vinny c's Avatar
Electrical problems
I replaced the 10 fuse block on 1980 SC because it was cracked. Before removing any wires, I marked all upper & lower wires. After finishing, everything works except turn signals and there isn't any CDI whine. Starter does work. There is continuity across all fused circuits. Where does the power for CDI unit originate? Any ideas?
Vince
Old 02-17-2014, 06:32 PM
Send a message via Skype™ to Porboynz
I seem to recall that Porsche did not believe in fusing anything that could stop the car in a race situation on the earlier cars, so the CDI will be fed via the ignition switch directly from an unfused connection on your fuse block. Maybe you have a problem with one of the metal links in behind the fuse block?
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 02-17-2014, 07:28 PM
ROW '78 911 Targa
timmy2's Avatar
Did you replace it with an original piece?
There are jumpers built into the original pieces on the back.
Installing a good used one upside down would cause trouble too as the jumpers/links wouldn't be oriented correctly.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-17-2014, 10:04 PM
T77911S's Avatar
thats what i was thinking. just answered another question concerning the same thing.
there are fuses that have one power source feeding one fuse, then it is bridged over to aother fuse. i dont think you can always see the bridge.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-18-2014, 02:45 AM
vinny c's Avatar
I replaced the jumper from 3 fuse panel to fuse panel. Don't believe I installed upside down but will double check.
Thanks for the help
Vince
Old 02-18-2014, 02:35 PM
