly to the engine.
I've never run an engine mounted cooler so have no opinion on how it would work on a 3.6/3.8 but have run 3.6 & 3.8 in early chassis, for street use 2 front fender mount or 1 front bumper mount are fine( so at a guess the fender mount and the engine mount will be fine for street use), for track use you need all the cooling you can fit, my 3.8RS track car is good w/ 2 very large Setrabs which have front air ducted directly into them, for an early chassis a very large bumper mount and at least one fender mount seem to work ok.
Hi; i need your advice?
i cant make a decision for the tires and rims; go for classic fuchs, minilite or campangnolo? |
this combo looks great!!
I love campangnolo's, but they aren't correct for an ST. So I'd go with Fuchs at the front and minilites on the rear?
The camps in gold anodized would be unique, period correct and really set of the red paint. Minilites would be a close second.
Jim 1987 Carrera 2002 BMW 525ti 1997 Buell Cyclone cafe project 1998 Buell S1W: "Angriest motorcycle I've ever ridden." Last edited by Dueller; 09-22-2014 at 05:19 AM.. |
Has anybody tried Minilite 9X15 at the front and 10X15 at the rear of an ST? offeset +3, enough space?
What a piece of work, wow.
I believe +3 offset was the original front wheel offset for the RSR 15x9 Fuchs. They were used with the 9 inch front flare.
Would also depend on your hubs and brakes. |
That works
Pelican Parts Vendor
BTW 911 Fuchs 15x10 seem to be about -15 if I'm not mistaken. Our replicas certainly are.
Paul Eddleston BRAID Wheels USA Team Illuminata Motorsport |
HI pelicans..
need your help. Does anybody has a 911 3.2 (1984-1989) engine console in spare? I am urgently lookinbg for one to get the engine into the car. Please send PM message if you can supply one. Thanks |
